A degraded NAS array can slow down before rebuilding starts because the failure has already changed how ordinary reads and writes are completed. The array may lose a parallel mirror source, reconstruct missing parity data on demand, retry an unstable drive, or route more work through the surviving members.
The rebuild is a later workload that restores the missing member. Degraded operation begins as soon as the array stops trusting one member, so application latency can rise even while the replacement bay is empty and no reconstruction progress bar is running.
What Changes the Moment a RAID Member Is Missing?
Most redundant arrays continue operating in degraded mode, but their data path is no longer the healthy path used when every member is available.
The array controller or software layer records the member as failed, unavailable, or no longer trusted. From that point forward, each request must avoid the missing source and preserve consistency with fewer devices.
The exact penalty depends on the RAID level and the requested block. Reads that target surviving data may remain relatively direct, while reads that require the failed member need reconstruction or another replica.
Why Do Parity Reads Need More Work Before Rebuild?
A request for data that belonged to the failed member becomes a degraded read. During that path, degraded reads spend CPU recovering data from the surviving data and parity pieces.
Instead of reading one requested block, the array may need blocks from several surviving drives, perform an XOR or erasure-code calculation, and return the reconstructed result to the client. That increases device fan-out and processing per request.
Because this reconstruction happens in the foreground, users can notice slower file opens, database reads, media seeks, or application startup before any replacement drive has been added.
Why Does a Mirror Lose Read Parallelism?
Healthy mirrors can distribute reads between equivalent copies. After one member fails, the remaining mirror member serves reads alone, removing the read parallelism and queue distribution that existed before the failure.
Sequential throughput may approach the capability of one disk instead of the combined behavior of the mirror pair. Random requests also accumulate behind one device queue rather than being served from whichever replica is less busy.
This penalty does not require parity calculations. It comes from losing an available copy and concentrating the workload on the surviving member.
Why Can a Half-Failed Drive Be Slower Than a Clean Failure?
A drive that remains visible but struggles with sectors may spend a long time retrying commands. In Linux software RAID, long drive timeouts can stall the array before the storage layer gives up and reconstructs the block elsewhere.
These pauses can be worse than a drive that fails cleanly and is removed from the active path. Requests wait for the uncertain member, queues build behind it, and applications experience long-tail latency even when average throughput still looks acceptable.
Controllers and NAS platforms differ in their timeout, error-recovery, and member-removal policies. That is why two arrays with the same RAID level can respond very differently to the same marginal disk.
How Do Normal NAS Workloads Compete With Degraded I/O?
The surviving drives must continue serving SMB, NFS, containers, media indexing, backups, and app databases while also supplying extra reads for missing data. degraded mode stresses the remaining drives.
A request that once touched one or two devices may now involve the whole parity group. This consumes bandwidth, increases queue depth, and can evict useful cache entries with reconstructed data and metadata.
The slowdown becomes more visible on HDD arrays, busy multi-user systems, and workloads with many small dependent I/O operations. A single large sequential copy can hide latency that an application database exposes immediately.
What Changes When the Rebuild Finally Starts?
Adding a replacement drive begins the second performance phase. The system must restore redundancy, and rebuild traffic can slow reads and writes while foreground applications remain active.
The rebuild reads surviving data, calculates missing content, and writes it to the replacement. That broad background stream competes with the degraded foreground work that was already occurring.
Rebuild priority is therefore a trade-off. A more aggressive rebuild can shorten the vulnerable window but consume more immediate bandwidth, while a very gentle rebuild preserves responsiveness at the cost of remaining degraded for longer.
| Array State | Extra Work | Likely User Effect |
| Healthy mirror | Reads can use either copy | Parallelism and lower queue pressure |
| Degraded mirror | One member serves all reads | Lower throughput and higher latency |
| Degraded parity array | Missing blocks reconstructed on demand | More device reads and CPU work |
| Rebuilding parity array | Foreground reconstruction plus recovery stream | A second, often larger performance penalty |
Can a degraded RAID array be slow even when no rebuild is running?
Yes. The array may already be reconstructing missing reads, using one remaining mirror member, or waiting through retries from an unstable drive.
Does every read become slower in a degraded parity array?
Not necessarily. Reads for data still available directly on surviving members may remain fast, while requests that need the failed member's contribution require reconstruction.
Why can removing a failing drive sometimes improve responsiveness?
A marginal drive can hold commands during repeated recovery attempts. Once the array stops waiting for it, the RAID layer may reconstruct failed reads predictably from redundancy.
Should rebuild priority always be set to maximum?
No universal setting fits every NAS. Higher priority shortens degraded time but may reduce service responsiveness. The decision should reflect workload importance, array condition, and backup readiness.
Final Takeaway
A NAS does not wait for the rebuild to become degraded. Performance can fall immediately because the healthy read path has already disappeared: mirrors lose a replica, parity arrays reconstruct missing blocks, and marginal drives can hold queues in long retries. Rebuilding adds a second workload on top of that degraded path, which is why the slowdown often begins before the progress bar and becomes stronger after it starts.
Why Does Home Assistant Perform Differently on LAN and Remote Connections?
LAN and remote Home Assistant sessions use different network paths; remote latency adds DNS, encryption, WAN, proxy or VPN, and reconnect behavior.
Does Home Assistant Work Reliably Behind CGNAT or Double NAT?
CGNAT and double NAT usually do not affect local Home Assistant control; they mainly change how remote clients can create an inbound path to...
How Does Network Latency Affect Home Assistant During Internet Outages?
Internet loss and network latency are different failures: local device paths can stay fast while DNS, cloud integrations, gateways, or remote clients wait.
