Capability-based access control limits an agent by making authority an explicit, resource-bound capability instead of ambient permission inherited by every tool call.
On a home server, that can let one agent inspect a backup target, another restart one service, and a third read a photo folder without sharing a master credential.
A Capability Binds Authority to a Specific Resource
Capability-based access control represents authority as a token or reference that identifies an object and carries the rights available on that object.
seL4 describes a capability as an unforgeable token that grants permission to access an entity or object. Possession is part of the authorization mechanism. seL4 represents authority through capabilities that reference specific kernel objects, providing a concrete example of resource-bound authority in seL4 capability model.
For a home AI agent, a backup tool can receive authority for one repository rather than ambient access to the entire filesystem. Knowing a path alone does not grant permission.
Possession Replaces Ambient Authority With Explicit Delegation
Traditional environments often expose ambient authority through process credentials or broad API tokens.
Capability systems make authority explicit in the references a component actually holds.
seL4 capDL describes which parts of a system possess capabilities to which other parts. Those distributions define access-control boundaries. Wasmtime describes capability-oriented isolation for WASI resources, illustrating how explicit possession can replace broad ambient access in Wasmtime capability security model.
A photo-organizing sub-agent can therefore receive read access to an import folder and write access to staging without gaining delete authority over the archive.
Rights Can Be Narrower Than the Resource
A capability can carry rights that limit which operations are available on the referenced object.
Two agents can hold capabilities to the same object with different authority.
seL4 explains that a capability encapsulates an object reference plus access rights that control permitted operations. The Bytecode Alliance has described WASI around capability-based security, supporting the idea that granted rights can be narrower than the host resource itself in WASI capability-based security.
A monitoring workflow might hold read-status authority while a maintenance workflow holds restart authority. The service is the same; the usable operations are not.
Delegation Can Hand a Smaller Capability to a Subtask
Capability systems fit agent decomposition because authority can be passed with the work. A parent agent can delegate only what one helper needs instead of forwarding a master credential.
Cap'n Proto models RPC references as references that also convey authority to call an object. Passing the reference passes a specific ability. Cap’n Proto RPC treats object references as capabilities that may be passed to other components, which is a useful model for delegated authority in Cap’n Proto object capabilities.
A helper asked to inspect one log directory can receive a read capability for that directory alone. Its prompt may mention other resources, but the authority cannot expand by request.
Capability Mechanisms and Tool Scope Are Different Layers
Tool scope is a policy choice about how narrow an agent action should be.
Capability-based access control is a runtime mechanism for representing and enforcing that authority.
ZimaSpace's home AI agent tool-scope analysis explains why action, resource, argument, and credential scope should narrow as autonomy grows. Current IETF draft work on attenuating agent tokens explores delegated authority that can be narrowed for downstream agents, illustrating the delegation boundary in attenuating agent token draft.
Capability enforcement still matters when the agent logic fails. ZimaSpace's repeated tool-call loop analysis shows why behavioral failure and authority limits must be treated separately.
Revocation and Legacy APIs Remain Implementation Boundaries
Practical systems still need ways to revoke lost authority, expire temporary access, and bridge services that only understand users, roles, or bearer tokens.
seL4 exposes capability derivation and deletion operations, but revocation behavior depends on the surrounding architecture. The cap-std project exposes external resources as capability values rather than ambient globals, while also showing that legacy APIs and revocation remain separate engineering concerns in cap-std capability-based APIs.
A capability wrapper around a NAS API is only as strong as the gateway behind it. If every request ultimately uses an unrestricted administrator token, the apparent granularity can disappear below that boundary.
