A Home Assistant performance benchmark is useful only when it reproduces the same workload and defines what โfast enoughโ means before looking at resource graphs. Otherwise CPU, memory, storage, and network numbers become observations without a capacity conclusion.
This is different from troubleshooting one slow installation. A benchmark deliberately creates a repeatable baseline, increases one workload dimension, and identifies how much resource margin remains before a chosen automation, history query, or dashboard response leaves its acceptable latency range.
Define One Workload and One Acceptance Threshold
Choose a workload that represents an actual household peak: for example, a local motion automation, three active dashboards, normal Recorder writes, one backup-free background period, and a fixed set of integrations. Record Home Assistant version, host hardware, storage, database, client, network path, and test duration.
Home Assistant's System Information view exposes installation, network, integration, and resource context that should be recorded alongside a performance result. Without environment details, one person's response time cannot be meaningfully compared with another machine.
Then define the acceptance threshold. A lighting automation might need a sub-second physical response while a five-year History query may be acceptable at several seconds. Do not combine those into one generic โHome Assistant speedโ score.
Use Utilization, Saturation, and Errors for Every Shared Resource
Average utilization alone is a poor stop condition. A disk can be busy but healthy, or a CPU can show modest average use while short bursts create a queue that users feel as latency.
The USE Method evaluates utilization, saturation, and errors for each physical or constrained resource. Apply that frame to CPU, memory capacity, storage I/O, and network interfaces rather than choosing the tallest utilization graph.
For containerized Home Assistant, include cgroup limits as resources too. A host with 60% free CPU can still throttle a container that has reached its assigned quota.
Pressure Metrics Show Time Lost to Resource Scarcity
Linux Pressure Stall Information adds a latency-oriented view. Instead of asking only how much CPU, memory, or I/O is used, PSI measures the fraction of time tasks are stalled because a resource is contended.
The Linux kernel documentation explains that CPU, memory, and I/O pressure can be measured as real time lost to contention, including short spikes that damage latency before average utilization looks extreme.
That makes PSI useful in a shared home server. If Home Assistant latency worsens when I/O pressure rises during another container's write burst, you have stronger evidence of shared storage contention than โthe SSD was 70% busy.โ
Increase Only One Workload Dimension Per Run
Do not simultaneously add dashboard users, automation triggers, camera streams, retention, and backup traffic. Increase one variable while every other condition remains fixed.
Useful step tests include more automation events per minute, more concurrent dashboards, larger History ranges, more entity updates, or one defined neighboring-service load. After each step, wait long enough for the system to reach steady behavior rather than collecting the first ten seconds of a warm cache or startup burst.
The ZimaSpace analysis of shared storage queue contention and tail latency shows why the workload must be mapped to the resource path: storage matters only when the tested action depends on it directly or shares the same I/O queue.
Change One Resource and Require the Result to Move
A benchmark becomes diagnostic when a controlled resource change moves the latency curve. Pin a heavy neighbor away from Home Assistant CPU, pause a write-heavy job, raise a tested cgroup memory limit, use a direct LAN route, or move app data to lower-latency storage.
If the original latency threshold improves at the same workload step, the resource was plausibly constraining headroom. If nothing changes, revert the experiment and test the next candidate instead of turning the change into permanent configuration.
Publish the Result as a Capacity Envelope
| Workload dimension | Measure with | Stop when |
| Automation/event rate | Trigger-to-action tail latency | Latency or queues grow persistently |
| Dashboard clients | Server response + client render | Repeated interaction delay exceeds target |
| Recorder/history load | Query latency + storage pressure | I/O pressure or query tail bends sharply |
| Shared-host load | PSI / cgroup / utilization | Home Assistant latency moves with contention |
| Network path | RTT, loss, DNS, response time | Remote path breaks the defined target |
The final result should read like โthis hardware, database, client mix, and background workload keeps the chosen control path inside the target through step N.โ That statement is reproducible. โHome Assistant uses only 20% CPUโ is not.
