AI photo labels change after an upgrade because the new model represents images, compares labels, and applies confidence boundaries differently from the old model.
A self-hosted photo library may keep the same original files while smart-search terms, detected objects, face groups, duplicate suggestions, or scene labels change after an update. These labels are derived database records, not facts written permanently into the image. When the visual encoder, text encoder, class vocabulary, threshold, preprocessing pipeline, or clustering rule changes, the system recalculates where a photo belongs.
A Photo Label Is a Model Decision, Not Permanent Metadata
Camera timestamps and filenames can be read from stored data, but labels such as “beach,” “dog,” “birthday,” or “vehicle” are predictions produced by a particular model version and configuration.
Amazon Rekognition returns the label-detection model version with results because the version is part of the meaning of the prediction. The service also exposes aliases, categories, and confidence values rather than treating one label string as an unchanging property.
A local photo system should preserve the same provenance. Without model name, version, preprocessing settings, and job time, an administrator cannot tell whether a changed label reflects a new model, a different threshold, or a damaged index.
New Embeddings Create a Different Similarity Space
Smart-search systems commonly convert each image into a vector. Text queries and candidate concepts are mapped into the same space, and labels or search results depend on which items are nearest.
Qdrant explains that even small embedding-model changes can shift the geometry of the vector space, requiring data to be re-embedded and reindexed for accurate comparisons.
The old and new vectors are not interchangeable scores. A photo close to “garden” in one space may move closer to “park” or “backyard” in another, even when both models are reasonable descriptions of the scene.
Candidate Words and Prompts Change the Winner
Zero-shot classification does not discover one universal label independently of language. It compares an image with supplied candidate labels or textual prompts and ranks those alternatives.
Hugging Face’s zero-shot image-classification workflow explicitly constructs candidate-label prompts such as “This is a photo of …” before scoring them against an image.
An upgrade can add labels, rename them, translate them, or change prompt templates. Adding “golden retriever” can replace the broader “dog,” while removing a narrow class can make the same image fall back to “animal.”
Label Hierarchies Change Granularity
Photo labels often form parent-child relationships: vehicle, car, sports car; food, dessert, cake. The system may display the narrowest class, the parent, or several levels depending on the model and interface.
The CHiLS research shows that hierarchical label sets can change classification by generating subclasses and then mapping predictions back to parent categories.
An upgraded ontology can therefore make labels appear more specific or more general without a straightforward accuracy loss. Auditing should compare the hierarchy and mapping rules, not only whether the old string remains present.
Confidence Thresholds Decide Which Labels Become Visible
Models usually return several candidates with scores. The application chooses how many to store and the minimum confidence required before a label appears in search or the photo detail view.
Changing a threshold can hide borderline labels or expose many more weak ones. A model whose score calibration differs from its predecessor may need a different threshold even when its ranking quality is better.
Store raw or top-k scores during evaluation, then choose display thresholds per model version. Reusing one numeric cutoff across unrelated models can make the upgrade look unstable when the real problem is score calibration.
Face Groups Can Change Even When Object Labels Do Not
Face recognition normally creates embeddings for detected faces and clusters nearby points into people. A new detector can change the crop, while a new recognition model changes the face-vector distances.
DBSCAN groups points according to neighborhood radius and minimum density; the distance and density parameters determine whether a face joins a person, forms another group, or remains an outlier.
Model changes and clustering changes should be audited separately. A cleaner face crop may split a previously merged person, while a looser distance threshold can merge relatives who look similar.
Partial Reprocessing Mixes Two Generations of Labels
If only new photos are processed with the upgraded model, the library contains old and new semantic spaces at once. Search results and labels can vary according to when each asset entered the system.
Immich instructs administrators to reprocess all assets after changing the smart-search model, and notes that incompatible data from the previous model can otherwise cause errors.
Use a versioned rebuild or a second index, verify completion, then switch searches atomically. Do not delete the old index until the new generation has complete asset counts and acceptable retrieval tests.
Version Predictions and Protect Human Corrections
Keep model-generated labels separate from user-created albums, manual tags, named people, and hidden-label decisions. An automated rebuild should not silently overwrite the user’s organizational work.
Evaluate a fixed set of representative photos before deployment. Compare added labels, removed labels, rank changes, false positives, face splits and merges, and search queries important to the household.
ZimaSpace’s article on why image resolution changes multimodal AI load adds another variable: preprocessing resolution and crop policy can change the visual evidence supplied to the upgraded model.
Does a changed label mean the new model is worse?
No. It may use a different vocabulary or choose a more specific parent-child class. Accuracy must be evaluated against representative photos and intended search tasks.
Should old AI labels be deleted immediately?
No. Keep the old generation until reprocessing and comparison finish. Versioned labels make rollback and regression analysis possible.
Can manual photo tags survive model upgrades?
Yes, when manual tags are stored separately from generated predictions and rebuild jobs are restricted to model-owned fields.
Why Do Smart Home Predictions Become Less Accurate After Seasonal Routine Changes?
Seasonal routines change the relationship between time, sensors, occupancy, and desired actions, making a model trained on older habits stale.
Why Does a Home NVR Miss Brief Events When Object Tracking Is Enabled?
Tracking needs enough detections to start and confirm a trajectory, so a brief object can disappear before the NVR creates a valid event.
Why Does Local Voice Recognition Fail More Often in Far-Field Rooms?
Far-field rooms weaken direct speech and add reflections and noise, so the recognizer receives a less stable acoustic pattern than close speech.
