Quick Answer
The best AI agent skills to try in June 2026 are not just the most-starred repositories. The strongest picks combine three things: a real SKILL.md structure, visible community or GitHub activity, and a practical workflow that solves a repeated problem for users.
Based on June 2026 signals, the most useful AI agent skills and skill collections include Anthropic Skills for official examples, Vercel Agent Skills for web app workflows, K-Dense Scientific Agent Skills for researchers, Supabase Agent Skills for backend and database work, Cloudflare Skills for edge deployment, n8n Official Skills for self-hosted automation, Qdrant Skills for RAG and vector search quality, Chroma Agent Skills for local semantic search, Sentry for AI for production debugging, Hookdeck Webhook Skills for event-driven automation, delegate-local for local model routing, and NVIDIA Skills for AI infrastructure and governance.
If you want to compare skills by role, category, and workflow, you can start from the AI Agent Skill Finder and use this June list as a current recommendation layer.
How We Picked These June 2026 AI Agent Skills
AI agent skills are moving fast. A list that was useful in March may already miss new official repos, new security concerns, or new community workflows by June. For this monthly recommendation, the goal is not to list every skill. The goal is to help users decide which skills are worth checking first.
The evaluation uses four signals: whether the skill is real and installable, whether the source is official or community-maintained, whether GitHub activity suggests momentum, and whether Reddit or community discussions show real user demand.
GitHub Stars Are Useful, but Not Enough
Stars are a useful popularity signal, but they should not be the only ranking factor. A large official repo may have high stars because it defines the ecosystem. A small repo may still be highly valuable if it solves a narrow, painful problem, such as local model routing, webhook verification, or RAG search quality.
For June 2026, the best approach is to separate “broad ecosystem signal” from “workflow value.” Anthropic Skills, Vercel Agent Skills, K-Dense Scientific Agent Skills, and VoltAgent’s directory have strong star signals. Smaller repos like Chroma Agent Skills, Hookdeck Webhook Skills, and delegate-local are more specialized, but they may be more useful for the right user.
Reddit Discussion Shows Real Pain Points
Reddit is useful because users often describe the problem before they know the solution. Agent skill discussions in 2026 show recurring concerns: which Claude Code skills are actually worth installing, how to make skills portable across providers, whether AGENTS.md matters more than skills, how to run local agents with Ollama, and whether unvetted SKILL.md files create a supply-chain risk.
That is why this list does not only reward hype. It looks for skills connected to real workflow pain: broken web app tests, unreliable webhooks, poor RAG retrieval, production errors, self-hosted automation, local privacy, and scientific literature overload.
A Skill Must Be Installable, Copyable, or Clearly Source-Backed
A generic capability is not enough. “Code review,” “research,” “debugging,” “automation,” and “RAG” are categories, not concrete skills. A June 2026 recommendation should point to something the user can install, copy, inspect, or adapt.
The best examples are repositories or folders with a clear SKILL.md, installation command, plugin path, or documented usage pattern. If a project is more of a directory, MCP server, or conceptual framework, it should be labeled clearly instead of being presented as a direct skill.
June 2026 Top AI Agent Skills Recommended
1. Anthropic Skills
Anthropic Skills is the best starting point for understanding the pattern. It includes official examples for creative work, web app testing, MCP server generation, and document handling skills such as PDF, DOCX, XLSX, and PPTX.
Category: official baseline, document workflows, testing, MCP building.
June 2026 signal: very high GitHub star signal and strong reference value.
Recommended for: users who want to understand what a real skill package looks like before installing third-party repos.
Why it matters: this repo is less about one narrow workflow and more about the standard pattern: a self-contained folder with instructions, metadata, and optional resources. It is the safest reference point for explaining what counts as an AI agent skill.
2. Vercel Agent Skills
Vercel Agent Skills is one of the strongest June 2026 picks for builders working on modern web apps. It includes installable skills and guidance for web design, React, Next.js, Vercel optimization, and deployment-oriented workflows.
Category: web app development, frontend quality, deployment, performance.
June 2026 signal: high star count, official Vercel source, and strong community discussion around agent workflows.
Recommended for: SaaS builders, indie hackers, frontend teams, Next.js developers, and product engineers.
Why it matters: many AI-generated web apps look finished but fail on performance, accessibility, routing, deployment cost, or UX polish. Vercel’s skill set helps agents reason with framework-specific and platform-specific context instead of generic web advice.
3. K-Dense Scientific Agent Skills
K-Dense Scientific Agent Skills is the strongest June 2026 pick for researchers and scientific users. It includes a large scientific skill library and install support across agent platforms such as Claude Code, Codex, Gemini CLI, Cursor, and other Agent Skills-compatible tools.
Category: research, science, literature workflows, domain-specific analysis.
June 2026 signal: strong star count, many releases, and a fresh June 2026 update signal.
Recommended for: researchers, PhD students, lab teams, data scientists, and scientific software users.
Why it matters: researchers do not only need paper summaries. They need domain-aware workflows for literature triage, experimental design, scientific databases, data analysis, and manuscript preparation. This collection is more differentiated than a generic “research assistant” prompt.
4. Supabase Agent Skills
Supabase Agent Skills is a practical recommendation for anyone building a product with Supabase. It includes a broad Supabase skill and a Postgres best-practices skill covering schema design, RLS, performance, connection management, indexing, migrations, and auth workflows.
Category: backend, database, auth, SaaS infrastructure, vectors.
June 2026 signal: official repo, thousands of stars, concrete install commands, and direct product coverage.
Recommended for: indie hackers, SaaS developers, backend builders, and teams using Supabase as a product database.
Why it matters: agents often produce database changes that look plausible but are risky in production. Supabase skills help guide the agent toward safer Postgres, RLS, auth, and performance decisions.
5. Cloudflare Skills
Cloudflare Skills is a strong June recommendation for low-cost deployment, edge computing, Workers, Wrangler, Agents SDK, Cloudflare One, and web performance workflows.
Category: edge deployment, Workers, web performance, AI agents, infrastructure.
June 2026 signal: official Cloudflare repo, active commits, plugin and npx installation paths, and support across several agent hosts.
Recommended for: developers deploying on Cloudflare, homelab users using tunnels, and teams building edge-native apps.
Why it matters: Cloudflare is not only a hosting platform. It is also becoming an agent deployment and edge automation platform. Skills can help agents avoid outdated Workers patterns and reason about performance, bindings, storage, and deployment configuration.
6. n8n Official Skills
n8n Official Skills is one of the most important June picks for self-hosted automation. It includes capability skills for workflow lifecycle, sub-workflows, expressions, loops, AI agents, credentials, error handling, data tables, debugging, and more.
Category: self-hosted automation, workflow design, AI agents, credentials, debugging.
June 2026 signal: official source, fresh repo activity, SessionStart hooks, PreToolUse hooks, and strong relevance to self-hosted automation.
Recommended for: automation builders, self-hosted users, AI workflow operators, and n8n teams.
Why it matters: this is not a coding skill. It is an automation-operations skill set. It helps agents understand triggers, nodes, expressions, credentials, workflow errors, and high-impact tool calls.
7. Qdrant Skills
Qdrant Skills is the best June 2026 recommendation for serious RAG and vector search work. It covers deployment options, search quality, scaling, performance optimization, monitoring, model migration, version upgrades, and SDK usage.
Category: RAG, vector search, semantic search, retrieval quality, production search.
June 2026 signal: official Qdrant source, active documentation, and strong fit with real community pain around retrieval quality.
Recommended for: local AI builders, RAG engineers, knowledge-base builders, and teams debugging poor search results.
Why it matters: the hardest part of RAG is not always storing vectors. It is diagnosing why search results are bad. Qdrant’s skills help agents reason through chunking, embeddings, metadata filters, hybrid search, reranking, deployment mode, and performance trade-offs.
8. Chroma Agent Skills
Chroma Agent Skills is an early but useful official collection for Chroma local and Chroma Cloud workflows. It includes chroma-local for open-source and self-hosted Chroma and chroma-cloud for cloud workflows.
Category: local RAG, semantic search, Chroma integration.
June 2026 signal: small star count but official source, recent release, and clear install commands.
Recommended for: users building small to medium private knowledge bases, local search apps, and early-stage RAG experiments.
Why it matters: not every valuable skill has a huge star count. Chroma Agent Skills are worth recommending because they solve a concrete problem: helping an agent make better local or cloud Chroma integration decisions.
9. Sentry for AI
Sentry for AI helps AI coding assistants use Sentry for setup, debugging, alerts, and production issue workflows. It also configures the Sentry MCP server as part of the install flow.
Category: production debugging, observability, error triage, incident workflow.
June 2026 signal: official Sentry source, real GitHub activity, and clear Agent Skills specification support.
Recommended for: teams that already use Sentry, indie products with real users, and developers who want agents to fix production issues from evidence.
Why it matters: production debugging is where generic coding agents often fail. A Sentry-aware skill can connect stack traces, breadcrumbs, traces, alerts, and code context into a more grounded debugging workflow.
10. Hookdeck Webhook Skills
Hookdeck Webhook Skills is a strong pick for event-driven apps and automation. It includes provider-specific skills for webhook receivers, signature verification, event handling, retries, replay, and debugging.
Category: webhooks, SaaS integrations, automation, payments, event handling.
June 2026 signal: moderate star count, high commit count, many provider-specific skills, and strong practical relevance.
Recommended for: SaaS builders, automation users, Stripe users, Shopify app builders, GitHub automation, and workflow engineers.
Why it matters: webhooks are easy to generate incorrectly. Agents often hallucinate signature verification code, ignore raw body requirements, or skip idempotency. This skill collection gives agents provider-specific implementation guidance.
11. delegate-local
delegate-local is a June 2026 hidden gem for local AI workflows. It routes summarization, log triage, changelog drafting, issue classification, structured extraction, and prose rewriting to local Ollama or MLX models instead of always using a cloud model.
Category: local AI, privacy, model routing, bulk text tasks.
June 2026 signal: low star count but high commit count, many releases, and a fresh June 2026 release.
Recommended for: local AI users, privacy-focused builders, homelab users, and anyone processing private logs or documents.
Why it matters: star count alone would miss this skill. Its value is practical: it keeps suitable work on-device, reduces cloud token use, and gives an agent a repeatable pattern for choosing local models when appropriate.
12. NVIDIA Skills
NVIDIA Skills is a June 2026 pick for AI infrastructure users. It publishes agent skills for NVIDIA CUDA-X libraries, AI Blueprints, and platform tools, with an emphasis on governance signals such as signatures, skill cards, and evaluation datasets.
Category: AI infrastructure, CUDA-X, AI Blueprints, enterprise governance.
June 2026 signal: official NVIDIA source, daily sync process, and governance-oriented metadata requirements.
Recommended for: AI infrastructure teams, GPU developers, enterprise AI teams, and builders using NVIDIA platform tooling.
Why it matters: most skill lists focus on convenience. NVIDIA Skills are useful because they point toward a more governed future: signed skills, identity cards, and evaluation data instead of anonymous instruction files.
Which Skill Category Should You Choose First?
Coding and Web App Builders
Start with Vercel Agent Skills, Supabase Agent Skills, Cloudflare Skills, Sentry for AI, and Hookdeck Webhook Skills. This stack covers the path from building a web app to deploying it, handling backend data, receiving external events, and fixing production issues.
Use Anthropic Skills as the reference set for understanding how the structure works, but choose workflow-specific skills for daily work.
Local AI and Private RAG Users
Start with delegate-local, Chroma Agent Skills, and Qdrant Skills. This combination helps with local model routing, local semantic search, private knowledge bases, and retrieval quality diagnosis.
If your main pain is “my local AI assistant gives bad answers over my documents,” Qdrant Skills and Chroma Skills are more relevant than generic coding skills.
Researchers and Knowledge Workers
Start with K-Dense Scientific Agent Skills and Anthropic’s PDF, DOCX, XLSX, and document-related skills. This category is different from coding. The goal is not to generate code, but to search literature, process papers, analyze tables, draft documents, and preserve evidence.
Self-Hosted Automation Users
Start with n8n Official Skills, community n8n skillsets, Hookdeck Webhook Skills, Cloudflare Skills, and delegate-local. This stack helps agents operate around workflows, triggers, credentials, webhooks, and notifications.
Self-hosted automation skills should be evaluated more strictly than writing skills because they may touch credentials, files, workflows, or external actions.
Teams That Care About Trust and Governance
Start with official sources, inspect every SKILL.md, avoid abandoned repos, pin versions where possible, and keep a private allowlist. NVIDIA Skills are worth watching because they show how skills may evolve toward signed, evaluated, and governed artifacts.
For teams, the question is not only “what skill should we install?” It is also “who approved this skill, what version is running, what tools can it call, and how do we roll it back?”
What to Avoid When Installing AI Agent Skills
Do Not Install Skills Only Because They Have Stars
A high-star repo can still contain skills you do not need. A low-star repo can be valuable if it is official, narrow, recent, and solves a real workflow. In June 2026, star count should be treated as a popularity signal, not a safety guarantee.
Avoid Abandoned or Unscoped Skills
A skill should have a clear trigger, clear boundaries, and a clear purpose. Avoid skills with vague descriptions such as “make the agent better” or “do everything.” These are hard for agents to select correctly and harder for users to audit.
Treat Skill Files Like Software Dependencies
Skills can influence what an agent reads, trusts, and does. Even instruction-only skills can steer behavior. Skills with scripts or tool calls require more scrutiny. Before installing a third-party skill, read the SKILL.md, inspect scripts, check recent commits, review issues, and test in a low-risk project.
Conclusion
The best AI agent skills in June 2026 are not simply the biggest repos. They are the skills that package real workflow knowledge into something an agent can reuse safely.
If you are building web apps, start with Vercel, Supabase, Cloudflare, Sentry, and Hookdeck. If you are building local AI or RAG, start with delegate-local, Chroma, and Qdrant. If you are a researcher, start with scientific and document-processing skills. If you run self-hosted automation, start with n8n skills and approval-gated workflows.
Most importantly, treat skills as part of your agent supply chain. Install fewer skills, choose better sources, and keep the ones that solve repeatable problems.
What are the best AI agent skills to try in June 2026?
The strongest June 2026 recommendations are Anthropic Skills, Vercel Agent Skills, K-Dense Scientific Agent Skills, Supabase Agent Skills, Cloudflare Skills, n8n Official Skills, Qdrant Skills, Chroma Agent Skills, Sentry for AI, Hookdeck Webhook Skills, delegate-local, and NVIDIA Skills.
Should I rank AI agent skills only by GitHub stars?
No. Stars are useful, but they do not prove that a skill is safe, relevant, or well-scoped. Also check whether the skill is official, recently maintained, installable, narrow enough to trigger correctly, and tied to a real workflow.
Which AI agent skill is best for local AI workflows?
delegate-local is one of the most practical picks for local AI because it routes suitable tasks to local Ollama or MLX models. For local RAG, chroma-local and Qdrant search-quality skills are stronger choices.
Which AI agent skills are best for self-hosted automation?
n8n Official Skills, community n8n skillsets, Hookdeck Webhook Skills, Cloudflare Skills, and delegate-local are strong choices for self-hosted automation. Focus on triggers, approval gates, notifications, credentials, and workflow debugging.
Which skills are best for researchers?
K-Dense Scientific Agent Skills are the strongest broad research pick in June 2026. Researchers should also consider document skills for PDFs, spreadsheets, and manuscripts, especially when working with literature reviews, lab data, and draft writing.
Are AI agent skills safe to install?
Not automatically. A skill can influence an agent’s behavior, and some skills include scripts or tool access. Read the skill file, inspect any scripts, prefer official sources, pin versions when possible, and test in a low-risk environment before using a skill on important data.
What is the difference between an AI agent skill and an MCP server?
An MCP server gives an agent access to tools or data. A skill tells the agent how to use that access. For example, a filesystem MCP server may expose files, while a skill can define when the agent may read, edit, summarize, or ask for approval.
How many AI agent skills should I install?
Install fewer than you think. Start with three to five skills tied to workflows you repeat every week. Too many skills can create noisy matching, overlapping instructions, and higher audit burden.
