A supported HBA in true initiator-target or JBOD mode is the correct default for ZFS. Hardware RAID is built to own disk grouping and recovery, while ZFS expects to see individual devices and manage checksums, redundancy, replacement, and repair itself.
The comparison is not about which controller has more features. It is about which layer has authority over disk identity, write ordering, error reporting, and reconstruction. Giving both the RAID controller and ZFS partial ownership creates ambiguity exactly when recovery is most difficult.
What ZFS Needs From the Controller
The controller should expose each drive with a stable unique identifier, accurate sector size, error status, and no hidden redundancy. It should pass SMART or equivalent health data, support the operating system reliably, and avoid a volatile write cache that acknowledges data before it is durable.
OpenZFS’s hardware guidance explicitly recommends direct disk access and explains how hardware RAID can restrict self-healing, distort device information, and tie recovery to a controller family.
An HBA passes when every disk is visible by serial, a removed disk maps to the expected bay, and the pool imports through another compatible HBA without rebuilding proprietary arrays.
Why Single-Disk RAID 0 Is Not JBOD
Creating one RAID 0 virtual disk per physical drive may appear to expose disks separately, but the controller still inserts metadata, caching, naming, and error translation. A firmware reset or controller replacement can change how those virtual disks appear.
This workaround also risks hiding native error behavior and makes the recovery sequence depend on recreating controller configuration correctly. It should not be treated as equivalent to IT-mode disk presentation.
If existing hardware cannot expose true JBOD and replacing it is impossible, use the RAID controller as the sole redundancy layer with a conventional filesystem rather than stacking pretend raw disks under ZFS. That is the honest third option.
Recovery Is the Deciding Test
With an HBA, ZFS pool metadata lives on the member disks and the operating system can usually import the pool through another supported direct-access controller. The recovery dependency is the filesystem, device compatibility, and healthy members—not one proprietary array definition.
Hardware RAID recovery may require a compatible controller, matching firmware behavior, preserved cache state, and correct import of the controller’s metadata before ZFS can even see its virtual device. That extra gate can extend downtime and narrow replacement choices.
Before production, export a disposable pool, move its members to another direct-access controller, import by persistent identifiers, and perform a checksum read. Record the exact commands and physical serial mapping.
When Hardware RAID Still Has a Role
Hardware RAID can be appropriate when the operating model, vendor support, and filesystem are designed around the controller. It may also be unavoidable in an appliance. In those cases, let the controller own redundancy and follow its tested battery, cache, firmware, and replacement procedure.
The client-facing share remains a separate design layer; use this SMB and NFS comparison after the disk ownership model is settled.
Do not select hardware RAID for ZFS merely to gain a cache or familiar management screen. Those benefits do not offset obscured disks and a second recovery authority.
Final Decision
Choose an HBA in verified direct-access mode for ZFS. Choose hardware RAID with a non-ZFS storage design when controller-managed redundancy and vendor support are the requirement. Avoid the hybrid of ZFS over single-disk RAID 0 virtual disks.
Can a RAID controller in true HBA mode be used with ZFS?
Yes, if the mode genuinely exposes each disk, preserves stable identifiers and sector data, passes health information, disables hidden RAID behavior, and is supported by the operating system.
Does an HBA make backup unnecessary?
No. It improves device visibility and recovery portability. It does not protect against deletion, pool-wide corruption, theft, fire, or failure of multiple members.
Product Comparisons
LXC vs Docker on Proxmox for App Updates and Rollbacks
Docker gives app-level version control; LXC gives guest-level rollback. The better fit follows the smallest state unit you can restore safely.
Docker vs LXC Security Boundaries for Privileged Home Services
Docker fits narrowly packaged apps; LXC fits fuller Linux services, but neither replaces a VM when shared-kernel risk is unacceptable.
Turnkey NAS OS vs Modular Linux for a First-Time Builder
Choose turnkey NAS software for guided storage operations; choose modular Linux when learning and explicit control justify more ownership.
