If your future NAS contains a 4TB drive, an 8TB drive, and a 16TB drive collected from different systems, choosing an operating system is not merely an interface decision. The storage model determines how much capacity you can use, how failures are handled, and whether adding another mismatched drive later will be straightforward or disruptive.
For most mixed-drive builds that require parity protection, Unraid is the most natural fit. ZimaOS is easier to approach when you prefer conventional RAID or simple JBOD storage, while CasaOS is better understood as an application dashboard that leaves advanced pooling and redundancy to the underlying Linux system. The right choice therefore depends on whether you prioritize capacity retention, protection, simplicity, or administrative control.
Why Mixed Drives Change the OS Decision
Traditional RAID works most predictably when its member drives have matching capacities and similar performance. With mismatched drives, the smallest member can determine how much space each disk contributes to a conventional RAID group. A larger disk may therefore have capacity that the array cannot immediately use.
Unraid takes a different approach. Its primary array stores files on individually formatted data disks and calculates parity separately. The critical sizing rule is that no data disk may be larger than the parity disk. With dual parity, both parity disks must be at least as large as the largest data disk, as explained in the official documentation covering Unraid array architecture and parity sizing.
This distinction creates five questions that should guide the comparison:
- How much of each drive's capacity remains usable?
- Does the storage model provide redundancy?
- Can a differently sized drive be added without rebuilding the pool?
- What data remains accessible after more drives fail than the protection scheme can tolerate?
- How much manual Linux administration is required?
Three Storage Models, Three Different Failure Boundaries
Although all three platforms can expose files over a network and run containerized applications, they do not manage storage in the same way. The distinction between an operating system, a storage layer, and an application dashboard matters more than their visual similarities.
Unraid: independent data disks with dedicated parity
Unraid combines independently formatted data disks into shared storage while reserving one or two drives for parity. It does not stripe every file across all array members in the same way as conventional RAID 5 or RAID 6.
The result is especially useful when drive sizes differ. A 4TB and an 8TB data disk can contribute their respective capacities as long as the assigned parity disk is at least as large as the largest data disk. The tradeoff is that the parity disk contributes protection rather than ordinary file capacity.
ZimaOS: graphical management for RAID and JBOD
ZimaOS is a purpose-built home server operating system with graphical storage management. Its current storage interface supports RAID 0, RAID 1, RAID 5, RAID 6, and JBOD, with ZFS available as a separate option.
Conventional RAID can provide strong redundancy, but it is usually most space-efficient when member drives have matching capacities. JBOD can use more of a mixed collection's raw capacity, but it does not provide redundancy.
CasaOS: an application layer over Linux storage
CasaOS is closer to a lightweight application and Docker management layer installed over a Linux distribution such as Debian or Ubuntu. The distinction between CasaOS and a complete storage-focused operating system is also described in this guide to CasaOS and ZimaOS home server roles.
CasaOS can display mounted storage and make it available to applications, but more advanced pooling and parity normally need to be created below its interface. That may involve Linux filesystems, software RAID, MergerFS, SnapRAID, or another storage-management layer.
How the Same Mixed-Drive Set Changes Across Each System
Consider a home server containing one 4TB drive, one 8TB drive, and one 16TB drive. The goal is to create shared storage while protecting against a single drive failure.
| Platform | Possible configuration | Approximate data capacity | Protection |
| Unraid | 16TB parity plus 4TB and 8TB data disks | Approximately 12TB before formatting overhead | One failed data disk can be rebuilt with valid single parity |
| ZimaOS | RAID 5, RAID 1, JBOD, or separate disks | Depends on the selected mode and capacity shown by the creation wizard | RAID-dependent; JBOD provides no redundancy |
| CasaOS | Separate volumes or a manually configured pooling stack | Up to the combined data-disk capacity, depending on the manual design | None by default; protection depends on the underlying storage tools |
For Unraid, using the 16TB disk as parity leaves the 4TB and 8TB disks as data members, producing approximately 12TB of usable file capacity before filesystem overhead. Using the 16TB disk as a data disk would require a parity disk of at least 16TB.
ZimaOS should not be assigned an exact mixed-drive RAID 5 capacity without checking the current storage wizard. Its documentation confirms that the system calculates estimated capacity during creation, but it does not publish a specific 4TB-plus-8TB-plus-16TB result. The official guide to ZimaOS RAID and JBOD options should therefore be used alongside the estimate shown on the actual device.
With CasaOS, the drives can remain independent, but presenting them as one protected storage pool requires additional Linux configuration. The final capacity and failure behavior depend on the tools chosen rather than CasaOS itself.
What Native Parity Actually Buys You
Unraid's main advantage in this comparison is not simply that it recognizes drives of different sizes. Its advantage is the combination of mixed-capacity data disks, shared folders, dedicated parity, and a graphical management workflow.
With single parity, the array can reconstruct one failed disk. With dual parity, it can reconstruct up to two simultaneous disk failures. The parity disks must meet the size requirements of the largest data member, and replacing a failed disk still requires a healthy remaining array and valid parity information. The official procedure for adding data and parity disks to an Unraid array documents these constraints.
Because the data disks retain individual filesystems, files are not divided into blocks across every array disk. If failures exceed the available parity protection, data on healthy disks may remain individually accessible. That is a useful fault boundary, but it is not a guarantee against filesystem corruption, controller failures, accidental deletion, malware, or multiple simultaneous disk losses.
What a Polished Storage Interface Cannot Change
ZimaOS makes storage creation approachable. Its interface can guide users through selecting disks, choosing a supported RAID mode, estimating capacity, creating the array, and monitoring its state. This reduces setup friction for users who do not want to administer Linux storage entirely from a terminal.
The interface does not, however, remove the underlying tradeoffs of the selected storage model. RAID 0 offers performance and capacity without redundancy. RAID 1 mirrors data. RAID 5 provides single-disk fault tolerance, while RAID 6 provides dual-disk fault tolerance. JBOD prioritizes capacity flexibility but supplies no parity or mirroring.
Recovery workflows should also be tested before important data is committed. An open ZimaOS beta RAID repair issue documented a virtual-machine test in which a slightly larger replacement disk was recognized but could not be used to start a RAID 5 repair through the interface.
This report does not prove that every current ZimaOS installation has the same limitation. It is a single beta-era case, but it illustrates why a storage interface should be evaluated by its replacement and recovery workflow as well as its initial setup wizard.
When a Simple App Dashboard Becomes a DIY Storage Stack
CasaOS is attractive when the primary goal is to deploy applications, manage Docker containers, and expose already mounted storage through a clean interface. It becomes less straightforward when the requirement changes to a parity-protected pool built from mismatched disks.
One common Linux-based design combines MergerFS and SnapRAID:
- MergerFS presents directories from multiple filesystems through one merged mount point.
- SnapRAID calculates parity across separate data disks and can help recover from the number of failures covered by the configured parity disks.
- CasaOS runs applications and exposes the resulting mount point after the storage layer has been configured.
MergerFS can pool filesystems of different sizes and types without requiring every disk to be reformatted into a striped array. A failed disk generally affects files stored on that filesystem rather than distributing every file across the entire pool. MergerFS itself does not provide parity or rebuild failed data.
SnapRAID supplies the missing parity layer, but it is not identical to Unraid's array protection. SnapRAID parity is updated when synchronization runs. Files added or changed after the most recent sync may not yet be recoverable, making the design better suited to media libraries and archival data than databases, active virtual-machine disks, or frequently changing application data.
The DIY route can be inexpensive and flexible, but the administrator becomes responsible for mount order, parity synchronization, scheduled scrubs, SMART monitoring, permissions, replacement procedures, and notifications. It is a reasonable engineering choice for an experienced Linux user, not a zero-configuration substitute for Unraid.
Expansion, Recovery, and Maintenance Matter More Than Day-One Setup
A storage system that is easy to create may still be awkward to expand or recover. Before choosing an operating system, consider what happens when the next drive is larger, when a disk begins reporting errors, and when the system disk itself must be reinstalled.
Adding capacity over time
Unraid is designed for incremental expansion. A new data disk can be added without requiring every existing disk to match it, provided that it does not exceed the parity disk. If a larger data disk is needed, the parity disk may need to be upgraded first.
Conventional RAID and ZFS expansion depend on the exact array or vdev design. Adding one mismatched disk does not necessarily make all of its capacity immediately usable. ZimaOS users should confirm the estimated capacity and supported expansion procedure before creating the original pool.
CasaOS can inherit flexible expansion from MergerFS because another mounted filesystem can be added to the pool. If SnapRAID supplies protection, parity sizing and synchronization must also be updated manually.
Recovering from failure
Unraid provides the most integrated recovery path of the three for this specific mixed-drive use case. ZimaOS provides graphical RAID status and repair controls, but the workflow depends on the chosen RAID type and current software behavior. CasaOS recovery depends almost entirely on the underlying Linux storage design.
None of these approaches eliminates the need for tested backups. A recovery plan should identify which files are backed up, where encryption keys and configuration files are stored, and how the system will be restored if more disks fail than the parity or RAID level can tolerate.
Which Setup Fits Your Mixed-Drive NAS?
| Your priority | Best fit | Why |
| Reuse several differently sized drives with parity | Unraid | Native mixed-capacity array, dedicated parity, and incremental expansion |
| Use a polished interface with conventional RAID | ZimaOS | Graphical RAID/JBOD setup and approachable application management |
| Build a simple NAS from recycled hardware | ZimaOS or CasaOS | Lower entry cost and lightweight home-server workflows |
| Run Docker applications over independently managed storage | CasaOS | Simple application dashboard over Debian or Ubuntu |
| Create a free, highly customized mixed-drive pool | CasaOS with Linux storage tools | Flexible, but requires manual administration and testing |
| Avoid paid licensing | CasaOS | Open-source application layer, with storage managed separately |
A recent hands-on test of Unraid and ZimaOS similarly characterized Unraid as a balance between advanced NAS functions and an accessible interface, while finding ZimaOS especially approachable for beginners and recycled hardware.
That comparison is useful as first-person experience rather than proof of storage architecture. Official documentation should remain the primary source for parity limits, RAID support, capacity calculations, and recovery procedures.
Licensing may also affect the decision. As of July 2026, Unraid's entry license starts at $49, while its lifetime tier costs substantially more. ZimaOS offers a free tier limited by disk count and a lower-cost lifetime Plus license. CasaOS is free and open source, but a DIY administrator may spend more time building and maintaining the storage layer.
Before You Reuse a Box of Old Drives
Mixed-drive support does not make aging disks equally reliable. Before creating any array or pool:
- Back up every file already stored on the drives.
- Review SMART data and run extended drive self-tests.
- Check for reallocated, pending, or uncorrectable sectors.
- Confirm that SATA, USB, and power connections remain stable under load.
- Use the largest healthy drive for parity when building an Unraid array.
- Record drive serial numbers and physical bay locations.
- Test failure notifications and the replacement procedure.
- Keep a separate backup of critical files after the NAS is operational.
Drives with different rotational speeds can coexist, but the slowest disks involved in a workload may limit performance. USB enclosures and port multipliers can also complicate drive identification and error recovery, so direct SATA or reliable HBA connections are preferable for a permanent NAS.
Frequently Asked Questions
Can I add a larger drive later without rebuilding the entire NAS?
Unraid generally allows another data disk to be added without rebuilding all existing data disks, but the new disk cannot be larger than the parity disk. If it is larger, upgrade the parity disk first. ZimaOS expansion depends on the selected RAID or ZFS layout. A CasaOS system using MergerFS can add another filesystem to the pool, but parity configuration and synchronization may need to be updated separately.
Is a paid OS worth it if I already own mismatched hard drives?
It can be. The value of Unraid is not only its interface; it can preserve more useful capacity from differently sized data disks while providing an integrated parity and expansion workflow. If the license costs less than replacing several healthy drives with matching models, it may be economically reasonable. Users with matching disks or strong Linux skills may prefer ZimaOS, CasaOS, or another storage platform.
Can CasaOS use MergerFS and SnapRAID for mixed drives?
Yes, because CasaOS runs over Linux and can expose a storage pool created with other Linux tools. MergerFS can combine mounted filesystems into one directory tree, while SnapRAID can add scheduled parity protection. Configuration, monitoring, synchronization, scrubbing, and recovery remain manual responsibilities, and frequently changing application data may require a different protection strategy.
Final Takeaway
Choose Unraid when the central requirement is a parity-protected NAS assembled from drives of different capacities and expanded one disk at a time. Its license adds cost, but its storage model directly addresses the mixed-drive problem.
Choose ZimaOS when ease of use, attractive storage controls, application deployment, and lower licensing cost matter more than extracting the maximum protected capacity from a mismatched collection. Check the capacity estimate and replacement workflow for the exact RAID configuration before moving important data.
Choose CasaOS when you primarily want a simple application dashboard and are comfortable treating storage as a separate Linux engineering project. MergerFS and SnapRAID can produce a capable mixed-drive system, but they add operational work and should not be presented as a native equivalent to Unraid.
Product Comparisons
PCIe vs USB Expansion: Which Fits a Beginner Home Server?
PCIe suits managed primary storage, while USB works well for backups and simple expansion when device compatibility and power are verified.
Silent Home Server vs High-Performance Mini PC for 24/7 Services
Silent servers suit light always-on services; performance mini PCs fit sustained compute, transcoding, VMs, NVR, and local AI.
8K Footage Archive vs Editing Cache: What Belongs on a Creator NAS?
Keep irreplaceable footage on protected NAS storage, localize latency-sensitive cache, and place active media by measured throughput.
