A local document assistant needs no dedicated VRAM when generation runs remotely or on a separate inference server. For same-machine inference, 8GB is a practical starting class for small quantized models, while larger models, longer context, and concurrency can push the requirement well beyond 16–24GB. Size the exact model and working context before buying because the RAG application itself does not define the VRAM requirement.
Decide Whether the Assistant Actually Needs a Local GPU
A document assistant has at least two layers: the application that stores files, chunks text, searches or retrieves passages, and presents answers; and the model backend that performs generation. Those layers do not have to run on the same hardware. A compact server can host the private document library and retrieval stack while sending model requests to another local GPU machine or a remote provider.
AnythingLLM's self-hosted documentation makes this separation explicit by allowing the application to connect to model and embedding services elsewhere. Its self-hosted requirements are therefore far lower than the hardware needed for a same-machine LLM.
If the requirement is “documents stay on my server” rather than “every model token must be generated on this server,” zero dedicated VRAM can be a valid purchase choice. You still need to verify what text leaves the machine, where embeddings are produced, how the remote model handles requests, and whether the privacy boundary matches the use case.
The first buying decision is architectural: remote or separate inference means size CPU, RAM, and storage for retrieval; same-machine inference means VRAM becomes a primary model-selection constraint.
Size the Model Weights Before Adding RAG Overhead
VRAM planning begins with the exact model and precision. Full-precision weights are much larger than 8-bit or 4-bit variants, which is why two users saying “I run a 7B model” can have very different memory requirements. Quantization can make a useful smaller model fit on mainstream hardware, but it may also change output behavior and should be evaluated with the document task.
Hugging Face documents that quantization reduces memory and compute costs by representing weights and activations with lower-precision data types and supports common 8-bit and 4-bit paths. That makes precision a buying variable, not merely a software toggle applied after hardware is chosen.
As a rough current planning rule, 4-bit 7–8B-class models often fit in the 6–8GB range, 13–14B-class models commonly move toward about 10–12GB, and 27–32B-class models often need roughly the low-20GB range before extra context headroom. Spheron's 2026 VRAM sizing guide gives similar INT4 planning figures and explicitly adds runtime overhead beyond the weight estimate.
Do not buy exactly to the downloaded model-file size. Leave room for the runtime and the context state, then verify the actual model in the intended inference engine. A model that loads with a tiny test prompt can still fail or offload when the assistant receives a long retrieved context.
Context Length Can Change the VRAM Tier After the Model Fits
A document assistant often needs more context than a casual chatbot because retrieved passages, citations, system instructions, conversation history, and user questions are assembled into one request. The model weights may remain constant while the key-value cache and other request state grow with context length.
Ollama's current context documentation makes this trade-off visible: its default context length rises with available VRAM, from 4K below 24GiB to 32K at 24–48GiB and much higher at 48GiB or more. The exact defaults are runtime choices, but the purchasing lesson is that long-context document work consumes memory beyond the model weights.
Do not respond by maximizing context indiscriminately. Retrieval should select the smallest set of passages that answers the question, and chunking or reranking should remove irrelevant text before generation. A document assistant that requires every document to be stuffed into one prompt is using VRAM to compensate for weak retrieval design.
Move to the next VRAM tier when the tested model is accurate enough but real document prompts cause offload, out-of-memory errors, or unacceptable latency at the context length you genuinely need. If retrieval quality is poor before context reaches the model, fix the index and ranking first.
Budget Separately for Embeddings, Reranking, OCR, and Concurrency
The local LLM is not the only component that can use GPU memory. Some document assistants also accelerate embeddings, rerankers, OCR, speech transcription, or vision models on the same GPU. Running those models simultaneously can reduce the VRAM available to the generator even though each component fits when tested alone.
The ZimaSpace article on complete model memory footprint explains why runtime buffers and request state need to be considered beside checkpoint size. For a document assistant, retrieved context and parallel services add another layer of shared-memory pressure.
Concurrency also changes the answer. Two active users may need separate KV-cache state even when they share one resident model. A batch-oriented server can improve accelerator utilization, but it does not make per-request memory disappear. Measure the longest normal document query under the expected number of simultaneous users.
If the generator is the only GPU workload, you can size closer to its tested working set. If OCR, embeddings, reranking, and generation must overlap, either buy more VRAM, serialize heavy stages, or separate services across CPU and GPU resources. The cheapest choice is the one that preserves the required latency without paying for idle acceleration.
Use VRAM Tiers to Shortlist Models, Then Test Quality
A useful shortlist can be organized by what the document assistant must accomplish rather than by the largest model that fits. Around 6–8GB VRAM, start with small 7–8B-class 4-bit models and bounded retrieval. Around 12–16GB, you gain room for larger models, higher precision, or more context. Around 24GB, many 27–32B-class quantized models become practical with more working headroom. Roughly 40–48GB and above is the class where 70B-scale 4-bit models begin to become realistic without heavy offload.
SitePoint's 2026 local-LLM guide notes that a 7B Q4_K_M model can fit comfortably in about 6GB of VRAM. Other current sizing guides place 14B and 32B quantized models higher, which reinforces the rule that the tier follows the exact checkpoint rather than a generic “AI PC” label.
Build an evaluation set from your own documents before buying the next tier. Include questions that require exact extraction, multi-passage synthesis, refusal when the source is missing, tables or structured text if relevant, and the longest context you expect. Compare answer quality, citation behavior, first-token latency, generation speed, and peak VRAM.
Buy more VRAM when the smaller model fails because model capability or context capacity is genuinely insufficient. Do not upgrade because a larger checkpoint exists. Retrieval can make a smaller, faster model more useful for a bounded private knowledge base than a slower model with weak grounding.
Keep the Storage-and-Retrieval Host Separate From the VRAM Decision
A document assistant also needs persistent storage for original files, extracted text, indexes, application databases, logs, and backups. Those assets usually consume system RAM and disk capacity rather than GPU VRAM. Combining every resource into one “AI memory” number creates bad hardware decisions.
The ZimaSpace overview of a private AI assistant on NAS describes the retrieval-first role of local files. That architecture lets the storage system remain stable even when the inference hardware changes later.
ZimaBoard 2 1664 is appropriate when the compact server's job is document storage, indexing, applications, and orchestration while the LLM runs remotely or on a separate GPU machine. Its integrated Intel graphics should not be treated as dedicated LLM VRAM.
Choose the storage host from document volume, backup, application memory, and network needs. Choose the accelerator from the exact model, quantization, context, and concurrency. Keeping those decisions separate lets you upgrade the GPU without rebuilding the authoritative document store.
Verify Any Same-Box GPU Configuration Before Buying
If you want storage, retrieval, and local generation in one enclosure, the final purchase check is the exact GPU memory available to the runtime. Product names such as “AI,” “Creator,” or “RTX” do not state whether the selected local model will fit. VRAM, driver support, container access, power, cooling, and physical expansion must all be verified.
The current ZimaCube 2 Creator Pack is the Zima option to evaluate when a buyer wants multi-bay storage and a dedicated NVIDIA GPU in the same system. The live product page identifies the GPU family but does not publish a VRAM figure in the main specification text, so do not map it to an 8GB, 16GB, 24GB, or 48GB model tier until the exact installed GPU memory is confirmed.
Before checkout, run or request a representative model test whenever possible. Record peak VRAM with the normal quantization and context, then repeat with the assistant's embeddings, reranker, OCR, or other GPU services active. Confirm that the runtime actually uses the intended GPU rather than silently offloading layers into system memory.
The final rule is to buy VRAM for the validated working set, not the marketing category. Use zero dedicated VRAM when inference can live elsewhere; start around 6–8GB for small quantized local models; move toward 12–16GB for larger models or more headroom; and consider 24GB or higher only when the tested document workflow proves that model size, context, or concurrency needs it.
Does RAG reduce the amount of VRAM I need?
RAG can let a smaller model answer from retrieved evidence instead of relying on a larger model's internal knowledge, which may reduce the model tier you need. Retrieved passages still consume context memory, so poor retrieval that sends excessive text can increase VRAM pressure.
Do embeddings require the same VRAM as the chat model?
No. Embedding models have their own CPU, RAM, or GPU footprint and can run on CPU or a separate service. If embeddings and generation share one GPU, measure their combined peak rather than adding model-file sizes on paper.
Buying Guide
How to Translate CPU, RAM, and IOPS Specs Into Plex Performance
A Buying Guide for turning Plex workload measurements into minimum CPU, RAM, storage, and network requirements without overbuying.
How to Shortlist Home Servers for Plex Using Weighted Criteria
A reproducible Plex buying matrix that separates mandatory gates from preferences and exposes uncertainty before purchase.
What Support and Upgrade Lifecycle Should a Plex Server Provide?
A pass-or-fail buying framework for Plex server support, update history, compatibility, repairability, costs, and migration readiness.
