Jellyfin RAM needs grow with the active working set and the rest of the host, not in direct proportion to the number of terabytes in the media library. For a dedicated Linux Jellyfin server, modest memory can be enough; more users matter mainly when they increase concurrent sessions, transcode buffers, cache activity, or companion services that are active at the same time.
Start with enough memory for the operating system, Jellyfin, and the services that are genuinely always on, then validate the busiest normal period. Add RAM when the active working set creates sustained pressure, harmful reclaim or swap, or OOM events; do not turn an 8GB, 16GB, or 32GB tier into a universal Jellyfin rule.
Library Capacity Is Not the RAM Budget
A 40TB library can Direct Play from disk while using modest RAM, whereas a much smaller server running Jellyfin, download automation, photo indexing, VMs, and memory-backed transcodes may need far more. Count active services and peak overlap before turning storage capacity into a memory estimate.
Current Jellyfin sizing examples increase memory mainly as the surrounding workload becomes more demanding, which is the useful lesson: treat published tiers as examples, then verify the complete host rather than multiplying RAM by library size.
List the containers and VMs that are always on, the heaviest normal scan or transcode activity, and the maximum concurrent household sessions. That is the workload the RAM budget must survive.
User Count Matters Only When Workloads Overlap
Adding an account by itself consumes little. Adding simultaneous playback, different client paths, subtitle processing, downloads, and concurrent background tasks changes the active working set. The important number is not registered users but what the busiest few users cause at the same time.
A media stack can expand quickly beyond the server itself. This home NAS media-app stack shows how Jellyfin commonly sits beside request, indexer, subtitle, and download services that each consume their own memory.
Test peak playback with the normal companion containers left on. If Jellyfin is stable alone but the host swaps or kills processes only when the stack overlaps, size the shared host rather than blaming the user count.
Linux Cache Makes โUsed RAMโ a Bad Buying Trigger
Linux intentionally uses otherwise idle memory for filesystem cache, so a host can show high used memory while still having healthy reclaimable capacity. Buying more RAM simply because the free column is small can waste money.
Linux filesystem cache is reclaimable when applications need memory. Watch available memory, swap, memory pressure, and OOM behavior instead of expecting an idle server to return most RAM to a visually โfreeโ state.
Measure after the system has warmed up and again during the busiest normal period. A healthy cache-heavy host is different from a machine that must reclaim constantly or push active pages into swap to keep Jellyfin responsive.
Containers Need Headroom Above Their Non-Reclaimable Working Set
If Jellyfin runs with a cgroup or Docker memory limit, total usage includes multiple memory types. Anonymous application memory, file cache, shared memory, and kernel charges do not have the same reclaim behavior, so one percentage can hide whether the limit is actually dangerous.
A container memory breakdown separates anonymous memory from reclaimable file cache and recommends looking at cgroup pressure and OOM signals rather than one total usage number.
Do not set a limit so close to the settled baseline that a library scan, plugin task, or second stream has no burst room. Conversely, do not double the limit after one cache-heavy reading if available host memory remains healthy.
Temporary RAM Storage Can Change the Budget Quickly
A tmpfs transcode directory or other memory-backed scratch path consumes real system RAM and can turn an otherwise comfortable server into a memory-pressure problem. Its peak depends on file size, concurrent conversions, seeking, and cleanup behavior.
If you use RAM-backed transcodes, measure the maximum observed working set and include that amount separately from Jellyfin process memory. A disk-backed SSD scratch path may be a better trade when predictable memory headroom matters more than avoiding temporary writes.
Upgrade Only When Memory Pressure Is Repeatable
| Observed signal | Interpretation | RAM response |
| Low free RAM, high available RAM, no swap pressure | Healthy cache use | No upgrade from this signal alone |
| Available RAM collapses during normal peak | Working set near capacity | Add headroom or reduce concurrent services |
| Repeated swap/reclaim stalls | Memory pressure affects latency | Increase RAM or lower the active working set |
| Container OOM / exit 137 | Limit or host memory is insufficient | Fix limit, leak, or capacity after diagnosis |
| New VMs or heavy services planned | Non-Jellyfin growth | Size the host for the combined peak |
When the host is containerized, watch pressure and cgroup events before changing the DIMM budget. A cgroup v2 workflow exposes memory.high, memory.max, PSI, and OOM counters, which makes persistent pressure easier to distinguish from a large but healthy cache footprint.
The ZimaSpace analysis of Jellyfin capacity by concurrent workload uses the same principle: user count matters only after it is translated into active resource demand and the first resource that loses margin.
Choose the smallest RAM tier that keeps the measured busy window healthy and leaves a realistic upgrade path. More memory is useful when it prevents real pressure or supports planned co-hosted work; it does not make incompatible clients Direct Play or fix a weak transcode engine.
Buying Guide
