Hardwareanforderungen für Transmission: CPU, RAM, Speicher und Netzwerk
Erfahren Sie mehr über die Hardwareanforderungen von Transmission an CPU, RAM, Speicher, Peers, Festplatten-I/O und Netzwerk sowie über die Hardwareauswahl für ZimaOS zum Herunterladen und Seeden.
Transmission hardware requirements at a glance
Transmission does not publish a numerical minimum CPU or RAM requirement for a Linux server. For ZimaOS, the useful sizing variables are the number of loaded and active torrents, peer connections, concurrent downloads and seeds, verification workload, download-disk behavior, target network speed and other services sharing the host.
No official numerical minimum is published. Transmission provides a headless transmission-daemon specifically for servers and routers, but CPU demand still rises with higher transfer rates, more peers, verification and other workloads running on the same system.
No official numerical minimum is published. Do not confuse Transmission's documented 4 MiB memory-cache setting with a total RAM requirement. Size memory for the operating system, Transmission session scale, peer activity and co-hosted ZimaOS applications.
Transmission publishes no fixed capacity requirement because the downloaded and seeded payloads dominate storage needs. HDDs are appropriate for large bulk libraries; SSD or NVMe can help when high transfer rates, verification, many small files or other applications create heavier random I/O.
Transmission publishes no minimum internet speed. Its current configuration defaults include peer port 51413 and RPC port 9091. Real throughput is limited by peer availability, WAN speed, router/NAT behavior, storage performance and the server's ability to process the connection load.
GPU
A dedicated GPU is not required for normal Transmission downloading, seeding, RPC or WebUI workloads. CPU, RAM, storage I/O and network capacity are the relevant hardware resources.
Best Zima starting point
Start with ZimaBoard 2 832 for a personal downloader or seedbox with one or two attached drives and light additional services. Choose ZimaBoard 2 1664 for more application and session memory headroom, or ZimaCube 2 when integrated multi-drive capacity, heavier I/O or faster whole-NAS networking becomes the real requirement.
Transmission sizing works best when you separate software compatibility from workload capacity. The application can run headlessly on modest server hardware, but the storage, network and concurrency around it can be much larger than the daemon itself.
    Treat Transmission's official documentation as a software and configuration baseline rather than a numerical hardware minimum. The project supports a headless transmission-daemon for servers and routers and does not publish a fixed CPU or RAM floor for Linux server deployments.
    Estimate session and connection scale. Current official configuration defaults are 200 peers globally, 50 peers per torrent and five non-stalled simultaneous downloads. The seed queue is disabled by default; when enabled, its default queue size is 10. Increasing these values can increase connection, CPU, memory and I/O pressure.
    Size storage for both capacity and behavior. Frequent downloading, verification and many small files can create more random disk activity than long-term seeding. Transmission 4.1.x documents a small memory cache that batches disk I/O, while the 4.2 RPC specification says that memory-cache setting is being removed, so hardware planning should not depend on a large Transmission-specific RAM cache.
    Install Transmission from the ZimaOS App Store, map persistent configuration and download paths, then test actual download, upload, seeding, verification and WebUI responsiveness while the other ZimaOS services you expect to run are active.
  • Number of torrents loaded in the session
  • Number of simultaneous active downloads
  • Number of simultaneous active seeds
  • Global and per-torrent peer limits
  • Expected WAN download and upload throughput
  • Download and seed drive type, capacity and filesystem
  • Frequency of full verification or recheck operations
  • Typical file count and whether torrents contain many small files
Transmission's current official download and project documentation does not publish a numerical minimum processor speed or RAM capacity for a Linux server. The authoritative facts are platform support, headless-daemon support and configurable concurrency. These are software baselines, not guaranteed throughput targets.
Transmission official downloads
For ZimaOS, do not invent a 1 GB, 2 GB or 4 GB 'official minimum.' Start from the supported headless daemon and size the real server around torrent and peer scale, concurrent activity, storage I/O, WAN bandwidth, verification and other applications on the machine.
CPUNo numerical minimum publishedThe official project supports a headless daemon for servers and routers but does not specify a minimum CPU model, core count or clock speed for Linux server use.
RAMNo numerical minimum publishedTransmission does not publish a total-RAM minimum for the daemon. Process memory should not be inferred from the separate disk-cache setting.
Server modetransmission-daemon with RPC and WebUI supportOfficial headless documentation describes transmission-daemon running in the background and accepting RPC/Web requests on TCP port 9091 by default.
Current stable release contextTransmission 4.1.3 on the official download pageThe current download page lists Linux/Unix source, Docker, NAS and embedded-system resources. macOS builds require macOS 11 or later; the main Windows build requires Windows 10 or later, with Qt5 packages still offered for Windows 7 or later.
Default peer and queue settings200 peers global; 50 per torrent; 5 active downloads by defaultThese are current configuration defaults, not hardware ceilings. The seed queue is disabled by default; if enabled, its documented default size is 10. Higher concurrency can increase resource pressure.
Network portsPeer port 51413; RPC port 9091 by defaultTransmission publishes no minimum broadband speed. Actual transfer rate depends on remote peers, WAN service, NAT/router behavior, storage and host resources.
Memory cache4 MiB documented default in current configuration; not a RAM requirementThe cache batches disk I/O. Transmission's RPC specification states that the memory cache is being removed for 4.2.0 and the setting will be deprecated, so do not size server RAM from this value.
Upgrade Transmission hardware only when a measured workload crosses a real CPU, memory, storage or networking boundary. A larger torrent library by itself does not automatically require an expensive server.
Torrent and peer concurrency is becoming large
Verification or downloading is saturating the storage path
Transmission shares the server with heavier ZimaOS services
More simultaneously active torrents and peers increase socket activity, protocol work and bookkeeping. Transmission exposes global and per-torrent peer limits as well as download and seed queues, so concurrency can often be controlled before hardware is replaced.
For long-running seedboxes, automation-heavy download stacks and users who keep many torrents active at once.
Full verification is deliberately able to pressure the storage subsystem; current Transmission settings even include a verification sleep control to reduce disk-I/O pressure. If the WebUI becomes sluggish or throughput collapses during heavy disk activity, storage layout and drive performance may matter more than adding CPU cores.
For large torrents, frequent rechecks, many-small-file workloads or fast internet connections writing to busy HDD pools.
Backups, media servers, photo indexing, databases, containers and virtual machines compete for the same CPU, RAM, storage and networking. Upgrade when the combined workload is constrained, not because Transmission alone has a published high-end hardware requirement.
For multi-purpose home servers and NAS systems where Transmission runs beside several always-on services.
Transmission scales more cleanly when capacity, active-download I/O, session concurrency and networking are treated as separate resources. That lets you expand only the part that has become a bottleneck.
Keep configuration persistent and payload storage separate
In a containerized ZimaOS deployment, keep Transmission configuration persistent and map download locations explicitly. This protects settings and torrent state across application updates while letting the large payload library live on the drives chosen for capacity and I/O.
Use persistent app storage for configuration and appropriately sized HDD or SSD storage for downloads and seeds.
Use HDD for bulk capacity and SSD only where I/O justifies it
Long-term seeding is often capacity-oriented, while downloading, verification and many-small-file torrents can create more random access. SSD or NVMe is useful when measurement shows the disk is the bottleneck; it is not an official Transmission requirement.
Large HDD pools fit archival seeding; SSD/NVMe can serve active downloads or other latency-sensitive apps when needed.
Tune concurrency before buying more hardware
Transmission provides explicit peer and queue controls. Reducing the global peer limit, active download queue or active seed count can lower resource pressure on a small server, router and storage pool without changing the machine.
Use configuration limits to match the workload to the hardware, then upgrade only if the required concurrency still exceeds the measured capacity.
Upgrade networking only when the rest of the path can use it
A 2.5GbE or 10GbE interface does not make an internet torrent faster when the WAN, peers or storage are slower. Faster LAN is most useful when completed data is also moved to other workstations, NAS pools or backup targets at high speed.
Match Ethernet speed to actual WAN and local-transfer requirements rather than using link speed as a torrent-performance guarantee.
Transmission is available in the ZimaOS App Store. The practical ZimaOS setup is a persistent container configuration plus explicit download storage, followed by connectivity and throughput tests using the real torrents and network path you expect to use.
Use the ZimaOS App Store package to deploy Transmission and open its WebUI. Transmission's own project supports headless daemon and remote Web/RPC management, which matches an always-on NAS or home-server deployment.
Open Transmission in the ZimaOS App Store
Map persistent app data and download folders
ZimaOS Docker applications use container paths that are isolated from the host until storage is mapped. Keep Transmission configuration persistent and point download and incomplete locations at the storage pool intended to hold the actual payloads.
Understand ZimaOS Docker app paths
Verify RPC access, peer reachability and disk behavior
Transmission's daemon uses RPC/Web access and a BitTorrent peer port. Keep the management interface appropriately restricted, verify the peer port/NAT path, then test download, upload and verification while watching CPU, memory and disk responsiveness on the ZimaOS host.
Read Transmission headless usage guidance
Choose Zima hardware for your Transmission workload
Choose hardware from storage capacity, torrent and peer concurrency, verification and disk-I/O behavior, target transfer rate and other ZimaOS applications. Transmission itself does not create a dedicated-GPU requirement.
Is Transmission mainly a personal downloader or seedbox with one or two attached drives and moderate concurrency?
Yes — storage capacity and concurrency are moderate
Use ZimaBoard 2 as the compact starting point. Choose 8 GB or 16 GB from the entire server workload and desired headroom, not because Transmission publishes either number as a requirement.
  • Personal downloading and seeding with a small set of additional ZimaOS appsZimaBoard 2 832
  • More co-hosted services or additional memory headroom for a larger long-running sessionZimaBoard 2 1664
No — multi-drive capacity, heavier I/O or faster whole-NAS networking is the priority
Move to ZimaCube 2 for integrated multi-drive expansion and stronger general-purpose headroom. Pro is justified when the larger server also benefits from more CPU, RAM, SSD expansion or 10GbE; Transmission itself does not need the Creator Pack GPU.
  • Large multi-drive download and seeding library with ordinary home networkingZimaCube 2 Standard
  • Heavier concurrent services, faster storage workflows or a real 10GbE requirementZimaCube 2 Pro
These are workload-based ZimaOS recommendations, not official Transmission minimums or guaranteed torrent-count or throughput benchmarks. Results depend on Transmission version, settings, peer availability, WAN service, NAT/router behavior, torrent composition, filesystem, storage devices and other services on the host.
ZimaBoard 2 832 A compact personal Transmission server for downloading, seeding and a small number of additional ZimaOS services. Personal torrent use with one or two SATA drives, moderate concurrency and browser-based management on an always-on home server.
32 GB eMMC plus dual SATA 3.0 and PCIe 3.0 expansion; keep torrent payloads on appropriately sized attached storage
No dedicated GPU acceleration is required for Transmission. The useful resources are CPU, memory, disk I/O and network throughput.
8 GB is a ZimaBoard configuration, not an official Transmission minimum or a guaranteed torrent-count ceiling. Large active sessions, heavy verification or multiple co-hosted services should be measured for resource pressure. Get Now
ZimaBoard 2 1664 The same compact Transmission platform with more memory headroom for larger sessions and additional ZimaOS applications. Downloading and seeding beside backups, media tools, automation or other containers when 16 GB of system memory is useful to the combined workload.
64 GB eMMC plus dual SATA 3.0 and PCIe 3.0 expansion
No GPU acceleration is needed. The additional memory increases application headroom but does not make the internet, peers or storage faster by itself.
Choose the 1664 for memory and co-hosted-service headroom, not because Transmission officially requires 16 GB. Disk and network bottlenecks can still dominate real transfer speed. Get Now
ZimaCube 2 Standard A larger Transmission download and seed library that benefits from integrated multi-drive storage and more platform headroom than a compact two-drive server. Long-term seeding, large download archives, several active disks and additional storage or self-hosted services.
Intel Core i3-1215U
8 GB
No dedicated GPU is required for Transmission. The value here is the multi-drive storage platform and stronger general-purpose compute headroom.
The six-bay chassis increases capacity and storage-layout options; it does not guarantee a particular torrent count or internet transfer rate. Session scale and disk behavior still need measurement. Get Now
ZimaCube 2 Pro A Transmission server that is also a heavier multi-service NAS and can make practical use of more CPU, 16 GB RAM, expanded SSD capability or 10GbE. Large storage pools, heavy co-hosted services, high local data movement and network environments where 10GbE benefits the broader NAS workflow.
Intel Core i5-1235U
16 GB
256 GB system storage with six 3.5-inch drive bays and expanded SSD options
Transmission does not use the integrated graphics or a dedicated GPU as a torrent accelerator. Pro is justified by its CPU, memory, storage and networking headroom for the complete server workload.
10GbE does not make internet torrents faster when WAN service, peers or drives are slower. Choose Pro because the complete NAS workload can use the added resources, not for Transmission alone. Get Now
These answers separate Transmission's documented software behavior from practical ZimaOS hardware planning, so estimated recommendations are not mistaken for official minimum requirements.
How much RAM does Transmission need?
Transmission does not publish a numerical minimum RAM requirement for its Linux daemon. The correct amount depends on the operating system, number of torrents and peers, active transfers and other services sharing the host. Transmission's documented 4 MiB memory-cache default is a disk-I/O cache setting, not the application's total RAM requirement.
What CPU does Transmission require?
Transmission does not publish a minimum CPU model or clock speed for a Linux server. The official project includes a headless transmission-daemon for servers and routers, so modest x86 hardware can be appropriate for light use. Higher line rates, more peers, full verification and co-hosted applications create the reasons to buy more CPU headroom.
Can ZimaBoard 2 run Transmission?
Yes. Transmission is available in the ZimaOS App Store, and ZimaBoard 2 is an x86 server with an Intel N150, 8 GB or 16 GB RAM, dual SATA and dual 2.5GbE. Those configurations are well suited to a personal Transmission downloader or seedbox, but they should not be described as official Transmission minimums or guaranteed throughput levels.
Does Transmission need a dedicated GPU?
No. Normal downloading, seeding, torrent verification, RPC and WebUI operation do not require a dedicated GPU. Spend hardware budget on the storage capacity, disk behavior, memory, CPU and networking that the real server workload needs.
Should Transmission downloads use an SSD or HDD?
Transmission does not require an SSD. HDDs are a sensible choice for large, capacity-oriented download and long-term seed libraries. SSD or NVMe becomes useful when fast internet service, verification, many small files or several applications create enough random I/O to make the disk subsystem the bottleneck.
How many torrents can a Transmission server handle?
There is no official hardware-independent torrent-count limit that should be used as a purchasing guarantee. Current configuration defaults are 200 peers globally, 50 per torrent and five non-stalled active downloads, while the seed queue is disabled by default. Real capacity depends on how many torrents are active, peer counts, metadata and file layout, storage, network and available CPU and RAM.
Does the 4 MiB Transmission cache mean the server only needs a few megabytes of RAM?
No. The documented cache value is only a dedicated memory cache used to batch disk I/O; it is not the process's total memory footprint or a system-RAM requirement. Transmission's RPC specification also says this memory-cache setting is being removed in version 4.2.0, so it should not be used as a long-term server-sizing rule.
When should I choose ZimaCube 2 instead of ZimaBoard 2 for Transmission?
Choose ZimaCube 2 when integrated multi-drive capacity, a much larger seed library, heavier concurrent storage activity or several other always-on services matter more than compact size. Standard is the first multi-drive step; Pro is justified when the complete NAS can use more CPU and RAM, expanded SSD options or 10GbE. Transmission itself does not require the Creator Pack's dedicated GPU.
What sources and further reading informed this Transmission hardware guide?
Transmission's official download page establishes current platform and release information. The official GitHub repository confirms the headless server/router daemon, while the configuration, headless-usage and RPC documents define peer limits, queue behavior, ports, verification controls and the changing memory-cache behavior. ZimaOS sources confirm the Transmission App Store listing and container path model. Zima product pages are used only for the current hardware specifications of the recommended devices. No unofficial CPU or RAM number is promoted to an 'official minimum.'
  1. Transmission Downloads
  2. Transmission Official GitHub Repository
  3. Transmission Editing Configuration Files
  4. Transmission Headless Usage
  5. Transmission RPC Specification
