Vollständige Hilfe Hardwareanforderungen: RAM, CPU, Speicher & Helpdesk & Wissensdatenbank
Vollständige Planungshilfe für Hardware, RAM, CPU, Helpdesk-Konversationen, Postfächer, Wissensdatenbankinhalte, Speicher und praktische Empfehlungen für die Bereitstellung von ZimaOS.
Full Help hardware requirements at a glance
Size Full Help from verified upstream requirements first, then add headroom for workload and persistent data.
No numerical official minimum published in accessible official docs
No numerical official disk minimum published
Application stack
Official API docs expose a Laravel 5.7 Passport-powered authentication layer
Mail integration
Mailboxes support forwarding, IMAP, or POP3 inbound connections
Best Zima starting point
ZimaBoard 2 832 for a small helpdesk
Start with current upstream facts for Full Help, then size the real workload rather than copying generic container or app-store labels.
  • Agent count
  • Conversation volume
  • Mailbox count
  • IMAP/POP3 polling
  • Knowledge-base traffic
  • Attachments
  • Database/app backups
  • Current vendor runtime requirements
The accessible official Full Help public documentation does not publish a numerical whole-host CPU, RAM, or disk minimum.
Full Help developer API documentation
Third-party catalogs estimate low resource usage, but the SOP requires official evidence for official_minimum. Those estimates are therefore excluded from the minimum claims.
No numerical minimum publishedHelpdesk workload dependent.
No numerical minimum publishedNo official current host-RAM figure found.
No numerical minimum publishedAttachments/history determine growth.
Laravel 5.7 PassportConfirms application framework component, not a host minimum.
Forwarding, IMAP, or POP3 inbound optionsMail integrations affect background workload.
Path, subdomain, or custom-domain sitesPublic help-center traffic varies.
Not requiredNo GPU workload is documented.
Conversation/mail growth
Attachment growth
Runtime uncertainty
SSD app/database state
Keep application and database state on SSD.
SSD
More RAM
Useful for more agents and mailbox processing.
ZimaBoard 2 1664
Attachment capacity
Expand storage for support files and KB assets.
ZimaCube storage
Backup capacity
Protect database/config/assets with tested backups.
External backup
Verify the current licensed installer requirements
The public developer docs do not expose a current complete runtime/system-requirements page.
Open Full Help developer docs ↗
Zima hardware for Full Help
Full Help should be sized by actual helpdesk usage and the runtime shipped with the licensed/current release.
Choose by workload
Small support team
ZimaBoard 2 832 is a practical provisional starting point, pending verification of the current licensed runtime requirements.
More agents/conversations/attachments
Scale CPU/RAM and storage based on measured helpdesk workload.
Because official public system requirements are incomplete, the JSON intentionally avoids inventing CPU/RAM minima.
ZimaBoard 2 832 Light self-hosted services and small databases Single-app or small multi-app workloads
PCIe expansion; no discrete GPU
8 GB RAM can limit larger CRM, mail, database, or platform stacks Get Now
ZimaBoard 2 1664 Memory-heavier self-hosted services Moderate multi-container and database workloads
CPU remains the 4-core N150, so heavy build/search/CRM workloads can still be CPU-limited Get Now
ZimaCube 2 Standard Storage-heavy file, mail, attachment, and archive workloads Large persistent data sets
Intel Core i3-1215U
8 GB RAM
256 GB system storage, 6 HDD bays, SSD expansion
Storage and PCIe expansion
8 GB RAM is less suitable for memory-heavy multi-service stacks Get Now
Does Full Help publish an official RAM minimum?
No numerical whole-host RAM minimum was found in the accessible official public documentation.
Does Full Help publish an official CPU minimum?
No numerical whole-host CPU minimum was found in the accessible official public documentation.
What does the official API documentation confirm?
It documents Full Help's helpdesk API, OAuth authentication using Laravel Passport, mailboxes, accounts, and knowledge-base sites.
How can Full Help receive email?
Official mailbox docs describe forwarding, IMAP, and POP3 inbound connection modes.
Can I use third-party 512 MB or 1 GB estimates as the official minimum?
No. They are not vendor-published system requirements.
Can ZimaBoard 2 832 run a small Full Help instance?
It is a reasonable provisional starting point, but verify the current licensed installer/runtime requirements before production.
Does Full Help need a GPU?
No GPU requirement is documented.
What should drive upgrades?
Agent count, conversation volume, mail processing, attachments, knowledge-base traffic, and database growth.
This page uses Full Help's official developer and documentation pages; unofficial catalog estimates are deliberately excluded from official minimum claims.
