Erxes-Hardwareanforderungen: RAM, CPU, Speicher sowie MongoDB- und Redis-CRM
Planen Sie die Erxes-Hardware für RAM, CPU, MongoDB-Replikatsätze, Redis, Plugins und Uploads und erhalten Sie praktische Empfehlungen für die Bereitstellung von ZimaOS.
Erxes hardware requirements at a glance
Size Erxes from verified upstream requirements first, then add headroom for workload and persistent data.
No tested current official minimum published
Database
MongoDB replica set required
Cache/queues
Redis required and should be persistent with noeviction
Best Zima starting point
ZimaCube 2 Pro for a small serious deployment
Start with current upstream facts for Erxes, then size the real workload rather than copying generic container or app-store labels.
  • Concurrent users
  • MongoDB workload
  • Plugin count
  • Redis queues
  • Uploads
  • Automations
  • Logs retention
  • Backup/replica-set design
Current Erxes deployment documentation explicitly says the repository does not establish a tested minimum CPU, RAM, or disk size.
Current Erxes self-hosting documentation
Older Erxes documentation published fixed figures such as 2 GB RAM or 4-core/8 GB examples, but the current deployment guide supersedes that approach and instructs operators to budget the whole stack and measure staging.
No tested minimum publishedBudget all Node services, Redis, and DB workload.
No tested minimum publishedMeasure a staging deployment.
x86-64 Linux for core published imagesMost core images are amd64.
MongoDB replica set requiredPlugins use sessions/transactions.
Persistent Redis requiredUsed for queues, sessions, service discovery.
Nginx + HTTPSReference deployment publishes UI/gateway on loopback.
Not requiredNo GPU baseline.
Plugin/service growth
MongoDB pressure
Automation/upload growth
Fast DB/storage
Use SSD/NVMe for MongoDB and app state.
SSD/NVMe
More RAM
Useful for the multi-service stack and MongoDB/Redis.
16 GB+
Separate MongoDB
Move DB to dedicated/managed nodes as scale grows.
Dedicated DB
Stronger CPU
Useful for plugins, automations, gateway, and workers.
ZimaCube 2 Pro or stronger
Zima hardware for Erxes
Erxes is a multi-service CRM/experience platform, so a fixed home-server minimum would be misleading.
Choose by workload
Evaluation/small deployment
Use a strong single host and a properly configured MongoDB replica set.
Growing plugins/users/automation
Separate stateful services and scale based on observed bottlenecks.
Use current docs over older legacy deployment pages when values conflict.
ZimaCube 2 Pro CPU-heavier, database-heavy, and higher-concurrency services Larger CRM/helpdesk/mail/platform workloads
16 GB RAM
10GbE + 2.5GbE
Higher CPU throughput plus PCIe/SSD expansion
16 GB RAM can still be low for large enterprise stacks Get Now
What is Erxes's current official RAM minimum?
The current self-hosting docs state that no tested minimum has been established.
Does Erxes require MongoDB?
Yes, a MongoDB replica set.
Does Erxes require Redis?
Yes; Redis is used for queues, sessions, plugin lists, and service discovery.
Do older Erxes docs list hardware numbers?
Yes, but current self-hosting guidance no longer establishes a tested fixed minimum.
Can a single-node MongoDB replica set work?
Yes for evaluation, but it provides no redundancy.
Can ZimaCube 2 Pro run a small Erxes deployment?
It is a reasonable lab/small-deployment starting point, but production should be validated with staging metrics.
Does Erxes need a GPU?
No baseline GPU requirement is published.
When should MongoDB move off-host?
When database memory, I/O, availability, or backup needs justify separate nodes.
This page uses current Erxes self-hosting/operations docs and notes legacy documentation only where it conflicts with current guidance.
