Hardwareanforderungen für DeepSeek V4 Pro
Sehen Sie die praktischen Anforderungen an RAM, VRAM, Speicher, GPU, Quantisierung und Bereitstellung für die lokale Ausführung dieses Modells.
8B-Parameter Dicht 128K-Kontext L2 · Home Server
What Hardware Does This Model Need?
Start with a practical answer, not a theoretical minimum.
Requirement Minimum Practical Recommended
System RAM——
VRAM——
Storage——
Quantization——
GPU——
Context——
Model Specifications That Affect Hardware Requirements
Only the model properties that materially change memory, compute, or storage belong here.
Total Parameters—
Sets the baseline weight footprint.
Active Parameters—
Important for MoE compute demand and throughput.
Architecture—
Dense and MoE models have different memory and compute behavior.
Context Window—
Longer context increases KV-cache memory pressure.
Modalities—
Vision or audio components can add memory and compute overhead.
Reference Precision—
Quantized formats can lower practical local memory requirements.
Practical Hardware Requirements
One comparison matrix keeps CPU, RAM, GPU, VRAM, storage, and usage level together.
Minimum PracticalMinimum usable configuration
GPU
VRAM
Use
Heavy UseHigh-headroom configuration
GPU
VRAM
Use
How Quantization and Context Change Memory Requirements
Model memory is not one fixed number. Precision and context can move the same model into a different hardware class.
QuantizationWeight memory
BF16
HighestQuality first
Q8
HighHigh quality
Q5
MediumBalanced local use
Q4
LowerLowest practical tier
Context lengthRuntime memory pressure
ShortLow
Basic chat and short prompts.
MediumModerate
Coding, documents, lightweight RAG.
LongHigh
Large document and repository context.
MaxVery high
Do not assume maximum advertised context is practical on minimum hardware.
Important: loading the model into memory is not the same as running it comfortably at maximum context.
Practical Local Deployment Profiles
Turn the component table into complete systems matched to real workloads.
A
Profile AMinimum practical local deployment
RAM · accelerator · quantization · context · workload
Single user
Baseline workload
B
Profile BRecommended local deployment
Everyday use
Balanced headroom
C
Profile CHigh-headroom deployment
Long context
Concurrency
What Increases Hardware Requirements?
Meeting the baseline does not guarantee the same experience under every workload.
Hardware factorLong Context
KV cache grows with context and can become the dominant runtime memory cost.
Memory ↑
Hardware factorConcurrent Users
Parallel requests increase memory pressure and reduce per-user throughput.
Compute ↑
Hardware factorRAG & Agents
Embedding, reranking, tools, and auxiliary models consume additional system resources.
System load ↑
Hardware factorMultimodal Inputs
Vision or audio components add encoder memory and processing overhead.
VRAM ↑
Hardware factorCPU Offload
Offload can make a model fit when VRAM is limited, but generation becomes slower.
Latency ↑
Hardware factorRuntime Choice
Ollama, llama.cpp, MLX, and vLLM target different hardware and memory strategies.
Efficiency varies
Product decision
Is This Model a Good Fit for Zima Hardware?
The product recommendation must follow from the model's verified memory, accelerator, and workload requirements.
Good FitCompact local deployment is realistic.
Recommended class Zima-Heimserver-Konfiguration
Verwende die Konfiguration, deren RAM- und Accelerator-Reserven dem oben empfohlenen Profil entsprechen.
Explore compatible Zima hardware →
More Hardware Questions
This area is reserved for query fan-out questions that extend the page beyond the core hardware decision path.
Can this model run on 16GB RAM?
Demo placeholder: answer this with the verified quantization, runtime overhead, and realistic context assumptions.
What GPU is a practical match for this model?
Demo placeholder: map common VRAM tiers to full offload, partial offload, or unsuitable configurations.
Should I use Q4, Q5, or Q8 for this model?
Demo placeholder: answer based on the quality-memory tradeoff and the user's available RAM/VRAM.
Can multiple users share one local model server?
Demo placeholder: treat concurrency as a separate capacity-planning question rather than repeating the baseline requirement.
