Hardwareanforderungen für den Alby Hub: RAM, Speicherplatz, Betriebszeit und Backups
Erfahren Sie mehr über die Anforderungen von Alby Hub an RAM, Festplattenspeicher, Swap, einen 24/7-Betrieb, den Lightning-Port und Backups und wählen Sie anschließend passende ZimaOS-Hardware aus.
Alby Hub requirements at a glance
Alby Hub publishes deployment-specific resource guidance. The current Docker guide lists 512 MB RAM minimum with 1 GB recommended, 1 GB swap with 2 GB recommended on smaller servers, and at least 1 GB storage. Alby's current installation reference is more conservative for the default embedded LDK backend: 2 GB RAM, or 512 MB RAM plus 2 GB swap. When Alby Hub connects to an external Lightning backend, the Hub layer can be much lighter.
RAM - Docker
Current official Docker guidance: 512 MB minimum, 1 GB recommended.
RAM - embedded LDK
Current project installation reference recommends 2 GB RAM for the default internal LDK node, or 512 MB RAM plus 2 GB swap.
RAM - external node
When connected to an external Lightning backend, current project guidance says about 256 MB RAM can be enough for the Alby Hub layer.
At least 1 GB is the documented baseline. Keep Hub data, keys, logs and Lightning state on a persistent volume with additional recovery headroom.
Network / uptime
Alby Hub is intended to run 24/7. Current installation guidance says Lightning port 9735 should be reachable for optimal channel connectivity.
Best Zima starting point
ZimaBoard 2 832 already exceeds all current Alby Hub RAM guidance by a wide margin. Higher Zima tiers are for a broader Bitcoin/Finance/self-hosted stack, not Hub compute.
Alby Hub sizing starts with the Lightning backend and recovery model.
    Choose the backend first. The default embedded LDK node carries the higher memory recommendation, while Alby Hub connected to an external node can run with much less RAM.
    Plan an always-on deployment. Alby Hub is designed to stay online so connected apps, Lightning addresses and inbound payments can reach it; power and network reliability matter more than extra CPU cores.
    Persist the Hub data directory and secure the recovery phrase. Lightning application state, keys and logs must survive container recreation or storage replacement.
    Install Alby Hub from ZimaOS, verify the selected backend, Lightning connectivity, channel/backup status and a documented recovery procedure before placing meaningful funds on the node.
  • Embedded LDK versus external Lightning backend
  • 512 MB minimum / 1 GB Docker recommendation
  • 2 GB LDK conservative recommendation or swap strategy
  • At least 1 GB persistent storage
  • 24/7 power and network reliability
  • Lightning port 9735 reachability
  • 12-word recovery phrase stored offline
  • Channel-backup / recovery configuration
Alby Hub has explicit current resource guidance, but the figures differ by deployment/backend and should not be collapsed into one number.
Alby Hub Docker requirements
For a ZimaOS Docker deployment, 512 MB RAM is the current Docker minimum and 1 GB is recommended. For the default embedded LDK node, keeping roughly 2 GB available is the more conservative official target; external-node mode can be much lighter.
Docker RAM minimum512 MBCurrent Alby Hub Docker guide.
Docker RAM recommended1 GBCurrent Alby Hub Docker guide.
Swap1 GB minimum; 2 GB recommended on smaller serversCurrent Docker guidance.
Embedded LDK conservative RAM2 GB, or 512 MB + 2 GB swapCurrent project installation reference for the default backend.
External-node Hub RAMAbout 256 MBProject guidance when Alby Hub connects to an external Lightning node.
StorageAt least 1 GBPersist Lightning/application state and leave extra room for logs/backups.
Alby Hub rarely needs a faster CPU; reliability, backend choice and surrounding services drive upgrades.
The same host runs a broader Bitcoin/Lightning stack
Memory pressure appears on an embedded LDK deployment
Power/storage reliability is not good enough for a wallet node
A full Bitcoin node, external LND/CLN, explorers, databases and other services can consume far more storage/RAM than Alby Hub itself.
Users consolidating a sovereign Bitcoin/Lightning server.
If a small host relies heavily on swap, moving from the 512 MB edge case toward 1–2 GB real RAM reduces swap dependence and leaves more room for container/OS overhead.
Very small VPS/SBC deployments close to the documented floor.
A self-custodial wallet/node should prioritize persistent storage, backups and uptime. Replacing fragile storage or adding UPS/recovery can be more valuable than CPU upgrades.
Users holding meaningful Lightning/on-chain balances.
Scale Alby Hub by improving uptime and recovery before buying more compute.
Use real RAM instead of depending on swap when possible
Alby's Docker guide permits low-memory operation with swap, while the project installation reference gives a more conservative 2 GB recommendation for embedded LDK.
ZimaBoard 2 832's 8 GB RAM makes swap-based sizing irrelevant for a normal Hub.
Keep the work/data directory on reliable persistent storage
Alby Hub's Docker/project guidance requires a persistent volume because Lightning and application state are stored to disk.
Use reliable eMMC/SSD/SATA storage and include Hub state in a broader recovery strategy.
Back up the 12-word recovery phrase offline
Current Alby Hub recovery guidance instructs users to back up the recovery phrase; it is fundamental to wallet recovery.
Do not keep the only recovery phrase inside the same ZimaOS machine or backup volume.
Use channel backups/recovery features for Lightning state
Alby's current documentation distinguishes the recovery phrase from Lightning channel-backup mechanisms and offers encrypted dynamic channel backups for supported recovery scenarios.
A RAID array or larger NAS is not a substitute for the wallet's documented cryptographic/channel recovery process.
Alby Hub is currently listed in the ZimaOS App Store under Finance.
Size the Docker deployment from Alby's current guide
The current Docker guide gives 512 MB minimum / 1 GB recommended RAM, swap guidance and at least 1 GB storage.
Read Alby Hub Docker guidance
Treat backup/recovery as part of the hardware page
Because Alby Hub is a self-custodial wallet/node, a hardware recommendation is incomplete without an offline recovery phrase and a Lightning channel-recovery plan.
Read Alby Hub backup and recovery guidance
Choose Zima hardware for Alby Hub
Alby Hub is lightweight enough that ZimaBoard 2 832 already offers very large resource headroom. Reliability and recovery matter more than higher CPU tiers.
Is this a standalone Alby Hub or part of a larger Bitcoin/Finance server?
Standalone embedded-LDK or external-node Alby Hub
ZimaBoard 2 832 exceeds the documented Hub requirements by a wide margin.
  • Normal always-on Alby HubZimaBoard 2 832
  • Hub plus more Finance/network servicesZimaBoard 2 1664
Larger Bitcoin/Finance/storage platform
Move to ZimaCube only when other node/storage/backup services justify the larger platform.
  • Integrated Finance/Bitcoin storage serverZimaCube 2 Standard
Meeting the documented RAM/disk baseline does not guarantee payment availability or fund safety. Lightning liquidity, backend configuration, network uptime, recovery phrase/channel backups and software updates all matter.
ZimaBoard 2 832 A normal self-hosted Alby Hub with embedded LDK or external Lightning backend. 24/7 Lightning wallet/node connectivity, NWC apps and persistent Hub state.
No dedicated GPU is required.
8 GB RAM is far above Alby's current 512 MB–2 GB guidance; uptime, backups and storage reliability matter more. Get Now
ZimaBoard 2 1664 Alby Hub plus more Bitcoin, Networking and Finance services. A larger always-on sovereign-computing stack on one compact host.
16 GB is for surrounding services; Alby Hub itself does not require this memory tier. Get Now
ZimaCube 2 Standard An all-in-one personal cloud also running Alby Hub and larger backup/storage workloads. Finance apps, backups and other self-hosted services with multi-drive capacity.
Intel Core i3-1215U
8 GB
Choose ZimaCube for the wider server platform, not because Alby Hub needs a Core i3 or six drive bays. Get Now
FAQ topics follow query fan-out around 512 MB/1 GB/2 GB RAM, embedded LDK versus external nodes, swap, 24/7 uptime, port 9735 and wallet/channel recovery.
How much RAM does Alby Hub need?
For the current Docker deployment, Alby documents 512 MB minimum and 1 GB recommended. A separate current installation reference gives a more conservative 2 GB recommendation for the default embedded LDK backend, or 512 MB plus 2 GB swap.
Why do Alby Hub docs mention 512 MB, 1 GB and 2 GB RAM?
They describe different operating margins and deployment guidance. 512 MB is the Docker minimum, 1 GB is the Docker recommendation, and 2 GB is the more conservative recommendation for the internal LDK backend without relying on swap.
Does Alby Hub need less RAM with an external Lightning node?
Yes. Alby's project guidance says the Hub layer can use about 256 MB RAM when it connects to an external backend because the Lightning node itself runs elsewhere.
Does Alby Hub need to run 24/7?
Ideally yes. The official project says it should run continuously so connected apps, Lightning addresses and incoming payments can reach it.
Should port 9735 be open for Alby Hub?
Alby's current installation reference says Lightning port 9735 should be open and reachable for optimal channel connectivity. Exact networking still depends on backend and deployment.
Can swap replace RAM for Alby Hub?
Alby's documentation explicitly supports low-memory configurations with swap, such as 512 MB RAM plus roughly 2 GB swap for the default backend. On ZimaBoard 2 with 8 GB RAM, there is no reason to target that edge-case setup.
Is the 12-word recovery phrase enough to recover Alby Hub?
It is essential, but Lightning recovery deserves separate attention. Current Alby documentation distinguishes wallet recovery from channel-backup mechanisms and offers encrypted dynamic channel backups for supported recovery scenarios.
Can ZimaBoard 2 832 run Alby Hub?
Yes. Its 8 GB RAM is multiple times higher than even Alby's conservative embedded-LDK recommendation, and its always-on server form factor is a better fit than sizing around the minimum 512 MB case.
What sources and further reading informed this Alby Hub hardware guide?
Alby's current Docker and project installation documentation provides the 512 MB/1 GB/2 GB RAM, swap, disk and port-9735 guidance. The official repository confirms persistent SQLite/application state and backend differences. Current backup/recovery docs define the recovery-phrase and channel-backup model. ZimaOS confirms the current Finance app.
  1. Alby Hub - Docker
  2. Alby Hub Official Repository
  3. Alby Hub - Backups & Recover
  4. Alby Hub - How Can I Back Up My Keys?
  5. Alby Hub - ZimaOS App Store
