42links-Hardwareanforderungen: RAM, CPU, Speicher und Lesezeichen-Datenbank
Planen Sie die 42links-Hardware für RAM, CPU, Lesezeichenspeicher, das Abrufen von Favicons/Titeln und die Kontonutzung und geben Sie praktische Empfehlungen für die Bereitstellung von ZimaOS.
42links hardware requirements at a glance
Size 42links from verified upstream requirements first, then add headroom for workload and persistent data.
Bookmark data, notes, imported records, cached metadata, and backups
Runtime
Common Lisp application
Key workload
Multiple accounts + bookmark metadata + automatic 404 checking
Best Zima starting point
ZimaBoard 2 832
Start with current upstream facts for 42links, then size the actual workload rather than copying generic container or app-store labels.
  • Bookmark count
  • Account count
  • Import size
  • 404-check frequency
  • Metadata fetching
  • Backup retention
  • Reverse proxy
  • Other containers
The public 42links project page describes the application and its lightweight design but does not publish a numerical whole-host CPU, RAM, or disk minimum.
Do not invent a RAM/CPU minimum from the programming language or binary size. This is a lightweight web/bookmark workload.
No numerical official minimum publishedBackground metadata/link checks are the main CPU work.
No numerical official minimum publishedDepends on bookmark/account scale and host consolidation.
Self-hostable multi-account bookmarking serviceSupports a simple read-it-later workflow.
Common LispImplementation detail, not a hardware minimum.
Favicon/title fetching and automatic 404 checkingCan create periodic network/CPU activity.
Wallabag and standard bookmarks.html importsLarge imports may create temporary processing work.
Not requiredNo GPU workload.
Large bookmark imports
Account/bookmark growth
Host consolidation
SSD app data
Keep the bookmark database and application state on SSD.
SSD
More shared-host RAM
Useful only when many other containers share the machine.
ZimaBoard 2 1664
Backup capacity
Keep database/config backups outside the live app volume.
Backup storage
Stronger CPU only if needed
42links alone rarely justifies a larger CPU.
ZimaCube 2 Pro for wider stack needs
Keep backups simple
The project is lightweight; prioritize durable application data and tested backups over high-end hardware.
Open 42links code/docs ↗
Zima hardware for 42links
42links is a lightweight bookmark service, so ZimaBoard 2 832 is already a conservative practical starting point.
Choose by workload
Personal or small multi-account bookmark server
Use a low-power ZimaBoard and persistent SSD storage.
42links on a larger shared host
Scale for the rest of the application stack rather than for 42links itself.
No numerical official minimum is invented because the project does not publish one.
ZimaBoard 2 832 Light self-hosted services and small databases Single-app or small multi-app deployments
8 GB RAM and a 4-core N150 limit larger databases, AI stacks, and heavy multi-service workloads Get Now
ZimaBoard 2 1664 Memory-heavier services and larger multi-container stacks Workloads that benefit from 16 GB RAM without needing a much faster CPU
CPU throughput remains the same 4-core N150, so compute-heavy workloads can still be CPU-limited Get Now
How much RAM does 42links need?
The public project documentation does not publish a numerical whole-host RAM minimum.
How many CPU cores does 42links need?
No numerical official CPU minimum is published.
What is 42links used for?
It is a self-hostable bookmarking/read-it-later service with multiple accounts.
What background work does it do?
It can fetch bookmark favicons and titles and run automatic 404 checks.
Can it import existing bookmarks?
Yes. The project documents imports from Wallabag and standard bookmarks.html files.
Can ZimaBoard 2 832 run 42links?
Yes as a practical lightweight starting point.
Does 42links need a GPU?
No.
When should I use larger hardware?
Only when the broader shared host needs more resources.
This page uses the public 42links project page and code location plus current Zima hardware specifications.
