We want to extend a sincere thank you to Mini PC Builder for putting together such a thorough, hands-on showcase of our hardware. Your video perfectly captured the core philosophy behind our design, providing a comprehensive and engaging look at what we've been working so hard to build.
The Question Every Homelab Nerd Is Asking
For many homelab enthusiasts, traditional NAS setups can be costly and unnecessarily bulky. When Mini PC Builder released a video titled "Stop Buying Expensive NAS" and began unboxing our device, it highlighted a growing shift in how we approach home servers.
As the creator walked through the setup process—from the initial unboxing to a fully operational system—the takeaway was clear: a home server doesn't need to be a massive rack-mount system. It just needs to be efficient, reliable, and perfectly suited to your needs. This is exactly where ZimaBoard2 comes in.
What's in the Box (and Hardware Specs)
The unboxing sequence in the video shows exactly what we pack in: the board itself, power adapter, SATA cables, and all the little essentials to get you started. No mystery parts, no "sold separately" surprises. What you see is what you get.
At the heart of ZimaBoard2 sits the Intel N150 quad-core processor (up to 3.6GHz), paired with up to 16GB of LPDDR5 DDR5 memory and up to 64GB eMMC onboard storage. That's not "budget board" territory anymore — that's legitimate server muscle in a 140mm × 83mm footprint running at just 10W TDP.
The video also detailed the comprehensive connectivity options:
2× 2.5GbE LAN ports — for high-speed networking
2× SATA 3.0 6Gb/s ports — for direct drive connections
1× PCIe 3.0 slot — for advanced expansion
- 2× USB 3.1 + Mini-DisplayPort 1.4 (4K@60Hz)
Furthermore, the design is completely fanless, ensuring silent operation, making it suitable for any room in your home or office environment.
The Storage Playground
The video provided an excellent demonstration of the board's storage versatility. Mini PC Builder didn't just plug in one drive and call it a day — they explored multiple configurations, including:
- 2× 2.5" SATA SSDs for the clean NAS setup
- 2× 3.5" HDDs via a custom mounting bracket
- An NVMe M.2 drive through the PCIe 3.0 expansion slot
- External USB drives
- And the grand finale: a tower of 5× 2.5" SATA drives
As the screen flashed "Welcome to ZimaBoard2" during the demo, it felt less like a setup tutorial and more like a homecoming. That PCIe slot is where the magic truly lives — add a network card, throw in a GPU for AI edge computing, build a 6-port gateway for traffic control. The board is as hackable as you want it to be.
ZimaOS: Three Minutes to Your Personal Cloud
Once the hardware was set up, the video dove into ZimaOS — and this is where things get surprisingly friendly for first-timers. The creator showed the system initializing, account creation, and the full App Store rolling by like a buffet of self-hosted goodness.
As highlighted in the video: "ZimaOS: A Simplified, Focused and Open NAS OS" — and that's not marketing fluff. It genuinely takes about 3 minutes to get started, 3 steps to set up RAID storage, and exactly zero headaches to launch apps like:
| App | What It Does |
| Jellyfin / Plex | Your personal Netflix, no subscription needed |
| Home Assistant | Smart home command center |
| Nextcloud | Private Google Drive, on your terms |
| Docker | Because real homelabbers containerize everything |
| Transmission | Download station, always on, always ready |
The mobile app integration shown in the video is the cherry on top — manage your storage, check device status, and access your files from anywhere, all from your phone. It's the kind of "it just works" experience that providing a seamless and modern user experience.
It Also Doubles as a Local AI Lab
One of the most exciting things about ZimaBoard2 that the video touches on? That PCIe 3.0 slot doesn't just mean more storage. Slot in a compatible GPU and you've got a local AI inference machine — run Ollama, fire up Qwen models, build voice-activated assistants, generate images, or create multimodal content entirely on your own hardware. This ensures your data remains private and secure on your local network.
Because the system "Supports all X86-64 hardware", the possibilities for expansion and customization are extensive, giving developers and enthusiasts the freedom to build exactly what they need. When you're on X86 with PCIe, the possibilities really are endless.
Build Your Versatile Home Server with ZimaBoard2
Mini PC Builder wrapped it up perfectly: this thing punches way above its weight class. For under $200, you get a legitimate home server, a personal NAS, a Docker playground, a smart home hub, and a potential AI lab — all in a silent, palm-sized package powered by an OS designed to get out of your way and let you actually enjoy the experience.
Whether you're a seasoned homelab veteran or just beginning to explore network-attached storage, ZimaBoard2 meets you exactly where you are.
Ready to build yours?
Zima Campaign Hub
Local AI on the ZimaCube 2 — PCIe Expansion, Ollama, and Future-Proofing Your Homelab
ZimaCube 2 ships with 4× NVMe slots, a PCIe expansion slot, and DDR5 RAM — ready for Ollama, RAG pipelines, and Docker out of...
ZimaCube Home Lab Monitoring Guide: From Uptime Kuma to AI Agents
Monitor your home server with Uptime Kuma, Pulse, Proxmox Data Center Manager, or an AI agent to track uptime, backups, VMs, alerts, and avoid...
From Sparcstation to ZimaBlade: A 57-Year-Old Geek’s Self-Hosting Journey
A French admin professional replaced his failed Raspberry Pi 4 with a ZimaBlade 7700, running Debian 13, XFS, and BorgBackup. Full backup server build...
