Workload identity authenticates home AI services by binding short-lived cryptographic credentials to an attested process rather than a network address or stored password.
A local RAG API, model server, vector database, and agent tool gateway may share one home network while having very different privileges. Workload identity lets each process prove what approved service it is before receiving data or credentials. The verifier checks runtime evidence, issues a named identity, and leaves resource authorization to a separate policy decision.
Attestation Connects a Running Process to a Declared Identity
An identity agent observes verifiable runtime properties such as service account, executable, container image, namespace, host, or signed workload metadata. Registration policy maps an accepted combination to a stable service name rather than trusting a self-declared label.
A practical runtime workload attestation demonstration shows how SPIFFE and SPIRE attest workloads before issuing identities inside a homelab. The bootstrap trust sits in the node and registration process, not in a secret copied into every container.
This changes the first authentication question from “which IP connected?” to “which approved workload proved possession of this identity?” Dynamic addresses and container restarts no longer require a new static credential. This distinction remains visible during later household testing.
The Identity Authority Issues Short-Lived Verifiable Credentials
After attestation, an authority issues an X.509 or JWT credential containing the workload identifier and a limited lifetime. The local agent delivers it through a protected workload interface and rotates it before expiry. The intermediate result must remain inspectable before automation follows.
An overview of short-lived workload credentials explains that SPIFFE identities are short-lived and cryptographically verifiable, reducing dependence on hardcoded service secrets. The receiving service validates issuer, audience, time, and proof of key possession. That boundary should be measured separately under realistic operating conditions.
Short lifetimes narrow exposure after a service is removed or compromised. Rotation must remain automatic, because expired certificates should fail closed rather than encouraging operators to restore long-lived keys. The practical consequence appears when several sources compete for limited context.
Authentication Supplies Identity but Policy Grants Access
A valid workload identity proves which service is calling; it does not prove that the model server may read every collection or that an agent acts for a particular user. Authorization evaluates identity plus resource, operation, user delegation, and current policy.
An analysis of workload and agent identity distinguishes workload identity, mutual authentication, and the user or agent context carried above the connection. That separation prevents a trusted service certificate from becoming a universal capability. This dependency should remain explicit in the final interface.
The failure boundary is a compromised identity authority, node attestor, or registration rule. Cryptographic proof faithfully enforces the identity it was issued, even when the issuance policy mapped an attacker-controlled process to the wrong service.
Trace One Service Call From Attestation to Authorization
Choose a RAG-to-vector-store request and record workload selector, registered identity, issuer, certificate or token lifetime, key location, peer validation, requested resource, delegated user, policy decision, rotation, revocation, and audit identifier. The result must therefore be checked against the original evidence.
Compare the control with AI identity controls. Test a legitimate restart, copied credential, unregistered container, wrong audience, expired identity, changed service account, and valid identity requesting a forbidden collection. This distinction remains visible during later household testing.
Pass only when authentic workloads reconnect automatically and every impersonation or overreach fails at a named boundary. Protect the identity authority separately and keep resource authorization narrower than service authentication. The intermediate result must remain inspectable before automation follows.
