Jellyfin can behave differently after a restart because persistent data survives while mounts, devices, startup timing, network paths, and caches are rebuilt.
The library may still exist while the process sees a different device readiness state or starts before a dependency is available. A cold cache can also make the first request slower without changing the underlying catalog. Separate durable state from runtime conditions before treating the difference as corruption.
Persistent State and Runtime State Are Different
Configuration, database files, users, and library definitions can persist outside the container. Mounts, environment variables, device permissions, network identity, process timing, and in-memory cache are recreated each time.
The persistent data roles breakdown helps identify which behavior should survive a restart and which is expected to change.
A restart difference is therefore not automatically evidence that Jellyfin lost its library.
Startup Order Can Change the First Result
If storage, GPU devices, network mounts, or dependent services become ready at different times, Jellyfin may initialize against a partial environment. The same image can then produce a different startup path even though the configuration file is identical.
Compare the restart sequence with the post-upgrade analysis model pattern of runtime conditions being rebuilt around persistent data.
A later restart that restores normal behavior points toward timing or readiness rather than a permanently damaged database.
Cold Cache Makes the Service Feel Different
After a restart, database pages, artwork, directory entries, and transcode state may be cold. The first library open or stream can therefore be slower than a repeated request, while steady-state behavior returns after the working set is rebuilt.
Use the cold and warm benchmark method to compare first-run and repeated-run timing instead of judging the service from one cold request.
If only first-use latency changes, cache state is the likely boundary; if every request changes, inspect mounts, devices, or resource contention.
Classify the Difference Before Changing Data
Record what changed: library visibility, user state, playback mode, device acceleration, network reachability, or only first-request timing. Then compare the smallest runtime variable that could explain it.
The persistent data roles distinction between normal restart variation and a persistent-state failure keeps recovery work bounded.
Stop at the first condition that explains the observed difference. Rebuilding or deleting data without that classification can turn a runtime issue into a state-loss event.
