What Is Metric Cardinality, and Why Can AI Observability Become Expensive?
Metric cardinality is the number of distinct label combinations stored as time series, and unbounded AI labels can multiply resource use unexpectedly.
A latency metric looks harmless until it is labeled by model, route, user, tool, status, quantization, and raw request ID. Each observed combination becomes a separate series with indexing, memory, query, and retention costs. AI stacks produce many naturally unique identifiers, so observability expense can grow faster than request volume even on a self-hosted server with no cloud bill.
Every Distinct Label Set Creates Another Time Series
A metric name plus one complete set of label values identifies a series. Ten models, five routes, four statuses, and twenty tools can create thousands of possible combinations before any user or request identifier is added. The realized count depends on combinations actually observed, not merely the labels declared.
Prometheus label cardinality guidance guidance notes that every label set adds RAM, CPU, disk, and network cost and recommends investigating metrics whose cardinality becomes large. It specifically warns against labels with unbounded values such as user IDs or email addresses.
Cardinality is different from sample frequency. One series scraped every second may contain many samples, while one million rarely updated series still impose large index and metadata overhead because the backend must track each identity.
AI Workflows Contain Attractive but Dangerous Labels
Model name, endpoint, tool class, response status, and bounded hardware tier can support useful aggregation. Prompt text, document path, trace ID, session ID, generated tool arguments, and full error messages are effectively unbounded and turn metrics into an accidental event store.
Grafana cardinality dashboard explains that high-cardinality dashboards inspect active series and label distribution so operators can connect unused metrics to ingestion cost. The same method can reveal whether one new agent label caused a sudden series explosion.
Unique diagnostic context belongs in sampled traces or structured logs, linked through exemplars where supported. Metrics should answer aggregate questions with intentionally bounded dimensions rather than preserve every request as a label value. This distinction remains visible during later household testing.
Combinations Multiply Before Queries Become Visibly Slow
Several individually modest labels can form a large Cartesian product. Series churn makes the problem worse when containers, model versions, or normalized paths continually create new identities that remain in retention after the active workload changes.
A Grafana cardinality spikes example defines cardinality through distinct label values and shows how spikes increase the number of stored series. This explains why a small change in instrumentation can raise ingestion and query work without changing inference traffic.
The failure boundary is observability that consumes enough memory, I/O, or CPU to disturb the AI service it measures. Dropping a label after ingestion may reduce future growth but does not immediately erase historical series or repair dashboards that depended on it.
Build a Cardinality Budget Before Adding Labels
Inventory every metric and estimate the upper bound of each label and common combination. Replay a representative day, measure active series, series churn, bytes ingested, query time, and memory, then rank labels by diagnostic value and incremental series count.
Compare those results with the wider observability signals described in local AI observability. Move unique request context into logs or traces, normalize dynamic paths, and expose model or tool categories only when a dashboard or alert has a defined use.
Set budgets and alerts for active series and creation rate before deployment. The instrumentation passes only when it answers the target operational questions without materially changing inference latency or exhausting retention storage during peak household use.
