Plex can retain more temporary data than expected when cache, transcode output, logs, previews, or interrupted work outlives the request that created it.
Not every growing directory is a leak. Some data is reusable cache, some belongs to an active transcode, and some remains because cleanup did not run or another feature stores long-lived derivatives. Classify the path before deleting it so performance data is not confused with durable server state.
Cache Can Stay Warm After the Request Ends
A cache exists precisely so recently used data can remain available after the original request. High cache occupancy therefore does not mean the application still needs every byte immediately.
Memory can retain reusable data until pressure makes that space more valuable elsewhere through normal page-cache behavior.
Observe whether the cache shrinks under genuine memory pressure and whether clearing it changes only warm-up behavior. Do not treat healthy reclaimable cache as a persistent leak.
Transcode Data Should Follow Session Lifetime
Temporary transcode files are working data, not the canonical media library. If they continue growing after sessions finish, check whether the cleanup path or container mount matches the directory Plex actually uses.
Plex separates metadata and server state from media files, which is why temporary work should be kept in its own recovery class.
End a known transcode and watch the temporary directory for cleanup. If old sessions remain indefinitely, verify mount paths and permissions before increasing the disk allocation.
Logs Can Grow Because the Error Is Still Repeating
A retained log may be a symptom of a crash loop, unreachable dependency, or noisy warning rather than a retention setting alone. Rotating faster hides the symptom but leaves the write workload intact.
Bounded Docker log rotation helps control size only after the underlying writer and message pattern are understood.
Identify the fastest-growing file and the repeated message before changing retention. Fix the error first, then size the log window around real troubleshooting needs. A clear persistent app-data layout helps distinguish durable Plex state from logs, caches, and temporary files that should remain bounded or rebuildable.
Preview and Analysis Data May Be Intentionally Long-Lived
Some generated artifacts exist to improve later browsing or playback and are not temporary in the same sense as a transcode segment. Deleting them can trigger expensive regeneration.
Storage planning should account for backup capacity and churn separately from rebuildable derived data so retention policies do not copy every disposable artifact forever.
Document which generated directories are rebuildable and which are needed for the experience you want to preserve. Exclude truly disposable paths from long-term backup only after a restore test proves the classification.
