Video AI becomes less reliable through rain, glass, or webs because optical interference hides real features while creating convincing false ones.
A patio camera may detect people reliably on a dry evening, then produce animal or person alerts when a wet web glows under infrared light. The model sees pixels, not “weather.” Droplets, reflections, and near-lens strands can dominate those pixels or erase the contours needed to recognize a distant subject.
Interference Adds Features That Do Not Belong to the Scene
Rain streaks create short bright lines; droplets refract and blur local regions; glass adds reflections; and webs form high-contrast curves close to the lens. Detectors trained on ordinary scenes may interpret those patterns as parts of an object or lose the true outline behind them.
Single-image research on rain removal models rain as a visual layer that can be separated from scene content. The need for dedicated removal methods shows that rain changes image structure rather than merely lowering brightness.
Near-lens interference is disproportionately powerful because it occupies many pixels despite being physically small. Infrared light can illuminate a strand or droplet while the distant driveway remains dark. The false feature may then receive more contrast than the real person the system is supposed to find.
Glass and Water Create Competing Images
A camera behind glass can capture the outdoor scene and an indoor reflection at the same time. Focus, exposure, and polarization determine which layer dominates. Water adds refractive distortion that moves as droplets slide, so a static background becomes temporally unstable even when nothing meaningful moves outside.
Reflection-removal work treats reflection separation as two superimposed visual components rather than one clean scene. That model explains why ordinary object detection can attach confidence to details from the reflected room instead of the monitored area.
Motion detection may trigger first, followed by a detector forced to classify the changed region. The resulting label can appear confidently wrong because the pipeline has already selected an unusual crop. Confidence measures fit to training data do not guarantee correctness under optical contamination.
Where Weather Is Not the Main Cause
The interference explanation falls short when errors persist after the lens and glass are clean, or when detections align with encoder artifacts and dropped frames. A model update, sensitivity change, infrared-mode switch, or altered detection zone can coincide with rain and create a misleading correlation.
Research specifically aimed at detecting spider webs reports that webs can cause substantial false-alarm burdens in surveillance. Yet a web is only causal when its position and illumination align with the false regions seen by the model.
Weather also cannot explain a failure limited to the mobile app if server-side detections and stored frames remain correct. Separate capture obstruction from transport and interface rendering. A wet scene with clear object contours may still work well, while one small backlit droplet can defeat a particular camera angle.
Match Obstructions to the Pixels That Trigger Detections
Save matched dry and contaminated clips from the same camera and inference model. Mark the pixel regions occupied by droplets, reflections, or webs, then compare whether false boxes overlap those regions. Record infrared state, shutter, gain, object size, confidence, and encoder bitrate.
Keep the test in a local event processing pipeline so file events, inference frames, and alert timestamps can be compared without a cloud service silently changing preprocessing. Use several nights because webs and droplets move.
Call optical interference causal when errors appear with the obstruction, overlap its image region, and disappear under otherwise matched conditions. If failures remain after cleaning or occur outside the affected pixels, investigate model or stream changes. If rain only increases motion triggers, distinguish trigger sensitivity from classification accuracy.
