USB power can fail during simultaneous NAS drive activity because several drives and bridge chips may demand more current than their shared path supplies.
The same enclosure or hub may look stable when one disk is idle, then disconnect when a backup starts, another drive wakes, or several volumes flush writes together. USB data bandwidth and USB power are separate limits, but a power disturbance often appears as a data error because the bridge resets and the operating system loses the device. The sections below trace the budget from host port to hub, cable, enclosure, and drive so concurrent activity can be tested without assuming every disconnect is a filesystem problem.
Bus-Powered Devices Share a Finite Upstream Budget
A bus-powered drive receives operating power from the USB connection rather than from its own adapter. When several devices sit behind one hub, the upstream port and hub design determine how much power can be distributed.
Plugable distinguishes bus-powered storage from self-powered equipment because external hard drives can exceed what a host or passive hub can reliably provide. A data-capable port does not guarantee enough current for every attached drive at once.
The limit can exist at the computer port, an internal hub, a USB-C dock, or the enclosure’s regulator. Moving the drive to another connector helps only when that connector uses a different power domain.
Activity Raises Demand Above the Idle Baseline
A mechanical drive uses more power while spinning up, seeking, and writing than while already spinning with little I/O. An enclosure also powers its USB-to-SATA bridge and any status, cooling, or control electronics.
Real hub failures show that simultaneous USB demand can disconnect a device that worked until another peripheral became active. The trigger is not necessarily total average watts; short current peaks and voltage droop can reset the bridge before a slow meter displays the maximum.
Two backup jobs beginning together can therefore fail even when either job completes alone. Drive wake-up, cache flush, head movement, and controller activity overlap in time.
SSDs avoid spindle startup but can still create short controller and flash-programming peaks, especially inside multi-drive docks powered from one adapter.
A Powered Hub Still Divides One Adapter Across Its Ports
Adding an external adapter changes the hub from relying entirely on the host to supplying its downstream devices locally. It does not create unlimited power per connector.
StarTech notes that high-power USB devices may fail or behave unreliably without an appropriate powered hub. The adapter wattage, hub conversion losses, charging policy, per-port protection, and simultaneous load determine the usable downstream budget.
A 60 W dock may also allocate power to laptop charging, Ethernet, displays, and other ports. The headline adapter rating is not necessarily the amount available to storage.
Use the intended adapter and avoid substituting one with matching connector shape but insufficient voltage, current, polarity, or negotiation support.
Cable and Connector Resistance Turn Current Into Voltage Drop
The source can provide enough current while the voltage arriving at the enclosure still falls too low. Longer cables, small conductors, worn connectors, adapters, and extra hub stages add resistance.
Plugable recommends keeping powered devices on their intended adapter because power-path voltage can become inadequate for high-current devices. The largest drop occurs when current rises, so a marginal cable may pass an idle test and fail during a simultaneous write.
The visible result can be a drive reset, repeated reconnect sound, bridge error, filesystem remount, or a copy that stalls before the device disappears.
Sustained NAS Work Exposes More Than Power Problems
A large copy keeps the drive, bridge, cable, controller, and thermal path busy long enough to expose marginal hardware. Power is one candidate, but bad sectors, bridge firmware, overheating, signal integrity, and host power management can produce similar symptoms.
ZimaSpace’s guide to an external drive disconnect separates true device disappearance from a slow transfer and tests the cable, direct port, hub, adapter, enclosure, and drive one variable at a time.
A power diagnosis becomes stronger when removing one simultaneous device or moving the drive to a self-powered enclosure makes the same workload stable without changing the data or filesystem.
Reproduce the Failure With a Controlled Power Path
Start with one drive connected directly or through its own powered enclosure, then repeat the same read-and-write workload. Add the second drive only after the first path remains stable.
Plugable warns that multiple mechanical drives should not share a bus-powered hub when their combined demand may exceed the host port. Use a powered hub or separate power domains, then inspect kernel or system logs for USB resets and over-current events.
Measure voltage and current at the correct point if suitable equipment is available, but do not place an unknown inline meter in a production backup path. The final validation is repeated sustained I/O with all intended drives active and no disconnect, reset, or filesystem error.
