TRIM does not become a different command when SSDs enter a home NAS pool. What changes is the path that free-space information must travel.
A single-drive filesystem can usually map a deleted range to one device. A pool may need to translate that range through datasets, volume managers, mirrors, parity layouts, encryption, or thin provisioning before any SSD receives a discard hint. That extra translation changes which blocks can be released, when the work runs, and how visible its cost becomes.
A Single SSD Has One Main Allocation Map to Translate
When a file is deleted, the filesystem removes its logical ownership of the blocks. The SSD cannot infer that change from ordinary reads and writes, so the host may issue TRIM, SCSI UNMAP, or NVMe deallocation for the affected logical addresses. This relationship between deletion and flash management is the central point in an accessible SSD TRIM explanation.
On one directly attached drive, the translation is comparatively short: filesystem free space becomes a device discard range. Even here, the hint does not promise immediate physical erasure. The controller may record the pages as invalid and reclaim them later during garbage collection, which is why TRIM is neither a secure-delete mechanism nor an instant performance operation.
An SSD Pool Adds Translation and Ownership Boundaries
A pool introduces layers that can each own a different map of allocated space. The filesystem may know that a logical extent is free while a snapshot still references it. A virtual block device may then split the surviving range across members, and a controller or encryption layer must preserve the mapping well enough to pass a safe discard downward.
The practical question is therefore not simply whether every SSD supports TRIM. It is whether every layer accepts, translates, and forwards the request. The discard path through Linux storage layers shows why a command can be valid at the filesystem yet altered, delayed, or blocked lower in the stack.
| Storage state | Single SSD | SSD pool | Why behavior differs |
| Deleted file | One device range may become free | Snapshots or replicas may still own blocks | Logical deletion is not always physical freedom |
| Address mapping | Filesystem to one block device | Filesystem to virtual layout to members | Ranges may be split or rewritten |
| Discard timing | Continuous or periodic | Often coordinated at pool or dataset level | Bursts can affect several devices |
| Visible result | One drive performs background cleanup | Members may clean up at different times | Pool latency can become uneven |
Mirrors, Parity, and Thin Allocation Change the Safe Range
A mirror can often send equivalent deallocation information to both copies, but only after the upper layer decides that neither copy is needed. Parity layouts are harder because one logical extent is represented by data and parity across several devices. A discard that is harmless to one logical address may require alignment, reconstruction rules, or suppression at the virtual-device layer.
Thin provisioning adds another ownership boundary. Freeing blocks inside a filesystem does not automatically free the backing allocation unless deallocation crosses the virtual disk boundary. This distinction is also why the TRIM, UNMAP, and deallocation commands should be understood as address-management signals rather than one universal erase action.
TRIM Timing Can Change Latency Without Changing Capacity
Continuous discard sends hints as space is released. Periodic trimming scans free ranges in batches. The first approach spreads command traffic across normal activity; the second can create a noticeable maintenance burst. Neither changes the filesystem's reported free-space total, because that total was updated when the files were deleted, not when flash blocks were erased.
Filesystems can deliberately choose asynchronous discard to reduce foreground pauses. The engineering behind asynchronous Btrfs discard illustrates how batching and rate control separate space release from immediate application latency. At the device level, TRIM and garbage collection behavior explains why cleanup can continue after the host-side command has completed.
Pool-Wide Consistency Matters More Than a Per-Drive Checkbox
For a home NAS, the useful test is end-to-end. Confirm that the filesystem can identify unused ranges, that retained snapshots are accounted for, that the pool layer supports discard for its layout, and that every member reports the expected capability. A drive-level feature flag proves only the final device can understand the command.
Also watch latency over time rather than expecting one trim run to raise a benchmark immediately. Multiple SSDs may enter garbage collection at different moments, and research into garbage collection in SSD arrays shows why uncoordinated cleanup can produce variable array performance. The pool's discard policy should be evaluated as scheduling behavior, not as a yes-or-no SSD feature.
Does deleting a file mean the NAS SSD is trimmed immediately?
No. Deletion changes filesystem ownership first. A continuous or scheduled discard may notify the device later, and the SSD controller can postpone physical reclamation until its own garbage-collection cycle.
Can snapshots prevent TRIM from releasing space?
Yes. If a snapshot still references the old blocks, the filesystem cannot truthfully mark those ranges unused. The blocks become discardable only after every live reference has been removed.
Should every SSD pool use continuous discard?
Not automatically. Continuous and periodic discard shift work into different latency patterns. The right choice depends on filesystem support, pool layout, workload, and whether scheduled maintenance produces acceptable pauses.
