Speculative decoding acceptance rate measures how often target-model verification keeps proposed draft tokens, directly shaping the useful work gained per verification pass.
A smaller draft model can propose several future tokens while a larger local model verifies them in parallel. If most proposals survive, one expensive target pass advances the response by multiple positions; if rejection happens early, much of the draft work is discarded. The rate is therefore a workload-dependent efficiency signal, not a standalone accuracy score or a guarantee of end-to-end speedup.
Acceptance Counts Verified Draft Progress
In standard speculative sampling, the draft distribution proposes a block and the target evaluates those positions together. Tokens are accepted in order until the first rejection, after which the algorithm samples a correction and starts another speculative round.
The original speculative-decoding paper defines an acceptance probability from the relationship between draft and target distributions while preserving the target model's output distribution. Accepted progress, not visual similarity between model answers, is the operative quantity.
Implementations may report accepted tokens divided by proposed tokens, average accepted length, or acceptance probability. Those metrics are related but not identical, so comparisons need the same definition and draft length. This distinction remains visible during later household testing.
Draft Quality and Sampling Policy Move the Rate
A draft closer to the target on the current language, domain, and prompt tends to propose more acceptable continuations. Temperature, top-p, tokenizer alignment, draft length, and target confidence also change how often a block survives.
Online Speculative Decoding adapts the draft from target feedback and reports that improving token acceptance rate can reduce latency across changing request distributions. The result demonstrates that acceptance can drift with workload rather than remain a fixed model-pair property.
A larger draft may raise acceptance but cost more to run; a smaller draft is cheap but may be rejected often. The useful choice balances accepted progress against drafting and verification time. The intermediate result must remain inspectable before automation follows.
High Acceptance Is Necessary but Not Sufficient for Speedup
End-to-end gain also depends on the target's ability to verify a block efficiently, draft latency, memory traffic, synchronization, batch size, and the cost of rejected work. A high fraction on short blocks may save fewer serial steps than a moderate fraction on well-sized blocks.
Medusa replaces a separate draft model with multiple decoding heads that propose multiple continuations from the target representation. Its design shows that proposal architecture and verification shape the same throughput tradeoff. That boundary should be measured separately under realistic operating conditions.
The failure boundary is a workload where drafting plus verification costs as much as ordinary decoding. Code, multilingual text, creative sampling, or domain shifts can lower accepted length enough that speculation consumes extra memory without reducing latency.
Measure Accepted Progress per Millisecond
For each prompt class, record proposed tokens, accepted tokens, accepted prefix length, draft time, target verification time, rejection position, total latency, tokens per second, memory, and output-equivalence checks. The practical consequence appears when several sources compete for limited context.
Relate the workload to sampling policy. Sweep draft length and sampling settings while keeping the target model and requested distribution fixed, then compare against ordinary autoregressive decoding. This dependency should remain explicit in the final interface.
Enable speculation only where accepted progress per total millisecond improves. If acceptance looks high but latency does not fall, optimize proposal and verification overhead rather than treating the ratio as the final performance metric. The result must therefore be checked against the original evidence.
What Is Embedding Drift, and When Does a Private Search Index Need Rebuilding?
Decode model, preprocessing, corpus, and query drift; distinguish monitoring from incompatibility; and decide when a private index needs rebuilding.
What Is Tokenizer Compatibility, and Why Can It Break Model Switching?
Decode vocabulary identity, special-token semantics, chat templates, cached tokens, adapters, and compatibility checks for local model switching.
What Is Model Residency, and When Should a Local AI Service Keep Weights Loaded?
Decode weight residency, cache levels, cold starts, eviction, multiplexing, memory pressure, and when a home AI service should stay warm.
