How Does a Sliding Context Window Change Local AI Memory Use?
A sliding context window caps active attention memory by excluding older token state after the retained window reaches its configured limit.
Full causal attention keeps keys and values for the entire active sequence, so KV memory grows as a conversation, document, or generated answer becomes longer. Sliding-window attention changes that relationship: each token attends directly to only a bounded recent region, allowing older cache entries to be overwritten or omitted when the implementation supports rolling storage. The model can handle a long stream with a more predictable working set, but discarded history is no longer available through the same direct attention path.
Full Attention Keeps Expanding the Active KV History
With ordinary full-context inference, each retained token contributes key and value tensors across the modelโ€™s attention layers. A longer conversation therefore increases the cache that must remain addressable.
Mistral 7B introduced sliding-window attention as a way to reduce inference cost while processing long sequences.
The weight memory does not change with conversation length, but the runtime memory available for KV cache, users, and temporary work does.
A Fixed Window Can Bound Cache Growth After Warm-Up
If each layer retains only the most recent window of tokens, old KV entries can leave the active working set as new tokens arrive. Memory then approaches a ceiling based on window size rather than total stream length.
Longformer formalizes local window attention whose computation scales with the selected neighborhood instead of every token pair.
A rolling KV buffer can reuse physical slots after the window is full, making memory use more stable during an extended local chat or transcription stream.
This benefit depends on the runtime actually dropping or overwriting out-of-window state. A model architecture that uses local attention does not guarantee every serving engine allocates the cache identically.
Stacked Layers Can Carry Information Beyond One Local Window
A token at one layer reads a recent neighborhood from the previous layer. Deeper layers receive representations that already contain information mixed from earlier neighborhoods.
The Mistral architecture explains this stacked receptive field: information can propagate farther than one window across multiple transformer layers.
Indirect propagation is not the same as retaining exact direct access to every old token. The model receives transformed representations rather than an unlimited full-history lookup table.
Dropping Old KV State Changes What the Model Can Retrieve Directly
Once an early token leaves every relevant attention window, later tokens cannot attend to its original key and value through the normal local-attention path.
StreamingLLM shows that naive recent-token eviction can damage model behavior after the sequence exceeds the cache size.
Attention sinks, global tokens, summaries, retrieval, or architecture-specific hybrid layers can preserve selected long-range information while keeping most cache memory bounded.
The memory saving therefore has a semantic boundary: old details may need to be summarized, retrieved again, or intentionally retained outside the ordinary sliding region.
Window Size Must Be Tested With the Actual Runtime and Workflow
Estimate the cache ceiling from window size, KV heads, head dimension, layer count, precision, batch size, and active users. Then verify the observed allocator behavior rather than assuming the theoretical bound is fully realized.
ZimaSpaceโ€™s Kimi K3 analysis separates fixed and token-growing state when discussing long-context memory. Different attention designs can impose different limits even when they advertise a similar maximum context.
Test short chats, streams longer than the window, facts placed near the beginning, several concurrent users, and a clean restart. Record peak memory, first-token latency, output speed, and whether early information remains available.
A smaller window is useful when it frees enough memory for reliability or concurrency without removing information the local workflow must preserve.
Is a sliding window the same as deleting the conversation?
No. The application may still store the full transcript, but the model may attend directly to only the recent window unless older content is summarized or retrieved again.
Does sliding-window attention always use constant memory?
It can bound the attention cache for one sequence, but total memory still includes weights, other layers, active users, temporary buffers, and runtime reservations.
Can a model remember facts older than its window?
Sometimes through propagated representations, global attention, summaries, retrieval, or application memory, but direct access to the original token state is limited by the architecture.
