Two editors sharing one NAS project database create concurrent transactions, locks, and failure states that ordinary shared media access does not require.
The result depends on architecture: a collaboration-aware database service can serialize changes, assign ownership, and expose updates to both editors, while two applications opening one database file through a mapped share may depend on fragile filesystem locking and application-specific safeguards. Network latency, autosaves, timeline changes, bins, markers, and disconnects all influence what the second editor sees and when a write becomes durable. The sections below separate file sharing from database collaboration and show which design keeps project state consistent.
How Is a Project Database Different From Shared Media?
Media files are usually opened for sustained reads and only occasionally replaced, while a project database receives frequent small updates to timelines, bins, markers, grades, permissions, and user state. Those changes must remain ordered and internally consistent.
Server-based editing distinguishes ordinary file access from shared projects. Storing a project beside shared footage does not automatically create transactions, ownership, or conflict resolution.
The NAS can host both data classes, but they are different services. Media needs throughput and stable paths; project state needs low-latency commits, durable journals, supported concurrency, and recoverable backups.
What Happens When Both Editors Try to Write?
The project system must decide whether the changes touch independent records, whether one editor owns a sequence, or whether the second write must wait. A coarse design may lock an entire project, while a collaboration-aware database can coordinate smaller transactions.
SQLite on network shares illustrates the risk of treating an embedded database as a client-server service. Network filesystem locking and cache semantics may not provide the guarantees that two independent applications expect.
At the editor level, the outcome may be read-only access, a waiting indicator, a rejected save, a conflict version, or merged updates. The behavior must come from the editing systemโs collaboration model rather than from SMB alone.
A file lock can protect one project file, but database transactions also need ordering, atomicity, and rollback. Those requirements extend beyond simple โone writer at a timeโ ownership.
Why Can a Fast NAS Link Still Feel Slow?
Database collaboration exchanges many short queries and commits, so round-trip latency can matter more than sequential bandwidth. A marker change may contain only a few bytes but still wait for authentication, a query, a lock, journal activity, a durable flush, and confirmation.
The editor experiences these database round trips as project-open delays, lock waits, or sluggish updates rather than a slow media stream. The database server coordinates transactions near its storage while clients send requests instead of manipulating a remote database file directly.
Moving from 2.5GbE to 10GbE can accelerate footage without shortening a database commit. Measure query latency, commit time, lock duration, database-disk latency, and disconnect recovery beside media throughput.
What Architecture Keeps Both Editorsโ Work Consistent?
Use the collaboration method the editing application supports: a project server or database service for concurrent state, stable NAS paths for media, explicit user permissions, and local caches for disposable workstation data.
ZimaOS can host a PostgreSQL project library as a service rather than exposing one embedded project database file to several clients. The service owns locking and transactions while the NAS provides persistent storage and network access.
The architecture is valid only when both editors pass a real concurrency test. Open the same collaboration project, change separate objects, attempt a conflicting edit, disconnect one client, reconnect it, and confirm that the second editor sees a consistent state through the supported collaboration service.
Back up the project database with its supported method and prove a restore outside the live service. Copying database files during active writes may capture an inconsistent point even when the media folders are protected correctly.
Can two editors safely open the same project at once?
Only when the editing application and project architecture explicitly support simultaneous access. Otherwise one editor may be read-only or both may create conflicting saves.
Should the database and media use the same NAS pool?
They can, but the database needs low-latency transactional I/O while media needs sustained throughput. Separate tiers or resource controls may be necessary when one workload disrupts the other.
Does copying the project folder protect the live database?
Not always. Use the database or applicationโs supported backup method and verify that the captured state can be restored consistently.
