A RAG pipeline can cite the right file but the wrong passage when document discovery succeeds while chunk retrieval or citation mapping fails.
Large files often contain many sections that share terminology, repeated headers, similar examples, or multiple versions of the same fact. A file-level retriever can correctly identify the relevant manual, report, or household note while the passage-level stage selects a neighboring chunk. The answer model may then infer the missing detail from its own knowledge or another chunk but attach the metadata of the selected file. Reliable citation requires independent correctness at document, page, chunk, span, and generation stages.
Document Recall and Passage Recall Are Different Retrieval Problems
A file can rank highly because its title, metadata, or overall embedding matches the question. That does not prove the answer-bearing paragraph appears in the retrieved chunk set.
A practical RAG failure guide separates retrieval failure layers and recommends inspecting the exact chunks rather than only the final answer.
The pipeline should measure document recall, page recall, and chunk recall separately. A correct filename can hide a missed answer span.
Chunk Boundaries Can Separate the Evidence From Its Context
A fixed-size split can place a heading in one chunk, the claim in another, and the exception or table label in a third.
Edtek’s guide describes how wrong chunk boundaries produce passages that mention the query without containing the complete answer.
The retriever may still select the correct file because many chunks share the topic. The generator receives an incomplete passage and cites the file-level source as though it proved the claim.
Structural chunking, parent-child retrieval, and neighbor expansion help only when source offsets remain traceable.
Citation Metadata Can Be Attached at the Wrong Granularity
Some pipelines copy one document URL or filename onto every chunk without storing page, section, bounding box, or character offsets.
Tensorlake’s citation guide shows how spatial anchors can flow from document preprocessing through retrieval and answer generation.
A file-only pointer proves where the corpus item came from, not which bytes support the sentence. Passage-level citations need stable chunk identity and location metadata.
OCR, PDF reflow, and edited documents can invalidate offsets unless the citation also records the indexed snapshot or content hash.
Similar Passages Can Cause the Generator to Mix IDs
The context may contain several chunks from the same file with similar language. The model can use one passage’s content and emit another nearby chunk’s citation label.
An article on citation-critical RAG warns that nearby passage errors remain possible even when the cited document is authoritative.
Label chunks with clear, non-similar IDs and keep the citation adjacent to the supporting text. Asking the model to remember a separate citation map after synthesis increases mismatch risk.
Deterministic quote-to-chunk verification can detect when the cited passage does not contain the claimed or quoted text.
Reranking Must Score Passage Support, Not Only Topic Similarity
A first-stage retriever may bring many chunks from the correct file. A reranker should distinguish the section that directly answers the query from sections that merely share the topic.
Databricks’ chunking guide emphasizes that coherent retrieval units are necessary before later retrieval stages can rank passages accurately.
Rerank with the full query, preserve the passage’s heading and parent context, and penalize chunks that lack the requested field, date, entity, or evidence type.
ZimaSpace’s document-search workflow treats these as separate stages rather than one generic “RAG quality” score.
Verify the Exact Passage Before Rendering the Citation
After generation, map each factual sentence or quote back to the chunk that contains its support. Reject citations that point only to the right file.
Infolitz recommends attaching citations to source-bearing chunks rather than reconstructing them at the whole-file level.
Evaluate passage precision, evidence completeness, quote containment, citation offset validity, and whether the cited span supports the exact generated claim.
The system is fixed only when clicking the citation opens the smallest sufficient passage—not merely the correct document somewhere near the answer.
