A RAG evaluation dataset is a repeatable set of queries and expected evidence or answer behavior used to measure private search changes consistently.
Without a fixed evaluation set, a home knowledge base can feel better after a new chunk size, embedding model, reranker, or metadata rule simply because different questions were tried. A useful dataset freezes representative household queries, labels the evidence that should be retrieved, records acceptable answer behavior, and includes cases where the system should admit that the corpus does not contain the answer.
An Evaluation Dataset Freezes Questions and Expected Evidence
The basic unit is a test case that can be run again after the RAG pipeline changes. It may contain a question, reference answer, relevant source passages, document identity, metadata constraints, and notes about what a correct refusal should look like.
A stable RAG test can pair questions and expected answers before measuring the application repeatedly.
For private search, evidence labels are often more valuable than answer text alone because they expose whether the right file and version entered context even when the language model happened to produce a plausible final sentence.
A test case should preserve source identity at the same granularity the system retrieves. If evaluation labels only a whole PDF while the index returns chunks, a failure can hide inside an apparently correct document-level match.
Private Search Needs Failure Modes From the Actual Household Corpus
Public benchmarks rarely contain the duplicate filenames, OCR scans, revised manuals, family-specific vocabulary, exact serial numbers, private folder rules, and stale versions that shape a home knowledge base.
Different corpora can require domain-specific RAG evaluation rather than assuming one general QA benchmark represents every retrieval environment.
Build cases from real search logs and known difficult files, then add synthetic variations only where they test a clearly defined boundary. Exact identifiers, paraphrases, multi-document synthesis, stale-current conflicts, and answer-not-present queries should not be represented by one generic question type.
Retrieval and Generation Need Separate Labels
A correct final answer can hide weak retrieval if the model knew the fact from pretraining, while a bad answer can occur even when the perfect passage was retrieved. The dataset should therefore support stage-level metrics rather than one all-or-nothing score.
Structured evaluation samples let metrics assess retrieval and response quality from consistent test inputs.
For each query, label which evidence must be present, which versions are forbidden, and what answer properties matter. Then compare recall, ranking quality, context precision, faithfulness, answer correctness, citation identity, and refusal behavior separately.
This separation makes regressions actionable. A lower answer score can be routed to chunking or retrieval when evidence vanished from top-k, or to generation when the evidence remained intact but the answer misused it.
Negative and Boundary Cases Keep the System From Gaming the Dataset
A dataset containing only easy answerable questions rewards systems that always respond confidently. Private search also needs queries whose answer is absent, ambiguous, permission-restricted, superseded, or dependent on more than one source.
Out-of-KB cases are necessary to measure conservative behavior rather than only recall on known answers.
Permission tests are equally important for a household index. A result that is semantically perfect but unauthorized should score as a system failure, not as excellent retrieval.
Include near-duplicate and version-conflict examples so the system cannot improve average metrics simply by returning more candidates. The expected evidence should identify the authoritative source, not only the topic.
Dataset Versioning Turns One-Time Testing Into Regression Control
The corpus and the questions both change over time. New devices, renamed folders, updated policies, and different user vocabulary can make an old evaluation set unrepresentative, so the test data itself needs a controlled lifecycle.
Dataset versioning allows pipeline results to be compared against a known state of the evaluation examples.
The private knowledge-base workflow is the application layer; the evaluation dataset is what makes changes to that workflow measurable instead of anecdotal.
Refresh the dataset when the corpus or user behavior changes, but keep historical versions so a new evaluation set does not erase evidence that a retrieval change regressed an older critical workflow.
