A second model changes evidence order by jointly reading each query-candidate pair, applying finer relevance signals than the first-stage vector comparison can represent.
A private archive may retrieve twenty plausible chunks in milliseconds, yet the most useful passage sits below generic material that shares the queryโs vocabulary. A reranker spends more computation on that small candidate set and produces a new score for each pair. The final context can improve even though no documents, embeddings, or user questions changed.
First-Stage Retrieval Optimizes Coverage Under a Speed Budget
Dense or hybrid retrieval compares compact representations across the entire corpus. It must be fast enough to scan or traverse many candidates, so it encodes each document independently of the current query. This favors broad recall but can miss fine relations such as negation, role, chronology, or exact constraints.
An overview of query-document pairs describes the reranker as a cross-encoder that scores a query and document together. That joint attention is more expressive than comparing separately produced vectors, but too expensive to apply to every document in a large library.
Two-stage retrieval divides the work: the first model creates a candidate pool; the second spends precision on that pool. If the correct evidence never enters the pool, reranking cannot recover it, which makes candidate recall a hard dependency.
Joint Scoring Changes Which Evidence Reaches the Generator
The reranker sees the full query beside each candidate and can reward exact entailment, matching entities, or required conditions. It can demote a broadly similar overview beneath a narrow paragraph that directly answers the question. The top-k passed to the LLM therefore contains different evidence.
A detailed treatment of cross-encoder interaction explains how cross-encoders solve limitations of bi-encoder similarity through joint processing. This extra interaction is the mechanism behind better ordering, not a second vector lookup. That distinction changes the resulting household decision.
Order matters because context windows and attention are finite. A better first passage can ground the answer early, while lower-ranked duplicates can crowd out complementary evidence. Reranking should therefore consider both relevance and coverage, not merely produce ten versions of one fact.
Where Reranking Makes Private Search Worse
A reranker inherits its training preferences. It may favor polished prose over tables, dominant languages over household dialects, or explicit keyword matches over implicit evidence. Small candidate pools amplify first-stage misses, while large pools add latency and can make interactive search feel uneven.
Recent discussion of evidence diversity notes that relevance-only reranking can reduce evidence diversity, motivating a later diversity step. This shows why a higher relevance score is not automatically a more complete evidence set. This boundary remains visible during later evidence review.
The claim fails when the reranker is mismatched to the domain or when latency exceeds the interaction budget. It should be bypassed or replaced if it consistently demotes verified answers, collapses source diversity, or changes ordering without improving supported responses.
Evaluate Ordering With Paired Retrieval Runs
Build a test set containing queries, acceptable evidence passages, and important source categories. For each query, save the first-stage ranking and reranked order, then measure recall in the candidate pool, precision at the final cutoff, reciprocal rank, citation support, and latency.
Use repeatable evaluation rather than memorable demo questions, following the approach in first-stage reranking. Inspect rank reversals manually, especially for spreadsheets, multilingual text, negation, dates, and near-duplicate chunks. The dependency must therefore be measured separately in practice.
Keep the reranker only if it promotes supported evidence across the test set without unacceptable latency or diversity loss. A lower final answer score should trigger investigation of candidate recall separately from reranker quality, because the two stages fail differently.
Multilingual Embeddings: How One Vector Space Connects Household Documents Across Languages
See how aligned embeddings connect documents across languages, why retrieval quality varies, and how to test cross-language evidence coverage locally.
Agent Memory Conflicts: Why Recent Corrections Can Lose to Repeated Older Facts
Learn how duplicate old memories overpower corrections, where recency rules fail, and how to test supersession in a private agent memory store.
Local LLM Sampling: Why Decoding Settings Change Repetition and Stability
Learn how temperature, top-p, min-p, seeds, and penalties interactโand how to test decoding settings without confusing randomness with quality.
