Prefix caching reduces repeated prompt work by reusing the key-value state already computed for an identical leading sequence of tokens.
On a home AI server, that shared prefix can be a system policy, tool schema, long document, household instruction set, or repeated chat history. The first request still pays the full prefill cost, but later matching requests can skip much of it. The main benefit is a shorter prefill path and faster first token, not free generation.
Repeated Prompts Recompute the Same Prefill Without a Cache
Before generating a reply, an autoregressive model processes the input tokens and builds the key-value state used by later decoding. A long system prompt, tool schema, document header, or shared instruction block can therefore consume the same prefill work on every request.
Prompt Cache formalizes this opportunity by reusing attention states from overlapping prompt segments. On a home AI server, the repeated portion may be thousands of tokens even though the user contributes only one new sentence.
Without reuse, the GPU or CPU performs those matrix operations again and reads the same model weights for the same prefix. The output may be identical, but the server still pays the computational setup cost.
A Prefix Cache Stores KV State for an Already Processed Prefix
After the first compatible request, the runtime can keep the KV state associated with the shared prefix. A later request begins by checking whether its leading token sequence matches cached blocks.
vLLM’s automatic prefix cache identifies blocks by the tokens in the block plus the preceding prefix. Matching requests can point to the same physical cache blocks rather than allocating and computing duplicate state.
The reusable object is not the final answer and not a generic semantic summary. It is model-specific attention state for an exact compatible prefix.
A Cache Hit Skips Shared Prefill but Still Computes the New Suffix
When the prefix matches, the runtime can start from the stored attention state and evaluate only the new tokens after the cached boundary. A household assistant with one stable system prompt can therefore avoid repeated work before each short command.
LMCache describes KV cache reuse across LLM requests as a serving-layer optimization rather than a change to model weights.
The new user message still needs prefill, and every generated output token still needs decode computation. Prefix caching mainly reduces redundant work before generation begins.
Long Stable Prefixes Create the Largest Time-to-First-Token Gain
A cache saves work in proportion to the portion that would otherwise be recomputed. Reusing a 2,000-token instruction and document prefix matters more than reusing a ten-token greeting.
SGLang’s serving design uses structured KV reuse to accelerate shared-prefix workloads. The home-server equivalent is a repeated agent policy, tool catalog, household knowledge packet, or document template.
This is why prefix caching should be evaluated with time to first token and prefill throughput, not only tokens per second during generation. The decode phase can remain nearly unchanged while the response starts sooner.
Small Prompt Changes Can Break Reuse at the Block Boundary
A cache is usually exact with respect to tokens and model state. Reordering tool definitions, inserting a changing timestamp near the beginning, switching adapters, or modifying the system prompt can make later blocks ineligible for reuse.
Hugging Face’s serving guidance distinguishes prefill from decode scheduling. Keeping stable content early in the prompt makes a larger fraction of that prefill reusable.
Applications should therefore avoid injecting volatile data into the front of an otherwise stable prefix when the same information could be placed later.
Cache Capacity and Eviction Set the Home-Server Boundary
KV blocks consume memory, so the server cannot keep every prefix forever. Concurrent conversations, long contexts, and several models compete for the same memory pool and can evict old reusable state.
ZimaSpace’s explanation of model caching and warm-response latency provides the wider cache hierarchy. Prefix caching is only one layer and should not be confused with keeping model weights resident.
Measure cache-hit rate, reused token count, time to first token, prefill throughput, KV memory use, and eviction rate under the real household concurrency level.
NVIDIA’s TensorRT-LLM documentation describes KV cache reuse as a serving optimization with the same core limit: reusable state helps only while the matching blocks remain available.
