An MTU mismatch causes partial home server connectivity when small packets can cross the path but larger packets cannot. DNS replies, TCP handshakes, pings, and short API calls may succeed, creating the impression that the route is healthy. The connection then stalls when TLS, a web response, an upload, or a file transfer produces an IP packet larger than one link can carry.
A correct path reports that size limit so the sender can reduce its packets. Partial failure appears when a tunnel, virtual bridge, router, or ISP link has a smaller MTU and the feedback never reaches the sender—or when different layers advertise sizes that do not reflect their real encapsulated path. The result is reachability without reliable data delivery.
The Short Answer: Packet Size Is Part of Connectivity
MTU is the largest IP packet an interface can send in one link-layer transmission. Endpoints care about the smallest usable value across the complete path, not just the 1500-byte setting displayed on a home server’s Ethernet port. VPN and overlay headers consume space, so a packet that fits the LAN may be too large after encapsulation.
The failure is partial because protocols begin with small control packets. A TCP three-way handshake can complete, and a browser can connect, before either side sends a full-size data segment. If oversized packets disappear while acknowledgments and smaller retransmissions still pass, the session looks alive but makes little or no progress.
MTU, MSS, and Path MTU Discovery Are Related but Different
Interface MTU limits the IP packet on one interface. TCP Maximum Segment Size, or MSS, advertises how much TCP payload an endpoint wants in each segment; it leaves room for IP and TCP headers. MSS clamping can lower that advertised payload at a router, but it affects TCP negotiations rather than every UDP or ICMP packet.
Path MTU Discovery, or PMTUD, lets a sender learn the smallest MTU along a route. For IPv4, RFC 1191 defines a process in which a router unable to forward a packet with the Don’t Fragment bit set returns ICMP fragmentation-needed feedback. The sender can then lower the path value and retransmit.
IPv6 routers do not fragment transit packets. RFC 8201 specifies that an IPv6 node uses ICMPv6 Packet Too Big messages to learn a smaller path MTU. Blocking that control traffic does not harden the data path; it prevents the endpoint from adapting to a real limit.
Where a Home Server Path Starts Dropping Larger Packets
A Tunnel Shrinks the Usable Payload
WireGuard, IPsec, PPPoE, VLANs, and other encapsulations add headers around the original packet. A 1500-byte inner packet cannot fit unchanged inside a 1500-byte outer link once those headers are present. A tunnel interface normally advertises a lower MTU, but a manual override or an intermediate device can leave the endpoints with an optimistic value.
The mismatch may affect remote access while the local service remains perfect. A phone on Wi-Fi reaches the server over ordinary Ethernet, while the same phone on a VPN uses the smaller tunnel path. Because routing, authentication, and small requests still work, the symptom can resemble an application or certificate problem.
Nested paths compound the issue. A container packet may cross a virtual Ethernet pair and bridge, enter a VM adapter, then enter a VPN. The restrictive MTU belongs to the complete route, while each visible interface may report a plausible value for its own layer.
ICMP Feedback Is Filtered or Lost
If the limiting router drops an oversized packet and its error reaches the source, PMTUD can recover. If a firewall discards all ICMP or ICMPv6 indiscriminately, the sender keeps using a size the path cannot carry. Cloudflare describes this modern failure as a Path MTU black hole: large packets are silently lost while the application waits.
Asymmetric routing can produce the same outcome even when no firewall deliberately blocks the message. The data packet may take one path and the ICMP error another; policy routing, NAT, or a provider filter can prevent the return message from being associated with the original sender. Packet capture must therefore inspect both the data and feedback directions.
Repeated TCP retransmissions are a clue, not proof. Congestion and wireless loss also trigger retransmission. MTU trouble becomes more likely when failures begin near a repeatable payload size, small probes succeed, and reducing the interface MTU or advertised MSS immediately restores progress.
Virtual Networks Advertise the Wrong Size
Container bridges and VM switches can inherit or default to an MTU that is larger than the underlay. The container then builds a packet valid for its virtual interface but too large after the host sends it through a VPN, cloud overlay, or PPPoE uplink. Offload features may make captures look larger than wire packets, so capture location matters.
A documented Docker case followed exactly this child problem: a small LDAP request succeeded, but the response disappeared because the VPN MTU was 1400 while Docker used 1500. Host networking appeared to fix the app because it removed the mismatched virtual layer, not because the application changed.
Do not infer wire behavior from one capture showing giant TCP segments. Generic segmentation offload can present large buffers to the operating system and split them later. Capture on the receiving side, disable offloads temporarily for diagnosis, or correlate interface counters with controlled packet-size tests before concluding that a device transmitted an impossible frame.
| Symptom | Why it can still work partly | Useful next test |
| Ping and SSH connect, but HTTPS hangs | Control packets fit; TLS or response packets do not | Probe increasing sizes with no fragmentation |
| LAN works, VPN fails | Encapsulation reduces the remote path MTU | Compare tunnel MTU and inner packet size |
| Downloads fail but tiny API calls pass | Only larger server-to-client packets cross the limit | Capture both directions and look for retransmission |
| Host works, container times out | Virtual interface advertises a larger MTU than the underlay | Compare host, bridge, container, and tunnel settings |
Upstream and Tunnel Settings Shape the Real Limit
The home server is not always the place that created the mismatch. PPPoE, an ISP transition mechanism, a remote-access tunnel, or an upstream router may introduce the narrowest link. Trace the exact client-to-service route and note every encapsulation boundary rather than changing only the physical NIC.
Allow the control messages PMTUD needs. For IPv4, that includes the relevant destination-unreachable fragmentation-needed message; for IPv6, it includes Packet Too Big. Apply narrow firewall policy by message type and state instead of blocking all ICMP. A server cannot learn a path constraint that the network refuses to report.
Avoid depending on fragmentation as the normal fix. RFC 8900 explains that IP fragmentation introduces operational fragility. Aligning MTU, preserving PMTUD, or making the transport probe safely is more robust than assuming every middlebox will forward and reassemble fragments.
If one router cannot be changed, MSS clamping may be a practical TCP workaround at the tunnel or forwarding boundary. Set it from the real path rather than copying a universal number. It will not repair oversized UDP datagrams, and an unnecessarily low value adds packet and header overhead, so confirm the improvement with captures and application tests.
Server, VM, and Container Settings Must Agree
Inventory the MTU on the physical NIC, bond, VLAN, bridge, VM adapter, container network, and tunnel. The values do not need to be numerically identical when a layer correctly accounts for encapsulation, but no inner layer should produce packets that the next layer cannot carry or report as too large.
For Docker, set an appropriate MTU when creating the network or through the daemon configuration, then recreate affected networks and containers as required. Civo’s troubleshooting example shows how a Docker MTU that ignores the underlay can cause unexpected connectivity problems. Verify the live interface afterward; editing configuration alone does not prove the running network changed.
Keep performance tuning separate from repair. ZimaSpace’s explanation of TCP window size on long-distance links concerns how much data can remain in flight, while MTU controls packet size. Increasing buffers cannot make an oversized packet fit through a smaller link.
Checks That Find the Broken Stage
Find the Largest Packet That Consistently Passes
Use platform-appropriate ping options to set payload size and prohibit fragmentation where supported, remembering to add IP and ICMP header bytes when comparing the result with an interface MTU. Test several sizes from the same client path that shows the failure. A repeatable threshold is more informative than one successful default ping.
Repeat the test on the LAN, through the VPN, and from inside the container or VM. If the threshold changes at one boundary, that layer becomes the leading suspect. Some networks rate-limit or block echo traffic, so confirm the result with TCP application requests or a purpose-built path-MTU tool.
Inspect Interfaces, Routes, and Encapsulation
Record the selected route and egress interface for the affected destination. Inspect MTU values on every virtual and physical interface the packet crosses, plus tunnel and container network configuration. Do not assume the default route is used when policy routing or split tunneling is active.
Calculate header overhead for the actual tunnel stack, including outer IP version and transport. The safe inner MTU must leave room for those headers on the outer path. If the tunnel uses a changing route, choose a value that works across its supported underlays or retain a functioning discovery mechanism.
Capture Data and ICMP Feedback on Both Sides
Capture near the sender and after the suspected narrow link. Look for a large packet repeated without acknowledgment, an ICMP fragmentation-needed message, or an ICMPv6 Packet Too Big message. If the error appears downstream but never reaches the sender, focus on return routing and firewall policy.
For TCP, inspect the MSS options in SYN and SYN-ACK packets and compare them with the observed data segments. A lower MSS can prevent the sender from creating oversized TCP packets, but it does not reveal whether UDP remains broken. Use the capture to validate the repair rather than treating a loaded firewall rule as success.
Align MTU or Clamp MSS, Then Retest
Prefer correcting the MTU at the interface that knows about the smaller underlay. Recreate virtual networks when their MTU is fixed at creation. If that is impossible, clamp TCP MSS at the forwarding or tunnel boundary and permit the required ICMP feedback. Make one change at a time so the result remains attributable.
Retest the original workflow, not only ping. Complete TLS negotiation, load a response larger than one packet, upload and download a file, and keep the connection active long enough to observe retransmissions. Partial connectivity is resolved only when the applications that exposed it transfer data reliably in both directions.
When Partial Connectivity Becomes a Serious Problem
Treat the issue as urgent when it affects backups, restores, remote administration, sync, or authentication. These workflows may pass preliminary checks and fail only after meaningful data starts moving, leaving incomplete copies or timeouts that operators misread as storage or credential faults.
Also prioritize it when IPv6 behaves differently from IPv4, a VPN-only path fails, or container traffic differs from host traffic. Those contrasts expose which route or encapsulation changes the usable packet size. The more deterministic the boundary, the less useful it is to keep retrying the application without repairing the network path.
Why can I ping the home server when its website will not load?
Default ping packets are small, as are DNS exchanges and TCP handshakes. The website may stall only when TLS or HTTP sends a packet above the path limit. Test larger non-fragmenting probes and capture the failed web connection instead of treating one ping reply as proof that every packet size works.
Should every interface use an MTU of 1500?
No. Ethernet often uses 1500, but tunnels and other encapsulations need room for outer headers. What matters is that each layer either advertises a size the next layer can carry or receives working feedback that lets it adapt to the smallest MTU along the route.
Is MSS clamping the same as fixing MTU?
No. MSS clamping changes the TCP payload size advertised during connection setup, which can keep TCP packets below a known limit. It does not change the interface MTU and does not directly constrain UDP or other IP traffic.
MTU alignment and functioning PMTUD address the path itself. Clamping is valuable when a forwarding device or tunnel cannot otherwise communicate the constraint, but it should be measured, placed at the correct boundary, and followed by tests of every affected protocol.
