Yes, model shards can live on a NAS while another home computer executes them, provided the runtime can read a complete, consistent checkpoint.
A GPU workstation does not need to be the permanent home of every model file. It can mount a NAS share, load the requested checkpoint into system RAM or VRAM, and perform inference locally while the NAS remains the durable library. The important boundary is timing: storage serves bytes during loading and occasional paging, whereas the computer’s processor and accelerator execute tensor operations after those bytes become addressable.
Shards Divide Storage, Not Automatically Computation
A sharded checkpoint splits one model’s tensors across several files so no single file becomes unwieldy. An index records which tensor belongs to which shard. This makes download, storage, and loading easier, but it does not mean each NAS disk or home computer executes one shard. Distribution at rest and parallel execution are separate architectural decisions.
Transformers can load sharded checkpoints by reading the index and loading each weight file into the model. The compute node still needs a device map that places tensors on CPU, GPU, or disk. Merely placing shard files in different folders does not create tensor parallelism or combine the VRAM of several unrelated machines.
For a home setup, the NAS is best understood as the model repository and provenance point. Keep configuration, tokenizer files, shard indexes, checksums, and license metadata beside the weights. The workstation is the execution node. This storage-compute split also appears in a NAS and compute-node design where media or documents remain centralized while specialized hardware handles inference.
Cold Start Depends on Bytes Crossing the Network
Before inference, the compute node must read enough of the checkpoint to create the execution layout. A 40 GB model cannot start as if it were a small configuration file: those bytes must cross the LAN unless a valid local cache already exists. A 1 GbE link has a theoretical ceiling near 125 MB/s before protocol overhead, so large cold loads can take minutes.
Runtimes may use memory-mapped model files, allowing the operating system to fetch pages on demand and retain them in page cache. On a network filesystem, a cache miss can become a network read during inference. That may reduce initial loading, but it can also move latency into the first prompts and make performance sensitive to cache eviction or NAS contention.
A local NVMe cache changes the experience without duplicating ownership. The workstation can copy a verified model version from the NAS once, execute from local storage, and discard or refresh it according to a manifest. The NAS remains authoritative; the cache absorbs repeated reads. More network bandwidth helps cold start, but it does not increase token generation speed after the active weights and cache are resident.
Consistency and File Semantics Set the Failure Boundary
A loader expects every shard and its index to describe one model revision. If a synchronization job replaces files while another computer is loading, the result can combine old and new shards or fail a checksum. File locking, atomic directory swaps, immutable version folders, and a completed manifest prevent readers from observing a half-published checkpoint.
Distributed frameworks explicitly account for storage coordination. PyTorch’s distributed checkpoint API supports storage readers and load-time resharding for compatible distributed applications. That is different from mounting a generic share and hoping any runtime can interpret training shards. Inference formats, tensor names, quantization, and device placement still must match the selected engine.
The NAS-execution claim falls short when the runtime requires local files, network locks behave differently than expected, a Wi-Fi link drops during page faults, or the working set repeatedly exceeds RAM. It also fails when “shards” are tied to a training topology rather than a portable inference checkpoint. Convert or consolidate the model before deployment instead of treating every checkpoint layout as interchangeable.
Use a Three-Run Storage Test
Measure a cold network run after clearing the workstation cache, a warm run from the operating-system cache, and a local-cache run from SSD. Record time to model ready, time to first token, sustained tokens per second, network bytes read after startup, and whether other NAS workloads change the result. Those three runs isolate transfer time from execution speed.
A dedicated discussion of model cold-start storage explains why format, memory mapping, page cache, and concurrent I/O matter before generation begins. Pair that model-level test with file checksums from the repository. A fast load of the wrong revision is a worse result than a slower, reproducible load.
Use direct NAS execution when cold starts are rare, the network is stable, and the working set remains cached. Use local caching when models start often or latency matters. If network reads continue throughout generation, reduce paging pressure or copy the model locally before upgrading the LAN. The pass condition is not that the model opens; it is repeatable loading with no mid-run dependency on fragile storage access.
| Test | What It Measures | Likely Decision |
| Cold NAS load | LAN plus storage throughput | Accept for infrequent starts |
| Warm NAS load | Page-cache benefit | Useful if cache remains stable |
| Local SSD cache | Execution-node storage ceiling | Prefer when startup matters |
FAQs
Can two computers use the same model files at once?
Yes, when they open an immutable model version read-only. Each computer still loads its own execution state and KV cache. Concurrent readers do not automatically share RAM, VRAM, or generated context.
Does 10GbE make inference faster?
It can shorten large cold loads and reduce page-fault delay. Once weights are resident, generation is normally limited by compute and memory bandwidth on the execution node rather than NAS throughput.
Are GGUF split files the same as training shards?
No. Both divide data across files, but their metadata, loading rules, and intended runtimes differ. Verify that the inference engine supports the exact split format before treating the NAS copy as executable.
How to Measure Local RAG Retrieval Quality and Interpret Recall, Precision, and Citation Coverage
Build a local RAG test set, calculate core retrieval metrics, interpret their tradeoffs, and audit whether answer claims are supported by cited evidence.
Why Does Smart Home Feature Computation Matter More as Sensor Count Increases at the Same Sampling Rate?
Trace per-sensor and cross-sensor compute as device count rises, identify nonlinear fusion costs, and benchmark the feature pipeline before automations lag.
Why Does RAG Evaluation Cost Matter More as the Document Library Grows at the Same Query Volume?
Understand why corpus growth raises RAG evaluation effort without more user queries and how stratified tests keep cost tied to risk.
