Plex performance is easy to overestimate when a repeated test is served from cache instead of exercising the storage, network, or compute path you mean to measure.
Cache is useful production behavior, not an error to eliminate, but it answers a different question from capacity. A warm movie, cached poster, or repeated seek can look dramatically faster than the first access. The method is to label cold, warm, and steady-state runs, control the client and playback mode, and watch the underlying device metrics before calling the fastest result sustainable capacity.
Define Capacity as Performance the System Can Sustain
Capacity is the workload the complete Plex path can maintain over the relevant time window: concurrent reads, transcodes, metadata activity, and network delivery without falling behind. Cache can raise short-term performance by serving reused data from a faster layer, but that burst is not proof that the slower backing resource can sustain the same rate indefinitely.
When the working set fits memory, warm-cache benchmark results can differ sharply from first-access behavior. For Plex, record whether a run is cold or warm instead of treating every repeated result as the same capacity measurement.
Write the performance claim before testing. If the question is “can this server sustain three remote streams while a backup runs,” a ten-second warm replay of one file is not the relevant capacity test.
Run Cold and Warm Tests on the Same Media Path
A cold-oriented run starts from a state where the exact file or metadata is less likely to be resident in the fastest cache, while a warm run repeats the same request soon afterward. The absolute coldness is hard to guarantee on a live home server, so use labels and device observations rather than destructive cache flushing.
If you perform cache warming between benchmark runs, document that state deliberately. Repeat the same file, client, quality, and seek pattern and note how much backing-device or network activity disappears on the later pass.
If the warm run improves while backing-device reads fall sharply, cache is part of the gain. That is valuable user performance, but the cold result remains important for new titles, large libraries, and working sets that exceed the cache.
Watch the Backing Device While Plex Looks Fast
Player smoothness alone cannot tell you whether data came from RAM, an SSD cache, a metadata cache, or the original media disk. Pair user-visible timings with storage latency, read throughput, CPU, GPU, and network counters so the fast path has a physical explanation.
Increasing cache size does not automatically improve every Plex workload. Treat cache size as a hypothesis to test, not a substitute for measuring the slow storage, network, or compute resource beneath it.
For metadata browsing, compare app-state device I/O with poster and library timings. For media delivery, compare source-device reads with network output. Different caches can accelerate different parts of Plex at the same time.
Use a Working Set Larger Than the Cache for Sustained Tests
A capacity test should eventually force the system to serve data that cannot all remain in the fastest cache. Rotate through several large titles, alternate libraries, or run concurrent sessions long enough that the backing storage and network reach a steady pattern instead of replaying one hot segment.
Putting metadata on faster storage can improve browsing and library responsiveness while source media remains on slower disks. That is why the working set and data role must be named before a benchmark result is generalized.
If performance falls only after the test exceeds the cache, the lower steady rate is the stronger capacity number. If it remains stable and backing resources still have margin, the cache is helping without hiding a bottleneck.
Treat Repeated Fast Runs as a Cache Signal, Not a Failure
Caching is supposed to make repeated access faster, so the goal is not to force every production request onto disk. The goal is to know whether the cache is masking a resource that will fail when the workload changes, grows, or becomes concurrent.
The first run can warm cache and change later measurements even when the underlying device has not become faster. Label the cache state instead of pretending a live server has none.
When the decision specifically concerns repeated NAS reads, compare SSD read cache versus direct disk. A Plex capacity claim is credible only when the test describes cache state, working set, concurrency, and the backing resource that actually carried the load.
