How to Measure Immich Performance Without Mistaking Cache for Capacity
Immich capacity should be measured with repeated cold, warm, and sustained workloads because one fast cached run can hide the system’s real saturation point.
A home server can make a timeline or album feel extremely fast after the same thumbnails, database pages, and application data have already been touched. That result proves the warm path is efficient, not that the system can sustain a larger family library or more simultaneous activity. A useful capacity test must control cache state, enlarge the working set, repeat runs, and define a measurable stop condition.
Cache Speed Is Not the Same as Capacity
Capacity describes how much representative work an Immich system can sustain before latency, queues, or errors become unacceptable. Cache speed answers a narrower question: how quickly can the system repeat work after useful data or generated assets are already close at hand? If a benchmark repeats the same album or timeline, those two questions can look identical even though they are measuring different operating conditions.
The difference is easy to see in web performance, where first-view and repeat-view timings can diverge because later requests reuse cached resources. Immich has additional opportunities for warm behavior because thumbnails, previews, database pages, filesystem metadata, operating-system cache, and client assets may all be reused. A repeat run can therefore remove work that a growing or newly accessed library must still perform.
This is the same reason a cache-focused Home Assistant test can mislead when repeated requests dominate the sample; ZimaSpace's discussion of repeated-request cache layers applies to the measurement logic here. For Immich, record warm performance, but label it as a separate path rather than treating it as the server's general capacity.
Separate Cold, Warm, and Steady-State Runs
Start by defining the state before pressing the stopwatch. A cold run should include work that has not just been repeated, such as opening a different date range or asset set after caches have had less opportunity to help. A warm run deliberately repeats a known path. A steady-state run keeps representative activity going long enough to expose background work, resource recycling, and queues that a short burst may never reveal.
Warm-up itself can be deceptive. Percona describes cases where a database appears warmed while delayed background processes continue changing performance, so steady state arrives later than the first fast queries. Immich can similarly overlap foreground browsing with database activity, thumbnail work, indexing, or other queued jobs, depending on what the library is doing at the time.
For a home-server test, run each phase separately instead of averaging them together. Note whether background jobs are idle or active, keep the client and network path constant, and repeat the same phase several times. If the warm run is fast but sustained activity gradually raises latency or queue depth, the second result is the better signal for capacity planning.
Make the Working Set Larger Than Easy Cache
A benchmark that opens the same twenty photos is usually too small to answer a family-library capacity question. The operating system, database, client, and storage stack can keep a small hot set close to the processor, while real use jumps between months, people, albums, search results, and videos. The test set should therefore be large and varied enough that not every operation benefits from the same recently touched data.
Database benchmarking practice makes the distinction explicit: when a test intends to examine storage or cold behavior, residual cache can turn the exercise into a test of cache performance instead. You do not need to purge every cache layer on a production Immich server to learn something useful, but you do need a workload whose working set is broader than one repeatedly reused screen.
Choose several date ranges, albums, searches, and asset types that resemble normal household use, then rotate through them rather than hammering one view. Preserve that workload definition across hardware or configuration comparisons. If a change only improves a tiny repeated subset while broader navigation still degrades under load, it has improved the hot path without moving the useful capacity boundary.
Measure Percentiles and Repeat the Test
One average can hide the moments users actually notice. If nine requests are quick and the tenth stalls while a queue builds or storage is busy, the mean may still look respectable. Record at least median behavior and a tail percentile such as p95, then pair latency with throughput, error count, job backlog, CPU, memory pressure, and storage activity so the slowdown has context.
Practical benchmark analysis recommends reporting p50, p95, p99 and variance rather than trusting a single run, especially for stateful systems where cache eviction, compaction, or background activity may appear later. Immich tests do not need laboratory precision, but they do need enough repetitions to distinguish a repeatable limit from a lucky quiet interval.
Run the same scenario at least several times at each load level and keep the raw observations instead of keeping only the best pass. A capacity claim becomes more credible when p95 remains stable across runs and the server clears queued work between windows. If results swing widely, investigate the uncontrolled variable before declaring that more users, more photos, or faster hardware changed the ceiling.
Use an Immich Capacity Protocol With a Stop Condition
Begin with one representative client workload and capture a baseline after the system reaches the state you intend to test. Then increase one variable at a time: more simultaneous browsing, uploads, searches, or background processing, while keeping library, client mix, network path, and server configuration fixed. At each step, record p50 and p95 latency, successful operations per minute, errors, queue growth, and the main server resource that is approaching saturation.
This approach avoids the common mistake of drawing conclusions from one short pass. Performance testing guidance warns against single-run conclusions because warm-up, cache state, background work, and normal system noise can dominate a sample. Repeat each load level until the direction is stable enough to explain, not merely convenient enough to quote.
Use a declared stop rule before testing. A practical home-lab heuristic is to call the current configuration saturated when p95 latency stays above roughly twice the unloaded baseline for three consecutive measurement windows, or when errors or job backlog keep growing instead of recovering; this is a test heuristic, not an Immich limit. The useful capacity number is the last load level below that boundary, measured with the same cold, warm, and steady-state protocol.
