Why Does a Local Speech Model Lag Only When Wake-Word Detection Is Active?
A local speech model can lag with wake-word detection active because the always-on detector adds preprocessing, buffering, scheduling, and audio-handoff work.
Without a wake word, a user may press a button and send one clean recording directly to speech recognition. With wake-word activation, the home server continuously captures short audio frames, extracts features, scores a trigger model, retains pre-roll audio, and decides when to transfer control to voice activity detection and transcription. If those stages share CPU cores, audio devices, queues, or memory, the added gate can slow an otherwise fast local model even though the speech model itself has not changed.
Wake-Word Detection Adds an Always-On Inference Loop
A wake-word engine must inspect audio continuously rather than only after a user starts a recording. It repeatedly frames the signal, computes acoustic features, and evaluates a compact classifier.
Picovoiceโ€™s wake-word guide describes the detector as the persistent activation layer that runs before the larger voice pipeline.
Even a small model consumes scheduled CPU time and memory bandwidth. On a lightly provisioned home server, that continuous workload can steal the short bursts needed by VAD, Whisper, or text-to-speech.
Wake Words and Speech Recognition May Duplicate Audio Preprocessing
The detector and speech model may each resample audio, normalize amplitude, compute spectrograms, or convert channels independently. Separate containers can make that duplication difficult to observe.
A hands-on Whisper pipeline found that audio preprocessing stages accumulate latency when they are chained without a shared streaming design.
The pipeline becomes slower even when each component benchmarks well alone. Reusing one decoded audio stream and one supported sample rate removes conversions that add no recognition value.
Measure feature extraction and resampling separately from model inference so the detector is not blamed for work performed by an audio adapter.
Pre-Roll Buffers Can Delay the Handoff After Detection
A voice system usually keeps audio from immediately before the wake word so the beginning of the command is not lost. After detection, that buffer must be replayed or copied into the recognizerโ€™s stream.
Rhasspy users describe replay-buffer latency between trigger detection and the point where ASR begins receiving the command.
An oversized pre-roll, blocking copy, or full buffer flush can make the recognizer appear slow even though its first inference begins late.
Timestamp the trigger, first ASR frame, end-of-speech decision, and first transcript. The largest gap identifies whether the delay occurs before or inside recognition.
Shared CPU Cores and Audio Queues Create Contention
Wake-word detection, VAD, echo cancellation, transcription, and text-to-speech can all run on the same CPU. One stage can delay another through thread scheduling or a full audio queue.
A local voice-assistant build reports that end-to-end voice latency depends on the complete pipeline rather than only the language or speech model.
ZimaSpaceโ€™s explanation of hidden server saturation applies here: low average CPU can conceal one hot core or one serialized audio thread.
Pinning every component to separate cores is not always necessary, but queue depth, per-thread CPU, and processing time per audio frame should remain below the real-time frame interval.
False Triggers Can Launch Expensive Work Repeatedly
A false wake-word match may start VAD, load or wake the speech model, replay buffered audio, and wait for a command that never arrives.
A wake-word architecture article explains the need to balance false accepts against missed triggers and detection delay.
Frequent near-matches can keep the speech pipeline warm or busy, causing the real command to arrive behind abandoned sessions.
Log trigger confidence, trigger frequency, session duration, and whether usable speech followed. Raising the threshold helps only when it does not create unacceptable false rejects.
Benchmark the Detector and Handoff as Separate Latency Stages
Compare push-to-talk, wake-word enabled, wake-word enabled with ASR stopped, and wake-word enabled under normal background load. Use the same microphone, command, and speech model.
An engineering overview describes wake-word systems as cascaded streaming systems whose stages have separate compute and latency budgets.
Record audio-frame delay, detector time, queue wait, buffer replay, model wake-up, ASR prefill, and decoding. Then optimize the stage that changes when the wake word is enabled.
The practical fix may be a smaller detector, shared audio preprocessing, shorter pre-roll, bounded queues, dedicated threads, or keeping the speech model warm. Replacing the speech model is unnecessary when the lag occurs before it receives audio.
