Why Do Local RAG Answers Look Better on Narrative Documents Than on Spreadsheets?
Local RAG often answers narrative documents better because ordinary chunking preserves prose context but breaks the relational structure that gives spreadsheet cells meaning.
A policy paragraph carries its subject and qualifiers in nearby sentences, while โ€œ42โ€ in a workbook may depend on a row label, column date, unit, formula, and sheet name. When a home server converts both into plain text chunks, the narrative survives that transformation more faithfully than the grid and its hidden cross-cell relationships during grounded answer generation.
Narrative Chunks Carry Their Own Semantic Neighborhood
Prose repeats entities, verbs, and causal relations across adjacent sentences. A fixed-size chunk usually retains enough language for an embedding to represent the topic and for a generator to interpret the evidence. Overlap can preserve a sentence that straddles a boundary.
A table-first RAG approach notes that conventional RAG works well for narrative text but breaks when key information lives in tables and structures. The mismatch begins before generation, during representation and retrieval.
Narrative quality can still be deceptive: fluent passages encourage fluent answers even when the wrong chunk was retrieved. The comparative advantage is structural preservation, not a guarantee that prose answers are factually correct.
Spreadsheet Meaning Lives in Coordinates and Operations
A cellโ€™s meaning comes from relationships across axes. Flattening row by row may detach headers, merged labels, formulas, hidden sheets, or units. Embeddings then compare isolated strings rather than the operation a question asks, such as filtering one quarter and summing a category.
Research on table topology models text and table topology explicitly because hybrid documents contain connections that ordinary linear chunks lose. Preserving adjacency and hierarchy changes which evidence can be recovered.
Even perfect retrieval may not complete a spreadsheet question. The generator must select cells, respect data types, execute arithmetic, and cite coordinates. A language model that summarizes a paragraph well may still transpose columns or calculate over formatted display text.
Where Narrative RAG Loses Its Advantage
The narrative advantage disappears when documents contain dense cross-references, long appendices, or facts separated from their definitions. Conversely, spreadsheets with explicit headers, tidy rows, and a semantic query layer can be easier to answer than ambiguous prose.
A guide to tabular RAG evaluation emphasizes evaluation against table-grounded questions rather than generic text metrics. The answer should be checked against exact cells and operations.
The mechanism also fails if the narrative and spreadsheet pipelines use different OCR, embedding models, or permissions. In that case, format is confounded with tooling. โ€œBetter lookingโ€ is not equivalent to better grounded; both formats need answer-level verification.
Score Retrieval and Calculation as Separate Stages
Create paired questions from one narrative report and one tidy workbook: lookup, comparison, aggregation, and exception questions. Record the required passages or cell coordinates, then run both through the same model and retrieval budget. Score retrieval, calculation, citation, and final answer separately.
Use a local vector database to preserve vectors and source files locally while testing table-aware serialization against plain row text. Keep model temperature and prompt fixed.
If spreadsheet evidence is retrieved but arithmetic fails, add a structured execution step. If headers disappear before retrieval, repair extraction and serialization. If narrative answers only sound better but cite wrong passages, adjust evaluation rather than declaring the prose pipeline superior.
