Immich family experience depends on account boundaries because ownership, sharing, search context, and administrative power attach to identities, not households.
One family may want a common vacation album while each person keeps screenshots, documents, and personal memories separate. The useful design starts with who owns an asset, who may view or add to a shared space, and who can administer the server when relationships or devices change.
Separate Identity Creates a Durable Ownership Boundary
A separate account ties uploads and private library behavior to one person rather than one reused credential. That boundary affects which assets appear by default, who can remove them, and which sessions can be revoked. It also preserves accountability when several phones back up to the same server.
A family-setup discussion highlights tension between individual libraries and a desired shared family experience. The thread shows that sharing an album does not automatically reproduce every owner-specific timeline, memory, or search behavior for recipients, making identity design visible in daily use.
Define each household member as an identity before defining shared albums. Include children or guests only when their ownership and recovery needs justify accounts. More accounts are not automatically safer if passwords are reused, administrator privileges are broad, or inactive sessions are never removed.
Sharing Grants Collaboration Without Merging Every Library
A shared album can provide a selected collaboration surface while original ownership remains attached to contributors. This allows a holiday, school event, or family archive to be visible without exposing every private upload. The resulting experience is intentionally narrower than combining all personal libraries.
A Hacker News family-use account describes separate credentials alongside a shared photo timeline and contrasts account-based access with public links. Its practical lesson is that album links, partner-like visibility, personal ownership, and authenticated family sharing are different behaviors rather than interchangeable labels.
Create a shared space only after naming whether members should view, add, edit, download, or remove content. Test each action with non-sensitive media. If recipients need personal timeline behavior rather than a collaborative album, record that as a separate requirement instead of expanding permissions silently.
Administration Has a Larger Privacy and Recovery Blast Radius
The administrator maintains system settings, users, processing, and recovery-sensitive operations. That power is different from owning many photos or organizing a shared album. Using the administrator account on everyday family devices increases the effect of a stolen session, mistaken setting, or poorly secured browser.
The ZimaSpace authentication analysis distinguishes identity proof, session credentials, proxy paths, and authorization. For families, the distinction means a successfully authenticated household member should still receive only the application scope assigned to that identity; login success is not permission to see every asset.
Reserve administration for maintenance and keep each personโs routine client signed into a normal account. Document who can reset credentials, restore backups, and change remote access. A second trusted administrator may improve recovery, but duplicated powerful sessions also expand the attack and mistake surface.
Build a Household Permission Matrix
Create rows for adult, child, guest, and administrator identities. Add columns for private uploads, shared-album viewing, adding media, removing media, public link creation, account recovery, and server settings. Mark each cell allow, deny, or supervised before configuring the live library.
A community permissions case describes two partners adding their own photos to a shared album while observing what each can remove. The example demonstrates why permission testing must use actions, not labels: โeditorโ matters only through the exact ownership and removal behavior family members experience.
Test every important allow and deny cell with disposable assets, then repeat after logging out and revoking one session. Record who owns the resulting files and what remains visible after removal from a shared album. The matrix becomes the family policy and should be reviewed when devices or relationships change.
Why Does Immich Reprocess Existing Data After an Upgrade?
Immich may reprocess assets when an upgrade invalidates earlier derivatives, metadata, models, or job state; repeated endless work is a separate fault.
What Dependencies Most Often Set the Real Immich Performance Ceiling?
Immich is capped by the slowest dependency on each measured path, so upload, search, browsing, and playback can have different ceilings.
Immich Networking: How Discovery, DNS, and Routing Produce Reachability
Immich is reachable only when endpoint selection, DNS, routing, NAT or proxy handling, TLS, and application response form one valid path.
