A useful Jellyfin benchmark holds media, clients, quality, cache state, and competing workloads constant before comparing the same pass criteria.
A benchmark should answer a defined question: first-use startup, repeated browsing, sustained playback, or concurrent capacity. Cold and warm runs are different cases, and background jobs can change both. Name the workload and acceptance threshold before changing hardware so the result remains comparable.
Define the Workload Before Measuring
Choose the file, client, subtitle and HDR conditions, quality policy, concurrency, network path, and background services. Record playback mode and whether the test is cold or warm.
Use the cold and warm benchmark checklist to keep the workload definition separate from the hardware conclusion.
A repeatable workload is more valuable than a synthetic number that never represents the household.
Cold and Warm Runs Must Stay Separate
The first run measures storage fetches and working-set construction; repeated runs measure reuse. Mixing them into one average can make a cached result look like extra hardware capacity.
The cold and warm benchmark method records the first post-restart run and repeated runs independently.
Keep both values because first-use responsiveness and steady-state behavior are different user experiences.
Control Background Work and Confounders
Scans, backups, thumbnails, downloads, and another container can consume the same resources or evict useful pages. Pause them for a controlled baseline, then run a second case with normal services active.
Apply utilization and saturation so utilization, saturation, and errors remain tied to the named workload.
If the result changes only when a neighbor runs, that is a shared-resource finding rather than unexplained benchmark noise.
Set Pass Criteria Before Changing Hardware
Define acceptable startup time, search latency, dropped frames, buffer health, queue depth, and error count. Repeat each case several times and change one variable per comparison.
The dependency-first ceiling model dependency model helps identify which stage must pass before an upgrade is considered useful.
Stop when the target workload passes consistently with headroom. Do not average incompatible playback regimes into one score.
