Why Does a Home Voice Assistant Feel Slow Even When the LLM Responds Quickly?
A home voice assistant can feel slow because speech capture, endpointing, tools, synthesis, and playback surround the LLM with serial delays.
A local model may produce its first token in 120 ms, yet the kitchen speaker answers two seconds after a command ends. The user experiences the entire turn, not one benchmark. Silence detection before the prompt and audio buffering after the response can each outweigh fast language-model inference.
The LLM Owns Only One Segment of the Voice Turn
A spoken turn passes through microphone buffering, voice-activity detection, endpointing, ASR, prompt assembly, model generation, tool execution, TTS, and audio output. Most stages wait on the previous one. A low time-to-first-token therefore proves only that the language stage is fast after text arrives.
A voice-stack latency analysis breaks the path into multiple latency stages, showing why optimizing one component does not guarantee a fast conversation. Serial overhead accumulates even when every individual stage looks modest in isolation.
Endpointing is often the hidden front-end cost. The assistant must decide whether a pause means the speaker has finished or is thinking. A conservative timeout prevents interruptions but adds silence before ASR finalization, so the system feels hesitant even though the LLM starts immediately afterward.
Streaming Moves Perceived Speed Without Removing All Work
Partial transcripts can start prompt preparation, and streaming tokens can feed TTS before the answer is complete. These overlaps shorten the critical path. However, chunk sizes, safety checks, tool confirmation, and the amount of stable text required before synthesis still determine when audible output begins.
Research on low-latency voice agents combines streaming ASR, quantized language models, and real-time synthesis because end-to-end responsiveness depends on coordinating all three rather than reporting model speed alone.
The first sound also matters more than the final audio duration. A system that begins a natural response at 500 ms can feel faster than one that silently completes the full answer in 900 ms. Streaming changes feedback timing, but it does not make a slow tool call disappear.
Where the Pipeline Explanation Stops Applying
Pipeline delay is not the full explanation when the assistant intentionally waits for confirmation, rate-limits commands, or applies a conversational pause. Network jitter, speaker power saving, Bluetooth reconnection, and audio-device wake time can occur outside the AI stack. A fast trace inside the server may still end at a slow room speaker.
Conversational latency guidance notes that people expect short turn gaps, making perceived response timing a product-level property rather than a single-model statistic. Perceived delay can rise even when total compute time is unchanged if feedback is withheld.
This mechanism fails when server timestamps show audio playback beginning promptly but users still report delay. Then acoustic distance, device synchronization, or interface feedback may be responsible. It also cannot explain a slow first command followed by fast ones, which more strongly suggests cold starts or power-state transitions.
Measure the Whole Voice Turn, Not Only the LLM
Log one monotonic timestamp at microphone onset, detected endpoint, final transcript, prompt dispatch, first LLM token, tool completion, first TTS chunk, playback queue, and audible output. Run twenty short commands plus five tool-using commands after both cold and warm starts.
Compare those traces with local AI cold starts because model loading can distort the first turn while endpointing dominates later turns. Preserve raw timings rather than one combined “response time” value.
Optimize the largest repeatable interval, not the most visible model. If endpointing dominates, tune turn detection; if tools dominate, prefetch only safe data; if first audio trails TTS, inspect buffering and speaker wake. Keep confirmation delays explicit because deliberate safety is not performance failure.
