GPU utilization gaps usually appear when the continuous-batching scheduler cannot assemble runnable work or feed the accelerator without a dependency stall.
A home LLM server can report high throughput yet show periodic GPU valleys between decode iterations. Continuous batching removes finished sequences and admits new ones, but it cannot create work when arrivals are sparse, KV blocks are unavailable, long prefills block decode, or the CPU runtime prepares batches too slowly. Synchronization and memory movement can add gaps even with a full request queue.
Request Supply and Sequence Turnover Can Empty a Batch
Continuous batching replaces finished sequences at iteration boundaries. If arrivals are bursty, outputs finish together, or admission limits hold requests outside the runnable queue, the active token count can fall below the GPUโs efficient operating range.
Benchmarks of continuous batch membership compare static and continuous request membership under varied input lengths, output lengths, and arrival times. The signature is low runnable-token count during utilization gaps despite a healthy accelerator and no memory error.
A queue that is genuinely empty is not a scheduler defect. Compare arrival rate, admitted sequences, and tokens scheduled per iteration before interpreting every idle interval as lost capacity. This distinction remains visible during later household testing.
Prefill, Decode, and KV Allocation Create Scheduler Bubbles
Prefill processes many prompt tokens with compute-heavy kernels, while decode advances each sequence by one token and is often memory-bound. Mixing the phases can delay decode, and reserving or reclaiming KV blocks can pause admission between iterations.
The chunked prefill scheduling design uses chunked prefill to prevent long prompts from monopolizing serving iterations. Its mechanism identifies gaps that correlate with prefill boundaries, KV allocation, or request preemption rather than weak demand. The intermediate result must remain inspectable before automation follows.
If GPU gaps expand with prompt length but not output length, prefill scheduling is the stronger cause. If they track cache pressure or evictions, memory admission is responsible even when the queue remains full. That boundary should be measured separately under realistic operating conditions.
CPU Feeding and Cross-Device Synchronization Can Starve Kernels
Tokenization, sampling, scheduler decisions, tensor metadata, host-to-device copies, distributed collectives, and logging occur outside the main kernels. A saturated CPU thread or blocking synchronization can leave the GPU waiting between otherwise valid batches. The practical consequence appears when several sources compete for limited context.
Research on prefill-decode interference separates prefill and decode resources to reduce interference and meet latency targets. The result reinforces that one utilization graph combines scheduler, host, communication, and accelerator behavior. This dependency should remain explicit in the final interface.
The failure boundary is a short sampling interval that reports normal kernel boundaries as zero utilization. Confirm gaps with a trace or hardware counters; dashboard averaging can create apparent valleys that do not reduce tokens per second.
Align Queue, Scheduler, and Kernel Timelines
Replay controlled steady and bursty arrivals while recording waiting, admitted and running requests, prompt and decode tokens per iteration, KV free blocks, preemptions, CPU scheduler time, tokenization, sampling, copies, collectives, kernel launch gaps, GPU clocks, and output throughput.
Compare the pattern with continuous batching behavior, then vary arrival rate, prompt length, chunked prefill size, cache budget, and CPU affinity one at a time. Preserve model, quantization, and latency target. The result must therefore be checked against the original evidence.
Classify each valley as no demand, admission stall, prefill interference, cache pressure, host starvation, or synchronization before tuning. Optimize the responsible boundary; forcing a larger batch cannot fix an empty queue or blocked host thread.
What Causes an AI Agent Planner to Repeat Steps It Already Completed?
Trace repeated planner steps through state persistence, completion evidence, tool-result parsing, context retention, retries, replanning, and stop conditions.
What Causes Permission Errors Only Inside AI Agent Subprocesses?
Compare parent and child identity, filesystem view, environment, capabilities, security policy, and executable path to diagnose subprocess-only denial.
What Causes CPU Saturation When Hardware Transcoding and Video AI Run Together?
Trace CPU saturation across codec offload, pixel conversion, frame copies, AI preprocessing, audio, subtitles, storage, and process scheduling.
