Why Does GPU Power Spike at the Start of a Local Inference Request?
GPU power often spikes at request start because clock ramp-up and highly parallel prompt prefill activate more compute at once than token-by-token decoding.
A home server can idle quietly, jump near its GPU power limit for a short interval, then settle while the model streams tokens. The transition combines device power-state changes, memory allocation, kernel initialization, and prefill over the prompt. Model size, prompt length, batch size, clock policy, quantization, measurement interval, and other accelerator workloads determine the height and duration of the observed spike.
The GPU Leaves Idle State as Work Arrives
Modern GPUs lower clocks and voltage when lightly used, then raise them as kernels and memory traffic appear. The first request may also create a device context, initialize libraries, allocate buffers, and load kernels, concentrating one-time activity around the same start window.
request-start power spikes characterizes power-management opportunities for LLM workloads and reports power spikes at the beginning of inference requests. The study links those spikes to the compute-intensive prefill phase and examines how GPU frequency affects latency and power.
A monitoring sample can exaggerate or hide the shape. A one-second average may merge clock ramp, prefill, and early decode into one point, while a slow smart plug may miss the GPU event entirely or report only the delayed whole-system response.
Prefill Uses Parallel Compute Differently From Decode
Prefill processes the prompt tokens together to build the KV cache, exposing matrix multiplications that can occupy many GPU cores. Decode advances one token per sequence and is often more constrained by memory movement and sequential dependency, especially at batch size one.
phase-aligned power measurement aligns GPU, node, and system power samples with prefill and decode for each request. Its phase-aware method shows why one energy total cannot explain when peak power occurs or which prompt and serving variables produced it.
Longer prompts or larger batches can extend the high-utilization interval, while quantization and fused kernels change both compute and memory demand. Peak watts, average watts, and joules per completed token answer different questions and should not be substituted for one another.
Power Limits Reshape the Spike Rather Than Removing Work
A lower power or frequency limit can reduce the instantaneous peak, but prefill may take longer. Total energy may fall, stay similar, or rise depending on efficiency at the selected operating point and whether the slower request delays other queued work.
phase-aware frequency control controls frequencies separately for prefill and decode while protecting latency objectives. Reported energy savings demonstrate that phase-aware control can outperform one fixed policy, but the result depends on workload classes and service-level constraints.
The failure boundary is equating a brief GPU spike with unsafe wall power. The PSU sees the whole system, including CPU, drives, fans, and conversion losses, while software sensors report chip power with their own cadence. Electrical safety decisions require wall-level measurement and transient margin.
Align Power Samples With Inference Phases
Run fixed prompts at 32, 512, 2K, and 8K input tokens with constant output length, then repeat at two batch sizes. Capture GPU power, clocks, utilization, temperature, host wall power, request arrival, model readiness, prefill start and end, first token, and decode completion.
Use the phase distinction in home-server startup power to calculate peak watts, prefill joules, decode joules, joules per token, TTFT, and p95 inter-token latency. Repeat once with a power limit and once after a long idle interval.
Keep a power policy only if it respects wall-power margin, temperature, and latency together. If lowering the peak lengthens prefill enough to increase energy or queue delay, treat the smoother graph as a cosmetic improvement rather than an efficiency gain.
