How Much GPU Memory Is Needed for Vision-Language Search on a Home NAS?
Vision-language search can start around 8–12GB VRAM, but model size, quantization, image tokens, context length, and concurrency determine the reliable floor.
A compact 7B-class quantized model may load on an 8 GB GPU, yet fail when several high-resolution images and a long chat history are processed together. Search also may use a separate image encoder and reranker. Capacity must include peak runtime allocations, not just the model file size shown on disk during the busiest expected query pattern.
Weights Set the Floor, Not the Peak
Theoretical weight memory is parameter count multiplied by bits per parameter. Seven billion parameters at four bits are about 3.5 GB before scales, metadata, framework buffers, and any unquantized layers. An image encoder may be separate or integrated into the model.
A practical explanation of GPU memory components separates model weights from KV cache, activations, and runtime overhead. File size alone therefore understates inference memory.
Quantization reduces weight residency but does not shrink every allocation equally. Vision projections, temporary attention buffers, and some kernels may remain in 16-bit precision. A model that barely loads leaves no margin for real image queries.
Images Become Tokens and Runtime State
Vision encoders divide or resample images into patches, then pass visual tokens to the language model. More images, higher accepted resolution, or dynamic tiling increase token counts. Those tokens expand attention work and, in autoregressive stages, KV-cache demand.
Research on visual instruction tuning shows how images are connected to language models through learned visual representations. Architecture and preprocessing decide how many visual features enter the context.
Batching several searches multiplies active image and text state even when weights remain shared. This is why an 8–12 GB tier suits compact single-user search, while 16–24 GB gives more room for larger models, multiple images, or concurrent requests.
Where VRAM Recommendations Stop Applying
Unified-memory systems, CPU offload, split encoders, and disk-backed embedding search change the constraint. Offload may make a model run with less VRAM but increase latency. Precomputed image embeddings need far less runtime vision work than generating descriptions for every query.
A discussion of KV-cache allocation illustrates how context length and KV-cache allocation can force smaller limits even when weights fit. Multimodal inputs tighten the same budget.
The ranges also fail for training or fine-tuning, which requires gradients and optimizer state. They describe inference only. More VRAM does not ensure accurate search if image embeddings, OCR, metadata fusion, or evaluation are weak.
Verify Peak VRAM With Representative Image Queries
Load the intended quantized model, encoder, and reranker, then run representative one-image, multi-image, high-resolution, and long-history queries. Repeat at planned concurrency while recording allocated and reserved VRAM, out-of-memory events, first-token latency, and image-processing time.
Test with a image pipeline bandwidth dataset that reflects creator images and screenshots rather than synthetic blank inputs. Keep precomputed and live-encoding paths separate.
Select a VRAM tier whose worst valid query remains below roughly 80–85 percent of capacity. If only image encoding spikes, move that encoder or precompute embeddings. If KV cache dominates, cap context or concurrency before assuming a larger vision model is required.
