What Factors Cause False Presence Detection in a Smart Home?
False presence appears when a sensor observes its physical proxy correctly but the automation interprets that proxy as a person who is not there.
A hallway light may turn on for warm airflow, while a phone that remains connected to Wi-Fi keeps the home marked occupied after its owner leaves. These are different causal failures, even though the dashboard shows the same state. Reliable diagnosis separates sensor physics, identity proxies, stale timing, room topology, and fusion rules before changing a global sensitivity threshold.
Environmental Motion Can Resemble Human Motion
Passive infrared sensors detect changes in thermal radiation, not people directly. Sun-warmed curtains, HVAC airflow across a temperature boundary, pets, reflections, and rapidly changing ambient temperature can generate a motion-like signal inside the sensor’s zones.
A broad PIR occupancy limits review notes that temperature changes, ventilation, pets, limited fields of view, and stationary occupants complicate PIR-based occupancy prediction. Combining independent sensing types can reduce some false positives, but it also creates new timing assumptions.
The signature is usually sensor-local: one device fires without a matching door, radar, light, or device-presence transition. Compare raw sensor values and environmental state rather than treating every binary motion event as equivalent evidence. This distinction remains visible during later household testing.
Radio and Device Proxies Can Outlive the Person
Wi-Fi association, Bluetooth beacons, GPS geofences, and app heartbeats represent a device, not its owner. A phone left at home, a watch moving between access points, cached router state, or delayed cloud updates can hold presence true after the person has moved.
Research on multimodal occupancy sensing shows that occupancy systems combine many sensing modalities with different ranges, delays, and privacy properties. A fusion rule must therefore model freshness and identity instead of counting all observations equally.
Radar and Wi-Fi channel sensing also face multipath: movement outside a room or through a wall can alter reflected radio energy. Zone calibration, antenna placement, and a dwell-time model determine whether those changes become an occupied state.
Fusion Timing Can Turn Weak Evidence Into a Strong Mistake
Presence engines often combine motion, doors, devices, power use, and environmental changes across a time window. If stale events are treated as simultaneous, several individually weak signals can cross a confidence threshold long after their shared explanation expired.
A personalized personalized home context study of smart home automation emphasizes that household behavior varies and must be learned from contextual data. That variability makes fixed universal thresholds especially vulnerable to schedule changes and guests.
The failure boundary is a hidden state with no immediate ground truth. Lowering sensitivity may suppress false positives while increasing dangerous false absences. Diagnose by cause class and room, preserve an unknown state, and avoid using one presence score for both convenience lighting and security decisions.
Run a Cause-Isolation Presence Test
Record raw signals for scripted empty-room and occupied-room trials involving HVAC cycles, sunlight, pets, phones left behind, visitors, slow movement, sleep, and transitions through adjacent rooms. Synchronize clocks and mark ground truth independently. The intermediate result must remain inspectable before automation follows.
Apply the multi-signal principle in multi-signal presence fusion, then disable one sensor family or shorten one freshness window at a time. Measure false-presence duration, false-absence duration, transition delay, unknown-state time, and automation impact by room and cause.
Change only the layer whose signature matches the error. If a stale phone causes occupancy, PIR sensitivity is irrelevant; if warm airflow triggers one hallway sensor, rewriting whole-home fusion can conceal the local physical problem.
