What Is an Egress Allowlist, and What Data Paths Does It Not Control?
An egress allowlist restricts which outbound network endpoints a workload may reach, but it does not determine what data travels through an approved path.
A self-hosted agent can be blocked from arbitrary internet hosts while still calling a weather API, model endpoint, or update server. That reduces reachable destinations, yet sensitive text can still leave through an allowed request, shared DNS service, mounted folder, browser session, removable device, or another trusted process. The control is a network-route boundary, not complete data-loss prevention.
The Allowlist Turns Outbound Reachability Into Default Deny
The policy selects a workload and permits only named IP ranges, ports, protocols, domains, proxy routes, or service identities. Everything else should fail closed at the enforcement point rather than relying on the agent to obey instructions.
Kubernetes explains that egress network policies select permitted pod connections and that default-deny egress also blocks DNS unless explicitly allowed. Enforcement depends on the network plugin and the traffic it can observe. This distinction remains visible during later household testing.
An IP rule, domain rule, and application proxy express different objects. Dynamic cloud addresses, content-delivery networks, redirects, IPv6, and encrypted DNS can make a simple hostname list diverge from actual connections. The intermediate result must remain inspectable before automation follows.
Approved Destinations Remain Full Data Channels Unless Inspected
If an agent may POST to an allowed API, the policy usually sees destination and transport metadata but not whether the payload contains a private document. TLS further hides content from network-layer enforcement unless traffic terminates at a controlled proxy.
A Red Hat explanation compares workload firewall rules to workload firewalls that restrict known communication patterns. That scope controls connectivity, not prompt content, tool arguments, or authorization inside the destination service. That boundary should be measured separately under realistic operating conditions.
Application-layer gateways can enforce method, schema, size, account, and data classification, but they become trusted processors and still require correct parsing. Allowing a general browser or storage endpoint creates a much broader channel than allowing one bounded API.
Local, Indirect, and Covert Paths Sit Outside Basic Egress Rules
Network egress policy does not restrict reads from mounted files, writes to shared NAS folders, clipboard transfer, USB media, local logs, screenshots, audio output, or data handed to another process that has broader network rights.
An analysis of DNS and connection paths notes that domain-based access may still leave DNS requests unaffected while blocking later connections. It illustrates how name resolution and destination enforcement can occupy separate data paths. The practical consequence appears when several sources compete for limited context.
The failure boundary is assuming an allowed destination is safe or that blocked internet access creates a complete trust boundary. DNS labels, request timing, logs, and approved uploads can leak information unless separate file, process, identity, and content controls constrain them.
Map Every Route From Sensitive Input to an External Observer
List direct sockets, DNS, proxies, allowed APIs, browser automation, webhooks, update channels, mounted shares, IPC, logs, clipboard, USB, audio, screenshots, and delegated subprocesses for one agent workflow. This dependency should remain explicit in the final interface.
Place that map inside the AI trust boundary. Test arbitrary hosts, IP literals, redirects, DNS labels, oversized allowed payloads, alternate protocols, handoff to a privileged process, and local export paths. The result must therefore be checked against the original evidence.
Call the allowlist effective only for routes it actually mediates. Protect remaining paths with least-privilege filesystems, capability-scoped tools, schema validation, content controls, user approval, and audit trails. This distinction remains visible during later household testing.
