Document embeddings shift after an OCR language update because the new recognizer changes the text, token boundaries, or layout supplied to the encoder.
A scanned invoice can look identical while its extracted text changes from one OCR run to the next. A better language model may repair accents and words, but it may also split compounds differently, reorder columns, or recognize numerals under another script. Chunk hashes, token sequences, vector positions, and nearest neighbors then change materially downstream.
The Language Pack Changes the Recognized Symbol Sequence
OCR combines visual evidence with a language-specific character set, lexicon, and sequence model. Updating those components can replace confusable glyphs, alter diacritics, join or split words, and select another script for the same ambiguous region.
A multilingual OCR training framework shows that language-aware training changes OCR completeness and robustness for small, blurred, and spatially scattered text. Those improvements necessarily alter the strings consumed by later retrieval stages. This distinction remains visible during later household testing.
Even corrections move embeddings because encoders tokenize the new string differently. One repaired product code may matter more than several punctuation changes when the query depends on that identifier, so vector distance does not map directly to character-error percentage.
Layout and Chunking Amplify Small OCR Differences
OCR output is normally converted into reading order, paragraphs, tables, and chunks before embedding. A changed line break or column assignment can move sentences across chunk boundaries, replacing much more of the encoded context than the edited characters alone suggest.
Research on spatial OCR relationships argues that one-dimensional reading order can misrepresent spatial relationships among OCR words. The result explains why updated layout or language processing can reorganize the semantic neighborhood even when the page image is fixed.
Chunking by token count adds another discontinuity. If corrected words consume different token counts, later boundaries shift and every subsequent vector may contain a different mixture of sentences until a stable section boundary resets the process.
A Better OCR Result Can Still Reduce Retrieval Stability
Improved text may move a document toward its true semantic neighborhood, but a mixed index containing old and new OCR vectors becomes internally inconsistent. Duplicate pages can rank differently solely because they were processed under different pipeline versions.
A study of OCR-aware hybrid retrieval enhances noisy OCR text before sparse and dense search and reports improved retrieval without changing the retrieval architecture. It demonstrates that text quality upstream affects both lexical matching and vector representation downstream.
The failure boundary is attributing every vector change to the language pack. Parser versions, normalization, embedding models, chunk size, floating-point kernels, and index quantization can also move vectors. Freeze those stages and compare extracted text first before naming OCR as the cause.
Version and Replay the OCR-to-Embedding Pipeline
Select pages containing accents, mixed scripts, tables, handwriting, product codes, and clean monolingual text. Run old and new language packs on identical images while freezing parser, normalizer, chunker, embedding model, precision, and index settings. The intermediate result must remain inspectable before automation follows.
Compare character edits and layout changes with OCR inconsistency, then record reading order, chunk boundaries, token counts, cosine shift, nearest-neighbor overlap, retrieval recall, and citation correctness. Separate improvements from merely different vectors. That boundary should be measured separately under realistic operating conditions.
Reindex a collection consistently only when the new OCR version improves held-out retrieval or evidence quality. If some languages regress, retain versioned outputs or route pages by detected language; never mix unlabelled OCR generations and call ranking changes model drift.
