One home AI model may serve one to several interactive users reliably, but the stable limit depends on token demand, batching, and latency targets.
A model producing 30 tokens per second may feel fast for one short chat yet stall when four people submit long prompts together. Concurrency consumes KV-cache memory, shares decode capacity, and creates queueing bursts. The correct limit is the highest offered load that still meets a defined p95 first-token and token-rate target during normal family use.
Concurrency Converts Throughput Into Waiting Time
A rough capacity estimate divides sustained generation throughput by the average tokens requested per second across active sessions. If demand approaches service capacity, small bursts create long queues. Users are not identical units; a 50-token answer and a 2,000-token answer occupy the server differently.
An analysis of latency and throughput explains that batching improves aggregate throughput while often trading against individual response latency. That tension determines whether additional sessions feel stable.
Prompt prefill can also block decode work, depending on the scheduler. Two users pasting large documents may hurt everyone more than six users asking short questions. A user count without prompt and output distributions is therefore not portable.
KV Cache and Scheduling Create a Second Limit
Each active sequence stores attention keys and values for its context. Longer histories and larger batches raise KV-cache use until requests are rejected, swapped, or delayed. Continuous batching can admit new work between decode iterations, improving utilization but not creating free memory.
A technical explanation of continuous batching shows how iteration-level scheduling fills otherwise idle batch slots. The benefit is workload-dependent and can slightly raise per-request contention.
Latency becomes unstable near saturation because queue length reacts sharply to arrival variance. Average latency may climb gradually while p95 and maximum latency jump. Stable capacity should sit below that knee rather than at the benchmark’s highest tokens-per-second point.
Where a User Count Stops Predicting Experience
The same server can support more users for autocomplete than for RAG, tool use, or long-form generation. Cold starts, thermal throttling, retrieval, and speech synthesis add stages outside model serving. A model-only concurrency figure cannot guarantee whole-application responsiveness.
A serving guide on serving memory describes memory, context, batching, and parallelism as interacting constraints. Changing any one can move the capacity knee.
The prediction also fails if family requests arrive in synchronized bursts rather than independently. Four users who rarely overlap may be easy, while two automated agents can saturate the model continuously. Measure offered work, not registered accounts.
Find the Concurrency Knee With a Load Test
Replay realistic short, median, and long requests at one, two, four, and eight concurrent sessions. Hold model, quantization, context cap, and sampling fixed. Record queue time, first-token latency, inter-token latency, completion rate, KV-cache use, and p50, p95, and maximum values.
Use the shared model sessions architecture as the test context when several household sessions share one model. Keep RAG and tool stages either disabled or timed separately.
Declare the stable limit as the highest concurrency whose p95 first-token latency stays inside the household target with no rising queue trend or memory errors. Keep 20–30 percent throughput headroom for bursts. Retest whenever context length, model, or scheduler changes.
How to Measure Local RAG Retrieval Quality and Interpret Recall, Precision, and Citation Coverage
Build a local RAG test set, calculate core retrieval metrics, interpret their tradeoffs, and audit whether answer claims are supported by cited evidence.
Why Does Smart Home Feature Computation Matter More as Sensor Count Increases at the Same Sampling Rate?
Trace per-sensor and cross-sensor compute as device count rises, identify nonlinear fusion costs, and benchmark the feature pipeline before automations lag.
Why Does RAG Evaluation Cost Matter More as the Document Library Grows at the Same Query Volume?
Understand why corpus growth raises RAG evaluation effort without more user queries and how stratified tests keep cost tied to risk.
