Color depth multiplies creator NAS demand by increasing the bits stored and transferred for every sampled color channel in every frame.
The multiplier affects camera originals, mezzanine files, image sequences, render caches, proxies, and simultaneous timeline streams, but it does not create one universal file-size ratio because codecs, chroma subsampling, resolution, frame rate, and encoder targets can outweigh bit depth in compressed media. Creators therefore need to separate raw sample math from actual codec bitrate before applying the result to storage capacity, sustained throughput, cache growth, and concurrent editors. The sections below build that calculation in stages.
What Changes When Media Moves From 8-Bit to 10-Bit or 12-Bit?
Bit depth describes how many binary digits represent each sampled channel value. Eight bits provide 256 levels per channel, ten bits provide 1,024, and twelve bits provide 4,096, giving image processing more intermediate values.
higher bit depth provides more tonal precision for grading, compositing, and HDR work. The number of possible colors rises rapidly, but storage grows according to bits stored per sample, not according to the total count of possible colors.
Ten-bit video is therefore not four times larger than eight-bit video simply because it has four times as many code values per channel. The storage comparison starts with 10 stored bits versus 8.
How Much Does Equal-Sampling Raw Data Increase?
Hold resolution, frame rate, channel count, and chroma sampling constant. The raw-data ratio then follows the bit-depth ratio: 10/8 equals 1.25, 12/8 equals 1.5, and 12/10 equals 1.2.
At equal sampling, ten-bit video uses 25 percent more raw data than eight-bit video, while twelve-bit uses 50 percent more. The same increase applies to every frame and repeats across the clip duration.
A raw or lightly compressed stream requiring 400 MB/s at eight bits would therefore require about 500 MB/s at ten bits before filesystem, protocol, and safety headroom. Capacity and throughput rise together because both store or move the same extra sample bits.
Why Do Compressed Files Not Follow the Same Fixed Ratio?
A codec predicts spatial and temporal patterns, transforms residual information, quantizes detail, and allocates bits according to a quality or rate target. It does not store every source sample independently.
This creates a codec-dependent bitrate rather than a guaranteed 25-percent file-size increase. A ten-bit encoder can preserve gradients more efficiently, while a high-quality ten-bit mezzanine can still be far larger than an eight-bit delivery encode.
Plan compressed storage from the measured or specified codec bitrate. Use raw ratios only when the formats keep the same sampling and compression assumptions.
How Do Resolution, Frame Rate, and Chroma Sampling Compound the Cost?
Each variable repeats the work of the others. More pixels increase samples per frame, higher frame rate increases frames per second, fuller chroma retains more color samples, and higher bit depth increases bits per sample.
The relationship between color depth and channels explains why higher precision applies across the whole sample grid. A 4K60 ten-bit 4:2:2 stream is not merely “two bits heavier” than an eight-bit file; the extra bits repeat across every retained luma and chroma sample.
The effect is especially visible in image sequences and lightly compressed intermediates, where individual frames retain much of their original sample structure.
Compression, subsampling, and alpha channels can change the final product, so compare formats only after all four variables are stated.
Why Does Multicam Editing Multiply NAS Demand Again?
A timeline can read several sources at once even though the viewer displays one composite frame. Multicam previews, stacked effects, transitions, picture-in-picture layouts, and background analysis add concurrent reads.
The active stream count multiplies the per-file requirement. Four 250 MB/s sources already demand roughly 1 GB/s before waveform caches, preview renders, project traffic, and another editor are included.
The storage pool and network must both sustain the total. A 10GbE port cannot compensate for a disk tier that stalls under several simultaneous reads, and a fast NVMe tier cannot exceed the client’s negotiated link.
How Should Creators Balance Precision, Proxies, and Capacity?
Keep the precision needed for acquisition, keying, VFX, aggressive grading, HDR, and mastering, but avoid forcing the highest-bit-depth representation through every interactive stage when it adds no useful editing value.
Many hybrid workflows combine protected originals on the NAS with proxies, previews, and local scratch storage. This lowers day-to-day bandwidth without shrinking the original or its backup requirement.
Capacity planning should therefore list originals, proxies, preview renders, cache growth, backups, and version retention separately. A proxy saves active bandwidth but adds another stored representation that must be managed and relinked correctly.
Is every 10-bit file 25 percent larger than an 8-bit file?
No. The 25-percent figure applies to equal uncompressed sampling. Codec, bitrate target, chroma format, frame rate, and image complexity determine compressed size.
Does a ten-bit monitor reduce NAS bandwidth?
No. Display precision and stored-media precision are separate. The monitor does not change the source data the editing application reads.
Can proxies be eight-bit when the originals are ten-bit or twelve-bit?
Yes, when the proxy preserves enough visual information for editorial decisions and the project reconnects to the higher-precision originals for finishing.
