Clock synchronization improves multi-camera correlation by placing independent frame and detection timestamps on a common timeline before events are associated across views.
A person may cross a driveway camera and reach the front door seconds later, yet two unsynchronized cameras can stamp those observations in reverse order. The NVR also receives each stream after different network and decode delays. Correlation works best when it compares normalized capture time, not arrival or inference-completion time, within a window that includes residual uncertainty.
Clock Offset Moves Simultaneous Observations Apart
Each camera timestamps frames using a local clock whose current value may differ from the NVR and other cameras. Even a fixed offset can place the same flash, person, or vehicle outside a shared event window.
A study of multi-sensor time synchronization separates clock alignment from later multimodal processing and demonstrates why independently captured streams need a common time reference. Capture timestamps become comparable only after offset estimation or synchronization. This distinction remains visible during later household testing.
Sorting detections by NVR arrival time does not repair capture offset because network jitter and buffering add different delays. The system needs to retain both capture and processing clocks. The intermediate result must remain inspectable before automation follows.
Drift Changes the Offset During Long Recording Periods
Oscillators run slightly fast or slow, so a calibration measured after reboot can become wrong hours later. Periodic time updates may correct gradually or step the clock, creating discontinuities that event correlation must recognize. That boundary should be measured separately under realistic operating conditions.
Research on cross-view temporal alignment uses cross-view tracks and geometry to estimate temporal alignment between cameras. The approach illustrates how shared physical motion can reveal timing error when hardware synchronization is unavailable. The practical consequence appears when several sources compete for limited context.
A constant correction fits offset but not drift. Long-term systems should estimate error over time or monitor synchronization quality instead of assuming one startup measurement remains valid. This dependency should remain explicit in the final interface.
Residual Uncertainty Expands Association Windows and Ambiguity
After synchronization, exposure timing, frame rate, encoder reordering, buffers, and detector latency still introduce uncertainty. Correlation windows must be wide enough to contain the true sequence but narrow enough to avoid joining unrelated people or vehicles.
A multi-camera subframe camera alignment analysis shows how subframe alignment links independent streams to a common time base. Its results reinforce that timestamp precision and identity association interact rather than solve one another. The result must therefore be checked against the original evidence.
The failure boundary is confusing clock agreement with object identity. Perfectly synchronized cameras can still associate the wrong similar-looking person, while unsynchronized views may correlate correctly when spatial paths and appearance are distinctive. This distinction remains visible during later household testing.
Reconstruct One Shared Event Across Every Clock Domain
Record camera wall clock, capture PTS, NVR arrival, decoder output, detector completion, tracker event, correlation window, and summary time for a visible shared flash or doorway crossing. The intermediate result must remain inspectable before automation follows.
Use multi-camera timeline errors to separate offset, drift, and pipeline delay. Repeat immediately after synchronization, several hours later, during network congestion, and after a camera reboot. That boundary should be measured separately under realistic operating conditions.
Normalize association to capture time, store residual error, and widen windows only from measured uncertainty. Reject cross-view joins when timing and identity evidence do not jointly support the same physical event. The practical consequence appears when several sources compete for limited context.
