Agent overhead grows with workflow length because every step adds tool waiting, context, validation, state transfer, and another opportunity for retries.
A 7B local model may answer a direct request quickly but take much longer when it must search, parse, calculate, write, and verify in sequence. Model weights remain unchanged. The workflow adds serial dependencies and feeds each result back into later prompts, increasing both wall time and tokens processed across a complete successful execution trace.
Serial Tool Waits Add Even When Inference Is Constant
For a strictly dependent workflow, total latency approximates the sum of model turns, tool calls, serialization, and queue waits. Five 400-millisecond tools add two seconds before extra reasoning. A slow outlier can dominate the whole path.
A 2026 survey of agent tool use describes linear or worse latency accumulation when later inference waits for earlier tool results. Parallelism helps only when dependencies are genuinely independent.
Each boundary also converts arguments and results, checks schemas, and may cross a process or network. Model size explains inference cost per turn, but not the number or duration of orchestration boundaries.
Returned Data Enlarges Later Model Turns
Tool outputs are often appended to context. Later steps reread prior observations, plans, and errors, so token processing can grow with depth. A verbose first result taxes every downstream turn unless it is filtered or summarized safely.
An analysis of agent execution tax reports that planning, execution, verification, and handoffs can consume many times the tokens of a direct completion. The waste fraction is an execution property, not model intelligence.
Validation adds useful overhead by preventing unsafe action, but redundant checking can loop. Caching read-only results helps only when freshness and user scope are preserved. Faster models cannot remove an unnecessary dependency graph.
Where More Steps Do Not Mean Proportionally More Cost
Independent tool calls can run concurrently, deterministic transforms may bypass the model, and cached results can eliminate repeated work. A ten-step graph with broad parallel branches may finish faster than a three-step serial chain.
A production discussion of tool-calling overhead shows how poor call selection and unnecessary invocations inflate both latency and token use. Step quality matters alongside step count.
The mechanism also stops applying when tool time is negligible beside one dominant inference or upload. Counting steps alone then misleads. More steps are not automatically bad if they create observable safety or correctness gains worth their cost.
Trace the Execution Tax Across the Whole Agent Graph
Trace every workflow with timestamps for model prefill, generation, argument validation, tool queue, execution, result serialization, verification, and retries. Record input and output tokens at each turn. Compare the full graph with a direct-answer baseline on the same tasks.
Use tool-result verification as a distinct measured step rather than hiding verification inside “agent time.” Classify dependencies as serial, parallel-safe, or removable.
Optimize the largest repeated serial span first. Trim or structure tool outputs before reinsertion, parallelize only independent reads, and retain validation where failure cost is high. Track both successful completion rate and p95 latency so speed improvements do not conceal weaker execution.
How to Measure Local RAG Retrieval Quality and Interpret Recall, Precision, and Citation Coverage
Build a local RAG test set, calculate core retrieval metrics, interpret their tradeoffs, and audit whether answer claims are supported by cited evidence.
Why Does Smart Home Feature Computation Matter More as Sensor Count Increases at the Same Sampling Rate?
Trace per-sensor and cross-sensor compute as device count rises, identify nonlinear fusion costs, and benchmark the feature pipeline before automations lag.
Why Does RAG Evaluation Cost Matter More as the Document Library Grows at the Same Query Volume?
Understand why corpus growth raises RAG evaluation effort without more user queries and how stratified tests keep cost tied to risk.
