Acoustic echo cancellation improves far-field recognition by estimating loudspeaker playback captured by the microphone and removing it before speech recognition.
A home assistant listening across a room hears the resident plus its own music, spoken response, and reflections from walls and furniture. AEC receives the clean playback reference, models how the room transforms it, and subtracts the predicted echo from microphone audio. Recognition improves when the model tracks the real echo path without damaging near-end speech.
The Playback Reference Predicts What Returns to the Microphone
The system knows the digital signal sent to the loudspeaker. An adaptive filter models delay, frequency response, and reflections between that reference and the microphone, producing an estimate of the echo embedded in the captured mixture.
A detailed echo path modeling explanation traces loudspeaker audio through room surfaces back into the microphone and shows why delayed self-audio disrupts communication. The same captured echo can dominate far-field recognition during local playback. This distinction remains visible during later household testing.
Accurate alignment matters because subtracting the right waveform at the wrong time leaves residual echo and can remove unrelated speech. Playback latency changes must be included in the model. The intermediate result must remain inspectable before automation follows.
Adaptive Filtering and Residual Suppression Clean the Mixture
The filter updates coefficients as the room path changes, subtracts the estimated linear echo, and may pass remaining components through a residual suppressor. The recognizer then receives audio with a stronger near-end speech-to-echo ratio. That boundary should be measured separately under realistic operating conditions.
Research on multichannel adaptive filtering formulates multichannel adaptive filtering that accounts for near-end speech and noise. Microphone arrays add several echo paths, increasing both available spatial information and adaptation complexity. The practical consequence appears when several sources compete for limited context.
Furniture movement, speaker volume, device motion, and sample-clock mismatch can make the old filter inaccurate. Convergence speed determines how long recognition remains exposed after a path change. This dependency should remain explicit in the final interface.
Double Talk Protects the Residentโs Voice From Cancellation
When playback and a resident occur simultaneously, naive adaptation can treat near-end speech as an echo-model error and distort it. Double-talk detection freezes or modifies adaptation while preserving the new speaker as much as possible.
A study of double-talk echo control explains the challenging case where far-end playback and near-end speech coexist. Residual suppression must remove echo without erasing speech that the recognizer needs. The result must therefore be checked against the original evidence.
The failure boundary is nonlinear playback distortion, severe reverberation, missing reference audio, or incorrect timing beyond the modelโs capacity. AEC can then leave artifacts worse than the original echo and reduce recognition despite lower measured energy.
Measure Recognition Before and After Echo Processing
Record fixed commands at several distances during silence, music, synthesized assistant speech, volume changes, room movement, and double talk. Save reference, raw microphone, predicted echo, residual, processed audio, transcripts, and timing. This distinction remains visible during later household testing.
Compare the pattern with room echo behavior. Measure echo return loss enhancement, speech distortion, word error rate, wake accuracy, convergence time, and false rejection using the same recognizer and microphone placement. The intermediate result must remain inspectable before automation follows.
Enable AEC only when processed audio improves command accuracy across playback and double-talk cases. Preserve bypass diagnostics and retest after changing speakers, microphones, sample rates, or room acoustics. That boundary should be measured separately under realistic operating conditions.
